Home » Eclipse Projects » Sirius » programmatically create a second aird file
programmatically create a second aird file [message #1716509] Fri, 04 December 2015 08:12 Go to next message
I want to copy an existing diagram and place it in a representation file that does not exist yet.
Copying a representation is not so difficult using the copyRepresentation() from the dialectmanager.
However creating a new representations file using SessionManager.INSTANCE.getSession("newRepresentationsUrl") results in the error:
"Found 2 main representations files (that means not referenced by another)...... A modeling project must contain only one."
How to solve this? How to add a reference of my new file to the original one
PS: basically its the same as what "extract to .aird file" does in eclipses project explorer menu
Re: programmatically create a second aird file [message #1716523 is a reply to message #1716509] Fri, 04 December 2015 09:14 Go to previous messageGo to next message
Hi Koen
This allows you to create a new Session (and you can have only one per
Modeling Project).
It seems you just want to create a new aird file, referenced from the
exisitng one to store one or many diagrams. So this will just be a copy
of the existing diagram and you want that both representations continue
to reference the same instance of the model ? (same instance, same
resourceset, same session).
> the error:
> one
You might take a look to
org.eclipse.sirius.ui.tools.internal.views.common.action.ExtractRepresentationAction
and
org.eclipse.sirius.ui.tools.internal.wizards.ExtractRepresentationsWizard.performFinish()
Maxime - Obeo
Re: programmatically create a second aird file [message #1716526 is a reply to message #1716523] Fri, 04 December 2015 09:59 Go to previous messageGo to next message
Thanks for your response
Yes i want to create a new aird file, referenced from the existing one.
Re: programmatically create a second aird file [message #1716530 is a reply to message #1716526] Fri, 04 December 2015 10:31 Go to previous message
DAnalysis slaveAnalysis = ViewpointFactory.eINSTANCE.createDAnalysis();
to create a new analysis
now i only i have to look into
new PrepareNewAnalysisCommand(domain, pickedResource, slaveAnalysis, session) and new MoveRepresentationCommand(session, slaveAnalysis, representations);
Previous Topic:Internal error when trying to open an aird file
Next Topic:How to create Border Node with a Domain Class not in the semantic model
Current Time: Mon Jul 28 09:37:15 EDT 2025
Powered by FUDForum. Page generated in 0.04716 seconds
