Home » Modeling » ATL » ATL Transformation and invalid names saved on annotations
ATL Transformation and invalid names saved on annotations [message #1716306] Wed, 02 December 2015 14:12 Go to next message
Hello !
I'm looking to transform my own model into an Ofbiz Entity Ecore model which has been reversed engineered from this XML schema:
ofbiz.apache.org/dtds/entitymodel.xsd
Entity FrameWork (my model) ----ATL----> Ofbiz EntityModel.
However the ofbiz entity model includes some invalid names, for example the entity node includes the entity-name attribute, which is renamed to entityName when reverse engineered. Additionally xml TAGS with text in them such as <description> text </description> become attributes of the parent node.
I've managed to produce instances of the ofbiz EntityModel which are correct by altering the ecore model factory implementation, and adding the following lines:
result.getDefaultLoadOptions().put(XMLResource.OPTION_RECORD_ANY_TYPE_NAMESPACE_DECLARATIONS, Boolean.TRUE);
result.getDefaultSaveOptions().put(XMLResource.OPTION_RECORD_ANY_TYPE_NAMESPACE_DECLARATIONS, Boolean.TRUE);
However i have no idea how to perform the same on ATL.
Here is the transformation code:
-- @path EntityFramework=/EntityFramework/model/entityFramework.ecore
-- @path EntityModel=/OfbizEntityModel/model/Entitymodel.ecore
module EntityFrameworkToOfbizService;
create OUT : EntityModel from IN : EntityFramework;
rule EFEntity2EMEntity {
	from
		s: EntityFramework!Entity
	to
		t: EntityModel!EntityType(
			entityName <- s.name,
			description  <- s.description,
			packageName <- s.package.name,
			field <- s.atributes
Best Regards,
Humberto Carvalho
Re: ATL Transformation and invalid names saved on annotations [message #1716634 is a reply to message #1716306] Sun, 06 December 2015 23:21 Go to previous messageGo to next message
Bump, no one?
I was thinking maybe if ATL generates the model code, i could maybe edit the ATL source code and configure the resource factory to "RECORD_ANY_TYPE_NAMESPACE_DECLARATIONS"
Re: ATL Transformation and invalid names saved on annotations [message #1716739 is a reply to message #1716634] Mon, 07 December 2015 16:39 Go to previous message
If you use the EMF namespace URIs to reference your metamodels in ATL, then ATL should already use your *ResourceFactoryImpl classes. Your example ATL code shows "@path" tags for the metamodels; these should be "@nsURI" tags ideally.
Previous Topic:Promotion of XMI to Ecore
Next Topic:XML schema as source file
Current Time: Sun Jul 27 02:19:37 EDT 2025
Powered by FUDForum. Page generated in 0.03827 seconds
