| http service in gyrex cluster [message #1716512] |
Fri, 04 December 2015 08:22  |
Finally, I decide to move standalone to cluster in production environment, it is more stable than standalone application.
I have done a simple test for cluster environment before deploying to production. There are two gyrex servers A (192.168.31.151) and B (192.168.31.156), and I have setup the http connectors on port 8080, and then set the tags for these two servers. A has three tags (webserver, scheduler, worker), and B has only one tag (webserver).
Then I try to access the web service through following two urls:
http://192.168.31.151:8080/service/xxx/yyy/zzz
http://192.168.31.156:8080/service/xxx/yyy/zzz
But, the first one cannot access with err connection refused, while the second one can access successfully.
Is there any mistake with my configuration?
| Re: http service in gyrex cluster [message #1719261 is a reply to message #1716577] |
Wed, 06 January 2016 11:21  |
On 2015-12-05 10:25:52 +0000, Sean Zhang said:
> Then, I reset everything and want to re-produce the problem, and then
> found that after setup the http service, the nodes need to be restarted.
That's probably a lack of dynamics in the implementation. It's not
intended to be that way. Sometimes we just haven't had the time to
finish/polish all the dynamics. In such a case, a node restart helps.
-Gunnar
Gunnar Wagenknecht
gunnar@xxxxxxxx
FUDForum. Page generated in 0.26099 seconds
