Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Save composite content as an image or pdf file
Save composite content as an image or pdf file [message #1716807] Tue, 08 December 2015 05:57 Go to next message
Hi !
I'm trying to save a composite and its whole content into a file, a pdf or an image.
This composite may have an hidden part as it uses a vertical scroll bar, but I want that these hidden part to be include in the pdf or image file.
Any idea ?
Thanks !
Helene
Re: Save composite content as an image or pdf file [message #1716868 is a reply to message #1716807] Tue, 08 December 2015 12:11 Go to previous messageGo to next message
Always worth checking through the SWT Snippets:
Re: Save composite content as an image or pdf file [message #1717132 is a reply to message #1716868] Thu, 10 December 2015 03:13 Go to previous messageGo to next message
=> "Always worth checking through the SWT Snippets"
Always read carefully the question Wink
I've tested these snippets already...
My problem is that the hidden part is not taken into account while saving the image. Thought I was clear....
Re: Save composite content as an image or pdf file [message #1717204 is a reply to message #1717132] Thu, 10 December 2015 12:39 Go to previous messageGo to next message
Sorry Embarrassed
You can use Control#print(GC) where you pass in a GC on an Image. It seems to do the right thing for individual controls, like Tree or Table on OS X, and for Composites where content has a viewport with scrollbars (but not clipped).
Brian.
Re: Save composite content as an image or pdf file [message #1717262 is a reply to message #1717204] Fri, 11 December 2015 03:28 Go to previous message
Hi again,
I found a way to do it but it works on Windows but unfortunately not on Linux (I work on Debian 64 bits).
I'm going to post a new topic about this.
Thanks for your answer
Previous Topic:Posting event from linux doesn't work like with windows
Next Topic:How to make this snippet work on Linux ?
Current Time: Sat Aug 30 23:21:09 EDT 2025
Powered by FUDForum. Page generated in 0.04745 seconds
