Home » Modeling » TMF (Xtext) » cross-file reference and link in xtext
cross-file reference and link in xtext [message #1716632] Sun, 06 December 2015 21:10 Go to next message
I created a new DSL by using xtext as follows. (Actually I will access the DSL on RCP application.)
grammar org.xtext.example.mydsl.MyDsl with      org.eclipse.xtext.common.Terminals
generate myDsl "...www.xtext.org/example/mydsl/MyDsl"
Configuration:
components+=(Component)*;
Component:
'Component' name=ID
(('display' display=STRING) &
('dependency' dependency=[Component|ID])?)
I have two files: sample1.mydsl
 Component comp1 {
     display "comp1"
     children comp2
sampl2.mydsl
 Component comp2 {
      display "comp2"
On RCP Application, I will compose a tree view with the Configuration model. But when I get comp2 object from getChildren() method of comp1 object, sometimes I couldn't get the comp2 object exactly.
I loaded the model data as below:
    private List<ConfigurationItem> itemList;
    void loadData() {
    project =               ResourcesPlugin.getWorkspace().getRoot().getProject("test");
    XtextResourceSet resourceSet = (XtextResourceSet) injector
        .getInstance(XtextResourceSetProvider.class)
        .get(project);
    resourceSet.addLoadOption(XtextResource.OPTION_RESOLVE_ALL, Boolean.TRUE);
    IFile[] samples = findFiles(resources);
    List<Resource> resourceList = new ArrayList<Resource>();
    for (IFile sample : samples) {
        Resource resourceSample = resourceSet.getResource(
                URI.createURI(sample.getLocationURI().toString(), true), true);
        resourceList.add(resourceSample);
    for (Resource resource : resourceList) {
        System.out.println("resource = " + resource.toString());
        try {
            resource.load(null);
        } catch (IOException e) {
            e.printStackTrace();
        EcoreUtil.resolveAll(resource);
    // add all to configuration item list
    for (Resource rc : resourceList) {
        Configuration config = (Configuration) rc.getContents().get(0);
        itemList.addAll(config.getConfigurationItems().toArray(new ConfigurationItem[config.getConfigurationItems().size()]));
test code
for (ConfigurationItem item : itemList) {
   if (item.getName().equals("comp1") {
      Component[] comps = item.getChildren();
      for (Component comp : comps) {
         if (comp != null) {
             System.out.println("comp display : " + comp.getDisplay());
result
comp display : null
I expected the result to be "comp display : comp2".
But Sometimes the result is "comp display : comp2"
and sometimes the result is "comp display : null"
I think it is because of the lazy linking of xtext.
How can always I get correct result -> "comp display : comp2"?
I Hope someone can help me solve it. Thanks.
[Updated on: Sun, 06 December 2015 22:39] by Moderator
Re: cross-file reference and link in xtext [message #1716637 is a reply to message #1716632] Mon, 07 December 2015 00:35 Go to previous messageGo to next message
Do you at some point call yourdslstandalonesetup from your code. You should never do that in an eclipse environment http://koehnlein.blogspot.de/2012/11/xtext-tip-how-do-i-get-guice-injector.html?m=1
Re: cross-file reference and link in xtext [message #1716638 is a reply to message #1716637] Mon, 07 December 2015 00:39 Go to previous messageGo to next message
And in eclipse you should load the resources by their platform resource uri
Re: cross-file reference and link in xtext [message #1716639 is a reply to message #1716638] Mon, 07 December 2015 00:52 Go to previous messageGo to next message
And you should call the resolve after the for loop
Re: cross-file reference and link in xtext [message #1716640 is a reply to message #1716637] Mon, 07 December 2015 01:03 Go to previous messageGo to next message
Hi Christian,
Because I use xtext models in RCP Application, I don't use the mydslstandalone. Instead, I created a injector as below and used it when it load models.
final private static Injector injector = ConfigDSLActivator.getInstance().getInjector("com.xxx.kcdsl.ConfigDSL");
public void loadData() {
			    .get(project);
I don't know what i did wrong.
[Updated on: Mon, 07 December 2015 01:12] by Moderator
Re: cross-file reference and link in xtext [message #1716642 is a reply to message #1716640] Mon, 07 December 2015 01:11 Go to previous messageGo to next message
Yes then move the resolveall(resourceset) after the load loop
Re: cross-file reference and link in xtext [message #1716643 is a reply to message #1716642] Mon, 07 December 2015 01:37 Go to previous messageGo to next message
Thanx Christian.
As you said, I Modified codes as below.
				try {
			EcoreUtil.resolveAll(resourceSet);
but The test code still returns "comp display : null".
[Updated on: Mon, 07 December 2015 01:39] by Moderator
Re: cross-file reference and link in xtext [message #1716644 is a reply to message #1716643] Mon, 07 December 2015 01:55 Go to previous messageGo to next message
Can you please share a complete reproduceable example
Re: cross-file reference and link in xtext [message #1716647 is a reply to message #1716644] Mon, 07 December 2015 02:56 Go to previous messageGo to next message
P.S: and use URI.createPlatformResourceURI(iFile.getFullPath().toString(), true) as decribed here https://wiki.eclipse.org/EMF/FAQ#How_do_I_map_between_an_EMF_Resource_and_an_Eclipse_IFile.3F
Re: cross-file reference and link in xtext [message #1716664 is a reply to message #1716647] Mon, 07 December 2015 05:58 Go to previous messageGo to next message
Dear Christian.
Thanx. Still returns "comp display : null" message. It seems to be a problem with resolving cross-file reference. but I can't solve the problem.
[Updated on: Mon, 07 December 2015 05:59] by Moderator
Re: cross-file reference and link in xtext [message #1716665 is a reply to message #1716664] Mon, 07 December 2015 06:25 Go to previous messageGo to next message
As i sais.i need your code to analyze
Re: cross-file reference and link in xtext [message #1716817 is a reply to message #1716665] Tue, 08 December 2015 06:44 Go to previous messageGo to next message
I made up a sample for analysis.
Please check below.
1. The code below is my sample test code. I call
new SampleConfigLoadOperation3().run(monitor); on my RCP Application.
SampleConfigLoadOperation3.java
import java.io.File;
import java.io.IOException;
import java.io.InputStream;
import java.lang.reflect.InvocationTargetException;
import java.net.MalformedURLException;
import java.net.URL;
import java.util.ArrayList;
import java.util.List;
import org.eclipse.core.resources.IFile;
import org.eclipse.core.resources.IFolder;
import org.eclipse.core.resources.IProject;
import org.eclipse.core.resources.IResource;
import org.eclipse.core.resources.IWorkspace;
import org.eclipse.core.resources.IWorkspaceRoot;
import org.eclipse.core.resources.ResourcesPlugin;
import org.eclipse.core.runtime.CoreException;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.jface.operation.IRunnableWithProgress;
import com.mdstec.ide.kcdsl.ConfigDSL.ConfigurationItem;
import com.mdstec.ide.kcdsl.ConfigDSL.Configuration;
public class SampleConfigLoadOperation3 implements IRunnableWithProgress {
	// Progress message
	final String loadConfigTaskBeginMsg = "load configuration.";
	IProject project;
	DataListener dataListener;
	 * Constructor for project configuration object
	 * @param prjConfig
	 *            the project configuration object
	public SampleConfigLoadOperation3() {
		// TODO Auto-generated constructor stub
    public SampleConfigLoadOperation3(IProject project, DataListener listner) {
    	this.project = project;
    	this.dataListener = listner;
	public void run(IProgressMonitor monitor) throws InvocationTargetException,
			InterruptedException {
		// TODO Auto-generated method stub
		if (monitor != null) {
			monitor.beginTask(loadConfigTaskBeginMsg, IProgressMonitor.UNKNOWN);
		try {
			loadConfigData(monitor);
		} catch (Exception e) {
			throw new InvocationTargetException(e, "Loading error" + ": "
					+ e.getMessage());
		} finally {
				monitor.done();
			if (monitor.isCanceled()) {
				throw new InterruptedException("Cancel loading");
	private void loadConfigData(IProgressMonitor monitor) {
		IWorkspace workspace = ResourcesPlugin.getWorkspace();
		IWorkspaceRoot workspaceRoot = workspace.getRoot();
		project  = workspaceRoot.getProject("testproject");
		IFolder sampleFolder = project.getFolder("data");
		//at this point, no resources have been created
		try {
			if (!project.exists())
				project.create(null);
			if (!project.isOpen())
				project.open(null);
		} catch (CoreException e2) {
			e2.printStackTrace();
		if (!sampleFolder.exists()) {
			try {
				sampleFolder.create(IResource.NONE, true, null);
			} catch (CoreException e) {
		copyDataFileToProject("sample1.cdl", "data");
		copyDataFileToProject("sample2.cdl", "data");
//		copyDataFileToProject("sample3.cdl", "data");
		ResourceSet resourceSet = new ResourceSetImpl();
		IResource[] resources = null;
		try {
			resources = sampleFolder.members();
		} catch (CoreException e1) {
			e1.printStackTrace();
		if (resources != null) {
						URI.createURI(sample.getFullPath().toString()), true);
			List<ConfigurationItem> configItemList = new ArrayList<ConfigurationItem>();
				configItemList.addAll(config.getConfigurationItems());
			// root model
			List<ConfigurationItem> rootItemList = new ArrayList<ConfigurationItem>();
			// set root list in configuration item list
			for (int i = 0; i < configItemList.size(); i++) {
				ConfigurationItem item = configItemList.get(i);
				if (item instanceof com.mdstec.ide.kcdsl.ConfigDSL.Package) {
					if (((com.mdstec.ide.kcdsl.ConfigDSL.Package) item)
							.isIsRoot()) {
						rootItemList.add(item);
			// set parents
			for (int i = 0; i < rootItemList.size(); i++) {
				ConfigurationItem root = rootItemList.get(i);
				ConfigurationItem[] children = (ConfigurationItem[]) root
						.getChildren().toArray();
				setParent(children, root);
			System.out.println("root size = " + rootItemList.size());
			for (ConfigurationItem item : rootItemList) {
				findChildren(item);
	private void copyDataFileToProject(String fileName, String prjDir) {
		File file = new File("C:/test/data/" + fileName);
		URL sourceURL = null;
		try {
			sourceURL = file.toURL(); // using .toURI().toURL()
										// fails,
										// due to
										// spaces substitution
		} catch (MalformedURLException e) {
		InputStream in = null;
		try {
			in = sourceURL.openStream();
		IFile iFile = project.getFile(prjDir + "/" + fileName);
		if (!iFile.exists()) {
			try {
				iFile.create(in, true, null);
				iFile.refreshLocal(IResource.DEPTH_ONE, null);
	private void findChildren(ConfigurationItem item) {
		ConfigurationItem[] children = (ConfigurationItem[]) item.getChildren()
				.toArray();
		if (children != null && children.length > 0) {
			for (ConfigurationItem child : children) {
				System.out.println("child name of " + item.getName() + " : "
						+ child.getName());
				findChildren(child);
	private void setParent(ConfigurationItem[] children,
			ConfigurationItem parent) {
				child.setParent(parent);
				setParent((ConfigurationItem[]) child.getChildren().toArray(),
						child);
	private IFile[] findFiles(IResource[] resources) {
		List<IFile> fileList = new ArrayList<IFile>();
		find(resources, fileList);
		return fileList.toArray(new IFile[fileList.size()]);
	private void find(IResource[] resources, List<IFile> fileList) {
		if (resources != null && resources.length > 0) {
			for (IResource res : resources) {
				if (res instanceof IFile) {
					fileList.add((IFile) res);
				} else if (res instanceof IFolder) {
					IResource[] reses;
					try {
						reses = ((IFolder) res).members();
						find(reses, fileList);
2. I defined my DSL using xtext as below and generated the models and parser.
ConfigDSL.xtext
generate ConfigDSL "............."
Configuration:
	((configurationItems+=ConfigurationItem)*
ConfigurationItem:
	Package | Component
Package:
	'Package' name=ID
		('description' description=STRING)? &
		('children' children += [ConfigurationItem|ID] (',' children += [ConfigurationItem|ID])*)?  &
		('parent' parent = [ConfigurationItem|ID])? &
		('isRoot' isRoot=BOOLEAN)?
Component:
	'Component' name=ID
terminal BOOLEAN returns ecore::EBoolean
	: 'true' | 'false';
3. I created two DSL files (sample1.cdl, sample2.cdl) as below and located in "C:/test/data" directory.
sample1.cdl
Component ds1 {
	display "ds1"
Component ds2 {
	display "ds2"
Package pk1 {
	display "pk1"
	children ds1, ds2, ds3
	isRoot true
sample2.cdl
Component ds3 {
	display "ds3"
4. When I call "new SampleConfigLoadOperation3().run(monitor);" on my RCP Application, the result is as follows.
root size = 1
child name of pk1 : ds1
child name of pk1 : ds2
child name of pk1 : null
I don't know why the result of the 3rd line is "child name of pk1 : null".
I expected the result is "child name of pk1 : ds3".
Re: cross-file reference and link in xtext [message #1716820 is a reply to message #1716817] Tue, 08 December 2015 07:06 Go to previous messageGo to next message
- the code does not compile. even if i remove the datalistener
- why do you copy files around? i always asumed you try to load model files from an xtext project that is clean built (xtext nature, incr. build was run after copy)
- after you read the model you seem to make a model 2 model transformation
so this is not really code i can simply import and execute
Re: cross-file reference and link in xtext [message #1716908 is a reply to message #1716820] Tue, 08 December 2015 20:05 Go to previous messageGo to next message
Sorry Christian. I don't know why the sample isn't compiled. I use the sample. Anyway, My RCP application will provide a function that can create a CProject. The created CProject has a treeview. When user creates a CProject and select a menu in the project, the application will collect one more DSL files In a specific folder (outside the project) and display the models on the treeview. Also user can edit the model data on the treeview. Is that possible using xtext? If that is impossible, is there an alternative for that?
In addition, I want a flat DSL to express a tree structure. That means that I want a DSL using not containment reference (layered DSL). So I will transform the models parsed by xtext to models that can be displayed on tree view.
[Updated on: Tue, 08 December 2015 20:20] by Moderator
Re: cross-file reference and link in xtext [message #1716923 is a reply to message #1716908] Wed, 09 December 2015 00:43 Go to previous messageGo to next message
Simply make sure the project has xtext nature and xtext builder and you call a build on the project
Re: cross-file reference and link in xtext [message #1716937 is a reply to message #1716923] Wed, 09 December 2015 01:54 Go to previous message
I solved the problem.
When creating ResourceSet object, I Modified the codes as below.
Now it works well.
		 Injector injector = new MyDSLStandaloneSetup().createInjectorAndDoEMFRegistration();
		 XtextResourceSet resourceSet = injector.getInstance(XtextResourceSet.class);
I understood wrong that MyDSLStandaloneSetup() should not use in RCP.
Previous Topic:update specific outline node by changing its background
Next Topic:Please check if using xtext is suitable in my case
Current Time: Thu Aug 21 15:15:54 EDT 2025
Powered by FUDForum. Page generated in 0.06419 seconds
