Home » Eclipse Projects » EclipseLink » Eclipselink is attempting to convert fields it's not supposed to
Eclipselink is attempting to convert fields it's not supposed to [message #1715193] Fri, 20 November 2015 00:30 Go to next message
We've recently upgraded from glassfish 3.1.2.2 (eclipselink 2.3.2) to glassfish 4.1.1 (eclipselink 2.6.1), and since then we've seen intermittent issues with the old converters that used to work.
In particular we see errors like this
Caused by: Exception [EclipseLink-3002] (Eclipse Persistence Services - 2.6.1.qualifier): org.eclipse.persistence.exceptions.ConversionException
Exception Description: The object [2142420849], of class [class java.lang.String], from mapping [org.eclipse.persistence.mappings.DirectToFieldMapping[usn-->smartedition.newsagentsubscriberqueue.usn]] with descriptor [RelationalDescriptor(com.inomial.newsagent.entities.NewsagentSubscriberQueue --> [DatabaseTable(smartedition.newsagentsubscriberqueue)])], could not be converted to [class java.util.UUID].
The thing that is odd is that the field in question NewsagentSubscriberQueue.usn is not annotated with @Convert at all (but the @Id field is).
@Entity
@Table(name="newsagentsubscriberqueue", schema="smartedition")
public class NewsagentSubscriberQueue implements Serializable
  @Id
  @Converter(converterClass=UUIDConverter.class, name="newsagentSubscriberQueue_uuid")
  @Convert("newsagentSubscriberQueue_uuid")
  @Column(name="newsagentsubscriberqueue")
  private UUID newsagentSubscriberQueue = UUID.randomUUID();
  private String usn;
  <... other fields ...>
Is there something we could be doing to cause this, or is this just a bug?
Re: Eclipselink is attempting to convert fields it's not supposed to [message #1715889 is a reply to message #1715193] Fri, 27 November 2015 05:45 Go to previous messageGo to next message
GlassFish 4.1.1 is known to have some issues with EclipseLink. They used EclipseLink 2.6.1-RC1 which was not final 2.6.1 release and we know that there are some integration problems.
On the other hand this issue looks quite strange.
Can you try GlassFish 4.1 and test this scenario with it? I know it's older but I would believe that this one may work better with EclipseLink.
Re: Eclipselink is attempting to convert fields it's not supposed to [message #1715971 is a reply to message #1715889] Sun, 29 November 2015 19:32 Go to previous messageGo to next message
Thanks for the suggestion. We've tried glassfish 4.1 also, and it has the same trouble (plus some others!).
The strangest part is that it's not entirely reproducible - sometimes it works ok.
I'll see if we can get a test case together.
Re: Eclipselink is attempting to convert fields it's not supposed to [message #1719081 is a reply to message #1715971] Mon, 04 January 2016 20:08 Go to previous messageGo to next message
I've attempted to make a reproduction case, but I can't reproduce it outside of our main product, so presumably there's interference from something else, or else the reproduction case is too simple. I'm happy to try any suggestions to get the reproduction case to reproduce it.
One potential oddity to point out is that we're not using the @Id field (which is a UUID) to link the two entities, we're using a different candidate key (usn), which is the one that is triggering the problem.
Any help would be appreciated
Entity code snippits:
@Entity
@NamedQueries({
  @NamedQuery(name="NewsagentSubscriberQueue.getUnprocessedSubscribersByUsn", query="Select n from NewsagentSubscriberQueue n where n.processed is null and n.usn = :usn")
  @Id
  private String usn;
  [more basic fields ...]
  @ManyToOne
  @JoinColumn(name="usn", referencedColumnName="usn", insertable=false, updatable=false)
  private NewsagentSubscriberState subscriberState;
  [getters & setters...]
@Entity
@Table(name="newsagentsubscriberstate", schema="smartedition")
public class NewsagentSubscriberState implements Serializable
  @Id
  @Converter(converterClass=UUIDConverter.class, name="newsagentsubscriberstate_uuid")
  @Convert("newsagentsubscriberstate_uuid")
  @Column(name="newsagentsubscriberstate")
  private UUID newsagentSubscriberState = UUID.randomUUID();
  private String usn;
  @OneToMany (mappedBy="subscriberState", orphanRemoval=true)
  private Set<NewsagentSubscriberQueue> newsagentSubscriberQueue;
Local Exception Stack:
Exception Description: The object [2142420823], of class [class java.lang.String], from mapping [org.eclipse.persistence.mappings.DirectToFieldMapping[usn-->smartedition.newsagentsubscriberqueue.usn]] with descriptor [RelationalDescriptor(com.inomial.newsagent.entities.NewsagentSubscriberQueue --> [DatabaseTable(smartedition.newsagentsubscriberqueue)])], could not be converted to [class java.util.UUID].
	at org.eclipse.persistence.exceptions.ConversionException.couldNotBeConverted(ConversionException.java:78)
	at org.eclipse.persistence.internal.helper.ConversionManager.convertObject(ConversionManager.java:176)
	at org.eclipse.persistence.internal.databaseaccess.DatasourcePlatform.convertObject(DatasourcePlatform.java:179)
	at org.eclipse.persistence.mappings.foundation.AbstractDirectMapping.getFieldValue(AbstractDirectMapping.java:789)
	at org.eclipse.persistence.internal.expressions.QueryKeyExpression.getFieldValue(QueryKeyExpression.java:420)
	at org.eclipse.persistence.internal.expressions.ParameterExpression.getValue(ParameterExpression.java:299)
	at org.eclipse.persistence.internal.databaseaccess.DatabaseCall.translate(DatabaseCall.java:1102)
	at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:241)
	at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:228)
	at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeSelectCall(DatasourceCallQueryMechanism.java:299)
	at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.selectAllRows(DatasourceCallQueryMechanism.java:694)
	at org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectAllRowsFromTable(ExpressionQueryMechanism.java:2740)
	at org.eclipse.persistence.internal.queries.ExpressionQueryMechanism.selectAllRows(ExpressionQueryMechanism.java:2693)
	at org.eclipse.persistence.queries.ReadAllQuery.executeObjectLevelReadQuery(ReadAllQuery.java:559)
	at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeDatabaseQuery(ObjectLevelReadQuery.java:1175)
	at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:904)
	at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:1134)
	at org.eclipse.persistence.queries.ReadAllQuery.execute(ReadAllQuery.java:460)
	at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:1222)
	at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2896)
	at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1857)
	at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1839)
	at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1804)
	at org.eclipse.persistence.internal.jpa.QueryImpl.executeReadQuery(QueryImpl.java:258)
	at org.eclipse.persistence.internal.jpa.QueryImpl.getResultList(QueryImpl.java:473)
	at com.inomial.newsagent.listener.NewsagentProvisionManagerBean.deleteFromSubscriberQueue(NewsagentProvisionManagerBean.java:267)
Triggering code:
    TypedQuery<NewsagentSubscriberQueue> query = entityManager.createNamedQuery("NewsagentSubscriberQueue.getUnprocessedSubscribersByUsn", NewsagentSubscriberQueue.class);
    query.setParameter("usn", usn);
    List<NewsagentSubscriberQueue> queue = query.getResultList();  <-- Exception thrown here
Re: Eclipselink is attempting to convert fields it's not supposed to [message #1719184 is a reply to message #1719081] Tue, 05 January 2016 19:08 Go to previous message
Ahha, found the problem. Naturally it was our code and not EclipseLink
One of our converters was a bit over-zealous with it's setting up of UUIDs:
public class UUIDConverter implements org.eclipse.persistence.mappings.converters.Converter
  private static final long serialVersionUID = 1L;
  public UUID convertObjectValueToDataValue(Object objectValue, Session session)
    return (UUID) objectValue;
  public UUID convertDataValueToObjectValue(Object dataValue, Session session)
    return (UUID) dataValue;
  public boolean isMutable()
    return false;
  public void initialize(DatabaseMapping mapping, Session session)
    DatabaseField field = mapping.getField();
    field.setSqlType(Types.OTHER);
    field.setTypeName("java.util.UUID");
    field.setColumnDefinition("UUID");
    for (DatabaseMapping m : mapping.getDescriptor().getMappings())
      if (m instanceof OneToOneMapping)
        for (DatabaseField relationshipField : ((OneToOneMapping) m).getForeignKeyFields())
          relationshipField.setSqlType(Types.OTHER);
          relationshipField.setColumnDefinition("UUID");
          relationshipField.setTypeName("java.util.UUID");
As you can see, it sets ALL fields to be UUIDs, not just the one it's dealing with! I'm pretty sure we got this off the internet, so I guess that's what we get for not understanding what we're doing!
Previous Topic:ReplicationDriver
Next Topic:Doing an Oracle db query with a PL/SQL Function in where clause
Current Time: Sun Jul 27 04:10:23 EDT 2025
Powered by FUDForum. Page generated in 0.30396 seconds
