Home » Modeling » GMF (Graphical Modeling Framework) » generate various diagrams on the same project
generate various diagrams on the same project [message #1715932] Fri, 27 November 2015 19:18 Go to next message
good night, first like to apologize for my English.
I am new to GMF. I'm creating a project with several ecores and other files that make up the GMF and would like to run them in a single project. How should I proceed?
Currently I do every gmfgen generate the project at a diagram in a separate folder, in addition, I change the model id gmfgen. But to run as application of the eclipse, all diagrams appear in the example folder. It is normal?
Thank you.
Re: generate various diagrams on the same project [message #1717444 is a reply to message #1715932] Sun, 13 December 2015 17:08 Go to previous messageGo to next message
You will create different GMF projects for each diagram. When you are ready to ship you will bundle all these together in a single plugin (see eclipse plugin features and eclipse plugin update site for more info on that).
Re: generate various diagrams on the same project [message #1718116 is a reply to message #1717444] Sat, 19 December 2015 21:53 Go to previous message
Thanks for the answer. It is through wizards that can build different diagrams on the same project.
Previous Topic:Adding Menus when running an activity diagram
Next Topic:Inheritance among nodes in different diagrams
Current Time: Tue May 13 05:28:33 EDT 2025
Powered by FUDForum. Page generated in 0.03676 seconds
