Null Worbench after changing bundle configurations [message #1716367] |
Thu, 03 December 2015 04:50  |
Dear list,
while overhauling all my bundles/features dependencies I managed to achieve validation of my product's plug-ins (Run Configuration -> Plug-ins -> Validate).
I have been happy and satisfied for a little while, as soon as I realized that my application now throws hundreds of NullPointers for it cannot get the instance of the org.eclipse.ui.internal.Workbench.
I have seen this issue around in a couple of places, but they only suggest to clear the workspace, clean Eclipse caches, even move the project to another folder, etc..
Here is the stack trace:
at org.eclipse.ui.internal.themes.ColorAndFontProviderImpl.getCurrentTheme(ColorAndFontProviderImpl.java:51)
at org.eclipse.ui.internal.themes.ColorAndFontProviderImpl.getColor(ColorAndFontProviderImpl.java:47)
at org.eclipse.e4.ui.css.swt.helpers.CSSSWTColorHelper.findColorByDefinition(CSSSWTColorHelper.java:319)
at org.eclipse.e4.ui.css.swt.helpers.CSSSWTColorHelper.getRGB(CSSSWTColorHelper.java:70)
at org.eclipse.e4.ui.css.swt.helpers.CSSSWTColorHelper.getSWTColor(CSSSWTColorHelper.java:58)
at org.eclipse.e4.ui.css.swt.properties.converters.CSSValueSWTColorConverterImpl.convert(CSSValueSWTColorConverterImpl.java:46)
at org.eclipse.e4.ui.css.swt.properties.converters.CSSValueSWTColorConverterImpl.convert(CSSValueSWTColorConverterImpl.java:1)
at org.eclipse.e4.ui.css.core.impl.engine.AbstractCSSEngine.convert(AbstractCSSEngine.java:1077)
at org.eclipse.e4.ui.css.swt.properties.custom.CSSPropertye4TabOutline.applyCSSProperty(CSSPropertye4TabOutline.java:31)
at org.eclipse.e4.ui.css.swt.properties.AbstractCSSPropertySWTHandler.applyCSSProperty(AbstractCSSPropertySWTHandler.java:40)
at org.eclipse.e4.ui.css.core.impl.engine.AbstractCSSEngine.applyCSSProperty(AbstractCSSEngine.java:722)
at org.eclipse.e4.ui.css.core.impl.engine.AbstractCSSEngine.applyStyleDeclaration(AbstractCSSEngine.java:520)
at org.eclipse.e4.ui.css.core.impl.engine.AbstractCSSEngine.applyStyles(AbstractCSSEngine.java:413)
at org.eclipse.e4.ui.css.core.impl.engine.AbstractCSSEngine.applyStyles(AbstractCSSEngine.java:354)
at org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngine.applyStyles(ThemeEngine.java:512)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$11.setClassnameAndId(PartRenderingEngine.java:1321)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.setCSSInfo(SWTPartRenderer.java:111)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.bindWidget(SWTPartRenderer.java:128)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.createWidget(StackRenderer.java:620)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:983)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:662)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:766)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:737)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:731)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:715)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:69)
at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:185)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:674)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:49)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:69)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:187)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4590)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:218)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:59)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:135)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:1)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:108)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:678)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:663)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1074)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:331)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:164)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at java.lang.reflect.Method.invoke(Method.java:483)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
This happens independently whether I launch the product directly, or via a Run Configuration with additional required plug-ins included.
Thanks for trying to help,
-Piero !
FUDForum. Page generated in 0.03487 seconds
