Home » Eclipse Projects » GEF » connections with right angle bends
connections with right angle bends [message #171564] Mon, 14 March 2005 00:48 Go to next message
Hello everyone ,
I am sorry that i am posting second mail on same subject. But i didnt get
answer of it and i need it immediately , please help.
I want connection between two models to be done such way that ,
after selecting conn src and when it is released on target model ,
connection line should route itself into right angle bends to reach target.
( this i have done with manhattenrouter)
Also after this , when user moves any corner conn should again reform into
right angle bends , passing through corner that user has just moved.
( i am actually facing problem here. I searched API's of draw2d -
polylineConn , Manhatten , FanRouter , BendpointRouter etc. ,
but i need bendpoint with constraint that bends must be right angled. )
Or should i do manually by setting new x and y values to moved bendpoint.
-- mithun.
Re: connections with right angle bends [message #171690 is a reply to message #171564] Mon, 14 March 2005 12:41 Go to previous messageGo to next message
"mithun ruikar" <mithun.ruikar@gmail.com> wrote in message
news:d138j6$gdk$1@www.eclipse.org...
> Hello everyone ,
target.
The functionality is not currently supported in GEF. I believe we already
have a feature request open on that. You can open another one if you can't
find it. Maybe you can implement this and contribute it to GEF.
> -- mithun.
Re: connections with right angle bends [message #172557 is a reply to message #171690] Fri, 18 March 2005 22:11 Go to previous messageGo to next message
Hello ,
I have created rectilinear connection with bendpoint support.
I used bendPointEditPolicy and implemented , getCreate , getMove ,
getDelete bendPoint commands.
These methods returns Command , which executes to support my need , which
is connection with bendPoints , but only bends at right angle are allowed.
Now , my User can have any kind of well shaped connection with right angle
bends.
And I think this functionality should be made available to GEF asp , so
that everybody can make use of these standard looking connections.
Thank you.
-- mithun
>> Hello everyone ,
> target.
>> -- mithun.
Re: connections with right angle bends [message #172574 is a reply to message #172557] Sat, 19 March 2005 09:46 Go to previous messageGo to next message
Originally posted by: Lamont_Gilbert.rigidsoftware.com
Ahh wonderful. I was going to eventually get around to writing such a
bendpoint setup.
Would you mind sending a copy of those required classes? Trade you for
my 'Line" editPart set if your interested (though i need to tweak the
select-move a bit) :P
Thanks!
CL
mithun ruikar wrote:
> Hello ,
> which is connection with bendPoints , but only bends at right angle are
> allowed.
> angle bends.
> Thank you.
> -- mithun
>>> Hello everyone ,
>>> get
>> target.
>>> into
>> already
>> can't
>>> bendpoint.
>>> -- mithun.
Re: connections with right angle bends [message #172911 is a reply to message #172574] Tue, 22 March 2005 02:57 Go to previous messageGo to next message
Hello Gilbert,
I have made many new classes and also have had made change to some
existing classes of my project , to have this functionality.
I had started with shapes examples and updated it to support my need.
You will need Connection (Model) , ConnectionEditPart ,
BendPointEditPolicy
, my custom commands to handle move, create , delete of bendPoint request.
tell me which classes you have , so that i can know what exactly i should
send you.
Re: connections with right angle bends [message #172961 is a reply to message #172911] Tue, 22 March 2005 08:41 Go to previous messageGo to next message
I got them all. Im surprised though, I would have thought the only
thing required would be a new BendPointEditPolicy. but I guess that
policy is what is returning your move, create, and delete commands?
CL
> Hello Gilbert,
> BendPointEditPolicy
> should send you.
Re: connections with right angle bends [message #173081 is a reply to message #172911] Tue, 22 March 2005 13:54 Go to previous messageGo to next message
Mithun,
I'm glad to see that you've implemented this functionality and are willing
to contribute it to GEF. Would you be interested in providing a patch for
the logic example? You can either post it here or post it in a bug report.
news:33cf91dbae0db6864c463c4620df426c$1@www.eclipse.org...
> Hello Gilbert,
> BendPointEditPolicy
> send you.
Re: connections with right angle bends [message #173289 is a reply to message #173081] Wed, 23 March 2005 15:18 Go to previous messageGo to next message
Hello ,
Thanks for showing interest in my thing. I have it currently running for
my own project based on GEF. But like you mentioned , I am trying to add
it to logic example.
I will notify you after it is over.
Thank you.
Re: connections with right angle bends [message #173777 is a reply to message #173081] Mon, 28 March 2005 08:03 Go to previous messageGo to next message
Hello ,
I have added right angled line bends to Logic Example.
But i dont know how to send it on this group. Because i use (simple web
interface) to post my mails to group, and i think there is no way to send
attachments from here.
Can you please tell me where should i send it , and how ?
-- thank you.
Re: connections with right angle bends [message #173836 is a reply to message #173777] Mon, 28 March 2005 13:16 Go to previous messageGo to next message
You can open a new bug report, and post a patch on there. Thanks.
news:e3f3932929b861474bccbea0b66d3752$1@www.eclipse.org...
> Hello ,
> -- thank you.
Re: connections with right angle bends [message #174580 is a reply to message #173777] Wed, 30 March 2005 16:03 Go to previous messageGo to next message
Post your code here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=71498
> Hello ,
> -- thank you.
Re: connections with right angle bends [message #175616 is a reply to message #174580] Tue, 05 April 2005 13:07 Go to previous messageGo to next message
Hello ,
Did you receive my attachment i attached my code at the link you specified.
-- mithun.
Re: connections with right angle bends [message #175633 is a reply to message #175616] Tue, 05 April 2005 13:30 Go to previous messageGo to next message
Yes, Mithun. Thanks. I'll review the contribution when I get the chance
and will post the updated status on that bug report.
news:6e5570a9c9ed415707d1a76291f1e0ab$1@www.eclipse.org...
> Hello ,
specified.
> -- mithun.
Re: connections with right angle bends [message #178341 is a reply to message #175616] Tue, 19 April 2005 17:06 Go to previous message
Mithun, please check the bug report. And make sure you're getting notified
about changes to that bug report.
> Hello ,
specified.
> -- mithun.
Previous Topic:Article proposal: Aspects of the graph related layout with GEF
Next Topic:How could i customize a java editor with a pallete
Current Time: Sun Nov 09 11:23:05 EST 2025
Powered by FUDForum. Page generated in 0.06100 seconds
