Home » Eclipse Projects » Eclipse 4 » Null Worbench after changing bundle configurations( The infamous ColorAndFontProviderImpl.getCurrentTheme() NullPointer)
Null Worbench after changing bundle configurations [message #1716367] Thu, 03 December 2015 04:50 Go to next message
Dear list,
while overhauling all my bundles/features dependencies I managed to achieve validation of my product's plug-ins (Run Configuration -> Plug-ins -> Validate).
I have been happy and satisfied for a little while, as soon as I realized that my application now throws hundreds of NullPointers for it cannot get the instance of the org.eclipse.ui.internal.Workbench.
I have seen this issue around in a couple of places, but they only suggest to clear the workspace, clean Eclipse caches, even move the project to another folder, etc..
Here is the stack trace:
	at org.eclipse.ui.internal.themes.ColorAndFontProviderImpl.getCurrentTheme(ColorAndFontProviderImpl.java:51)
	at org.eclipse.ui.internal.themes.ColorAndFontProviderImpl.getColor(ColorAndFontProviderImpl.java:47)
	at org.eclipse.e4.ui.css.swt.helpers.CSSSWTColorHelper.findColorByDefinition(CSSSWTColorHelper.java:319)
	at org.eclipse.e4.ui.css.swt.helpers.CSSSWTColorHelper.getRGB(CSSSWTColorHelper.java:70)
	at org.eclipse.e4.ui.css.swt.helpers.CSSSWTColorHelper.getSWTColor(CSSSWTColorHelper.java:58)
	at org.eclipse.e4.ui.css.swt.properties.converters.CSSValueSWTColorConverterImpl.convert(CSSValueSWTColorConverterImpl.java:46)
	at org.eclipse.e4.ui.css.swt.properties.converters.CSSValueSWTColorConverterImpl.convert(CSSValueSWTColorConverterImpl.java:1)
	at org.eclipse.e4.ui.css.core.impl.engine.AbstractCSSEngine.convert(AbstractCSSEngine.java:1077)
	at org.eclipse.e4.ui.css.swt.properties.custom.CSSPropertye4TabOutline.applyCSSProperty(CSSPropertye4TabOutline.java:31)
	at org.eclipse.e4.ui.css.swt.properties.AbstractCSSPropertySWTHandler.applyCSSProperty(AbstractCSSPropertySWTHandler.java:40)
	at org.eclipse.e4.ui.css.core.impl.engine.AbstractCSSEngine.applyCSSProperty(AbstractCSSEngine.java:722)
	at org.eclipse.e4.ui.css.core.impl.engine.AbstractCSSEngine.applyStyleDeclaration(AbstractCSSEngine.java:520)
	at org.eclipse.e4.ui.css.core.impl.engine.AbstractCSSEngine.applyStyles(AbstractCSSEngine.java:413)
	at org.eclipse.e4.ui.css.core.impl.engine.AbstractCSSEngine.applyStyles(AbstractCSSEngine.java:354)
	at org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngine.applyStyles(ThemeEngine.java:512)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$11.setClassnameAndId(PartRenderingEngine.java:1321)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.setCSSInfo(SWTPartRenderer.java:111)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.bindWidget(SWTPartRenderer.java:128)
	at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.createWidget(StackRenderer.java:620)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:983)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:662)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:766)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:737)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:731)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:715)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:69)
	at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:185)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:674)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:49)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:69)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:187)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4590)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:218)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:59)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:135)
	at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:1)
	at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:108)
	at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:678)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:663)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1074)
	at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:331)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:164)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
	at java.lang.reflect.Method.invoke(Method.java:483)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
This happens independently whether I launch the product directly, or via a Run Configuration with additional required plug-ins included.
Thanks for trying to help,
-Piero !
Re: Null Worbench after changing bundle configurations [message #1716418 is a reply to message #1716367] Thu, 03 December 2015 10:38 Go to previous messageGo to next message
Check your product or application setting in your Run Configuration. You're launching an E4 application, and not an E3.x Workbench application.
Re: Null Worbench after changing bundle configurations [message #1716423 is a reply to message #1716418] Thu, 03 December 2015 11:04 Go to previous messageGo to next message
Hi Brian,
I am actually running the product as an E4 application (org.eclipse.e4.ui.workbench.swt.E4Application).
Why do you think I am running it as an E3 one?
thanks,
-Piero
Re: Null Worbench after changing bundle configurations [message #1716426 is a reply to message #1716423] Thu, 03 December 2015 11:39 Go to previous messageGo to next message
Piero Campalani wrote on Thu, 03 December 2015 11:04
If you're running an E4 app, don't include any bundles matching org.eclipse.ui.*.
Brian.
Re: Null Worbench after changing bundle configurations [message #1716431 is a reply to message #1716426] Thu, 03 December 2015 12:07 Go to previous messageGo to next message
Woah... thank you Brian, did not know about this, guess I should have read more about E4.
Do you mean I should not include the org.eclipse.ui plug-in neither?
Re: Null Worbench after changing bundle configurations [message #1716432 is a reply to message #1716431] Thu, 03 December 2015 12:18 Go to previous message
That's right!
Previous Topic:e4 Best Practice to avoid extension points
Next Topic:Eclipse e4 - Part menus
Current Time: Sat Jul 26 06:18:35 EDT 2025
Powered by FUDForum. Page generated in 0.04276 seconds
