Trouble importing Atmel ASF project [message #1715316] |
Sat, 21 November 2015 17:07  |
Hi All,
I am new to Eclipse and am trying to use in a Linux environment to develop for an Atmel SAM D21 Explained Pro development board. The Atmel Software Framework has a led toggle demo project which I am trying to import into Eclipse so that I can build and run. However, Eclipse does not seem to recognize the demo project gcc files which are:
config.mk
Makefile
asf.h
Can anyone offer me some clues on how I can get Eclipse to recognize these files and make a project?
I am running Eclipse for C/C++ Developers, Mars.1 Release 4.5.1
Dallas
Re: Trouble importing Atmel ASF project [message #1716421 is a reply to message #1715490] |
Thu, 03 December 2015 10:59   |
Hi David,
Thank you for your reply and sorry for taking so long to answer your questions.
> What kind of project is this? Autotools?
> What exactly are you doing?
This is an Atmel embedded micro-controller project. Pardon my ignorance, because I have never used Atmel products or Eclipse before. I'm an old-fashioned Linux command-line tools guy, gnu make, gnu gcc etc.
Atmel has a demo project for the microcontroller board I am trying to use. I simply want to build this project and run it on my eval board. Atmel provides a Windows IDE which I believe is based on Eclipse. I am allergic to Windows, and just wanting to import this project into Linux / Eclipse, build, and run.
I'm not sure what kind of format this config.mk file is. I have attached for you to take a look at.
Thanks for your help!
Attachment: Makefile
(Size: 2.13KB, Downloaded 235 times)
Attachment: config.mk
(Size: 6.04KB, Downloaded 231 times)
Attachment: asf.h
(Size: 2.97KB, Downloaded 288 times)
Re: Trouble importing Atmel ASF project [message #1729778 is a reply to message #1716425] |
Mon, 18 April 2016 20:00  |
I am having the same issue but I can't seem to import the project to the workspace. Iam using eclipse CDT Mars on ubuntu 14.04.
Particularly, I have tried both importing existing projects into workspace and new project from makefile but still I can't get my project to be imported properly. Can someone please advise. (3rd day trying to install the toolchain for linux )
FUDForum. Page generated in 0.50812 seconds
