Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Forms] multi-row controls
[EMF Forms] multi-row controls [message #1715956] Sun, 29 November 2015 06:47 Go to next message
I try to render something called "text area" - in SWT it is called "multi-line text", however it does not work. I subclassed TextControlSWTRenderer like this:
public class DescriptionControlRenderer extends TextControlSWTRenderer {
	private final static int ROWS = 10;
	@Inject
	public DescriptionControlRenderer(VControl vElement, ViewModelContext viewContext, ReportService reportService,
			EMFFormsDatabinding emfFormsDatabinding, EMFFormsLabelProvider emfFormsLabelProvider,
			VTViewTemplateProvider vtViewTemplateProvider, EMFFormsEditSupport emfFormsEditSupport) {
		super(vElement, viewContext, reportService, emfFormsDatabinding, emfFormsLabelProvider, vtViewTemplateProvider,
				emfFormsEditSupport);
	protected Control createSWTControl(Composite parent) {
		final Text text = new Text(parent, getTextWidgetStyle());
		GridData gridData = new GridData(SWT.FILL, SWT.CENTER, true, true);
		gridData.minimumHeight = ROWS * text.getLineHeight();
		gridData.heightHint = ROWS * text.getLineHeight();
		text.setLayoutData(gridData);
		return text;
	public SWTGridDescription getGridDescription(SWTGridDescription gridDescription) {
		int columns;
		switch (getVElement().getLabelAlignment()) {
			case DEFAULT:
			case LEFT:
				columns = 3;
				break;
			case NONE:
				columns = 2;
				break;
			default:
				getReportService().report(new AbstractReport(MessageFormat.format(
						"Label alignment {0} is not supported by renderer {1}. Label alignment set to default.",
						getVElement().getLabelAlignment().getLiteral(), getClass().getName()), IStatus.INFO));
				getVElement().setLabelAlignment(LabelAlignment.DEFAULT);
				columns = 3;
		SWTGridDescription description = GridDescriptionFactory.INSTANCE.createSimpleGrid(ROWS, columns, this);
		for (int i = 0; i < description.getGrid().size() - 1; i++) {
			SWTGridCell swtGridCell = description.getGrid().get(i);
			swtGridCell.setHorizontalGrab(false);
		return description;
	protected int getTextWidgetStyle() {
		return SWT.MULTI | SWT.WRAP | SWT.V_SCROLL | SWT.H_SCROLL | SWT.BORDER | getAlignment();
	private int getAlignment() {
		if (getVTViewTemplateProvider() == null) {
			return getDefaultAlignment();
		final Set<VTStyleProperty> styleProperties = getVTViewTemplateProvider()
			.getStyleProperties(getVElement(), getViewModelContext());
		for (final VTStyleProperty styleProperty : styleProperties) {
			if (VTAlignmentStyleProperty.class.isInstance(styleProperty)) {
				if (VTAlignmentStyleProperty.class.cast(styleProperty).getType() == AlignmentType.LEFT) {
					return SWT.LEFT;
				} else if (VTAlignmentStyleProperty.class.cast(styleProperty).getType() == AlignmentType.RIGHT) {
					return SWT.RIGHT;
That is I set the number of rows in getGridDescription(), as well the height of the multi-line control but nothing seem to work.
Is it a limitation of EMF Forms: always the one-row? Or can it be achieved with custom areas? Looking at the custom area example gives no clarity on this topic, because the example uses 2 1*1 grids instead of 1 2*1... how can we render text area in EMF Forms?
Re: [EMF Forms] multi-row controls [message #1715967 is a reply to message #1715956] Sun, 29 November 2015 13:11 Go to previous messageGo to next message
well, the custom area would be to much - I think the way is to subclass AbstractSWTRenderer
multi-line text controls are required in most form-based applications
there should be some MultiLineTextSWTRenderer in EMF Forms
at the moment multi-line text goes rendered into one-line control with scroll-bar
thanks again
Re: [EMF Forms] multi-row controls [message #1716001 is a reply to message #1715967] Mon, 30 November 2015 06:42 Go to previous messageGo to next message
even better would be setting property "multiline" to "true" in gen-model... then text area will be rendered by default Laughing oh boy.. is it documented somewhere?
although I would see this "multiline" property as explicit part of the view model, not of the gen-model
Re: [EMF Forms] multi-row controls [message #1716056 is a reply to message #1716001] Mon, 30 November 2015 16:48 Go to previous message
Hi Klim,
good that you found the option.
Yeah the multi-line thing is strange.
On the one hand site the genmodel has this optional so it makes sense to reuse it. On the other hand one could make this explicit.
So could you please open a bug report for this. Maybe we will find some time to fix this.
Thanks and cheers,
Eugen
Previous Topic:[Texo] NoSuchMethodError
Next Topic:[EMF Forms] Error running org.eclipse.emf.ecp.makeithappen.application.sample.e3
Current Time: Sun Jul 27 02:27:16 EDT 2025
Powered by FUDForum. Page generated in 0.06176 seconds
