Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [TEXO] Is it possible to use Texo without DB?
[TEXO] Is it possible to use Texo without DB? [message #1709979] Fri, 02 October 2015 08:08 Go to next message
I'm currently trying to setup Texo in Felix. Right now I have everything resolving without errors and also the JSONRestWebServiceServlet is registered and running.
As I don't want to use a DB yet, I wanted to ask if there is a way to run this setup without one? All the examples seem to assume, that a DB is installed and an EntityManager is available.
I'd prefer an in memory solution just for testing and I thought this might have something to do with the MemoryObjectStore provided by Texo, but I just don't understand how to set up things properly.
Any hint is appreciated Smile
Kind regards,
Thomas
Re: [TEXO] Is it possible to use Texo without DB? [message #1710204 is a reply to message #1709979] Mon, 05 October 2015 06:56 Go to previous messageGo to next message
Hi Thomas,
I will make an example with a memory store and maybe add a file store. Give me a day or so.
gr. Martin
On 02-10-15 14:08, Thomas Driessen wrote:
> Any hint is appreciated :)
> Kind regards,
> Thomas
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [TEXO] Is it possible to use Texo without DB? [message #1710242 is a reply to message #1710204] Mon, 05 October 2015 09:38 Go to previous messageGo to next message
Hi Martin,
that sounds great. Thank you so much!
Kind regards,
Thomas
Re: [TEXO] Is it possible to use Texo without DB? [message #1710829 is a reply to message #1710242] Fri, 09 October 2015 10:58 Go to previous messageGo to next message
Hi Martin,
any update on the issue?
Kind regards,
Thomas
Re: [TEXO] Is it possible to use Texo without DB? [message #1710981 is a reply to message #1710829] Mon, 12 October 2015 02:50 Go to previous messageGo to next message
Hey Thomas,
I need a few days more, I am trying to add a file based objectstore in the same effort.
gr. Martin
On 09-10-15 16:58, Thomas Driessen wrote:
> Hi Martin,
> Kind regards,
> Thomas
The Netherlands
Re: [TEXO] Is it possible to use Texo without DB? [message #1711023 is a reply to message #1710981] Mon, 12 October 2015 09:03 Go to previous messageGo to next message
Hi Martin,
a file based object store sounds great Smile Thanks for your effort.
Kind regards,
Thomas
Re: [TEXO] Is it possible to use Texo without DB? [message #1712126 is a reply to message #1711023] Wed, 21 October 2015 08:37 Go to previous messageGo to next message
Hi Martin,
any updates on the issue? Smile
Kind regards,
Thomas
Re: [TEXO] Is it possible to use Texo without DB? [message #1715729 is a reply to message #1712126] Wed, 25 November 2015 09:08 Go to previous messageGo to next message
Hi Martin,
I've just reviewed my Todos and wanted to ask if there's any update on the issue yet?
Kind regards,
Thomas
Re: [TEXO] Is it possible to use Texo without DB? [message #1715797 is a reply to message #1715729] Thu, 26 November 2015 05:37 Go to previous messageGo to next message
Hi Thomas,
I was afraid that you would ping me on this one :-(.. got overloaded on other work. I will pick it up now, early next
week to be done.
The Texo build environment is being moved so also busy with that part.
gr. Martin
On 25-11-15 15:08, Thomas Driessen wrote:
> Hi Martin,
> Kind regards,
> Thomas
The Netherlands
Re: [TEXO] Is it possible to use Texo without DB? [message #1716630 is a reply to message #1715797] Sun, 06 December 2015 17:14 Go to previous messageGo to next message
Hi Thomas,
To give you an update on this. I finished the development. It was some work to get it right with json/xml transport and xml and xmi serialization and accompanying testcases.
It will be published tomorrow/monday and I will add some docs on it.
gr. Martin
Re: [TEXO] Is it possible to use Texo without DB? [message #1716882 is a reply to message #1716630] Tue, 08 December 2015 13:31 Go to previous messageGo to next message
New build has been published, see here for some docs:
https://wiki.eclipse.org/Texo/EMFResourceObjectStore
gr. Martin
Re: [TEXO] Is it possible to use Texo without DB? [message #1718503 is a reply to message #1716882] Fri, 25 December 2015 03:24 Go to previous message
Hi Martin,
thank you so much for your effort. I will have a closer look on it over the holidays.
Merry Christmas to you and thanks again Smile
Kind regards,
Thomas
Previous Topic:[Edapt] is bidirectional migration possible/planned/feasible?
Next Topic:[Texo] Mars
Current Time: Sun Jul 20 20:13:20 EDT 2025
Powered by FUDForum. Page generated in 0.08362 seconds
