Home » Eclipse Projects » EGit / JGit » How to do "git log --oneline --decorate" in JGit
How to do "git log --oneline --decorate" in JGit [message #1586413] Mon, 26 January 2015 16:15 Go to next message
Wanted to ask how to get the information returned by
with JGit?
Using Iterable<RevCommit> commits = git.log().call(); is obvious, but how to do what "--decorate" does?
Martin
Re: How to do "git log --oneline --decorate" in JGit [message #1587185 is a reply to message #1586413] Tue, 27 January 2015 02:32 Go to previous messageGo to next message
That's a functionality exposed by the pgm package. The org.eclipse.jgit.pgm.Log class exposes the "decorate" option. You can lookup there [1] how it is done.
[1] https://github.com/eclipse/jgit/blob/master/org.eclipse.jgit.pgm/src/org/eclipse/jgit/pgm/Log.java
Re: How to do "git log --oneline --decorate" in JGit [message #1588067 is a reply to message #1587185] Tue, 27 January 2015 13:35 Go to previous messageGo to next message
Thanks much!
It's something like:
    Map<AnyObjectId, Set<Ref>> allsRefs = git.getRepository().getAllRefsByPeeledObjectId();
    for (RevCommit commit : commits) {
      log.info("commit msg={}", commit.getShortMessage());
      Set<Ref> commitRefs = allsRefs.get(commit);
      if (commitRefs == null)
        continue;
      for (Ref ref : commitRefs) {
        String name = ref.getName();
        log.info("    rev={}", name);
Re: How to do "git log --oneline --decorate" in JGit [message #1715141 is a reply to message #1588067] Thu, 19 November 2015 09:54 Go to previous messageGo to next message
I have a similar question. How to call log with "--merges" option?
I have tried to extract such info from the answer above with no success.
Re: How to do "git log --oneline --decorate" in JGit [message #1715168 is a reply to message #1715141] Thu, 19 November 2015 13:14 Go to previous messageGo to next message
I have just managed to get the merge commits using the following method:
	 * Returns the commits returned by the <code>git log --merges</code> command call.
	 * Commits with 2 or more parents are considered merges, as says the 'git-log' mannual .
	 * @return
	public List<RevCommit> call() {
		ArrayList<RevCommit> commits = new ArrayList<RevCommit>();
		try {
			git = new Git(repository);
			Iterable<RevCommit> logs = git.log().all().call();
			for (RevCommit aCommit : logs) {
				count++;
				if (aCommit.getParentCount() >= 2) {
					commits.add(aCommit);
				}else continue;
		} catch (GitAPIException e) {
			// TODO treat GitAPIException
			e.printStackTrace();
		} catch (IOException e) {
		return commits;
Is there any better way to do it?
Re: How to do "git log --oneline --decorate" in JGit [message #1715201 is a reply to message #1715168] Fri, 20 November 2015 03:00 Go to previous messageGo to next message
That looks ok. You can skip the "count++" and "} else continue;" lines but other than that its ok. If you need more control you can directly use RevWalk. There we have a NoMerges Filter which does the opposite of what you want (report only non-merges). Writing a MergesFilter is very easy. Adding "setNoMerges()" and "setMerges()" to LogCommand would also be easy. You want to contribute?
Re: How to do "git log --oneline --decorate" in JGit [message #1715577 is a reply to message #1715201] Tue, 24 November 2015 07:50 Go to previous messageGo to next message
Thanks for the answer. And about your question...
Christian Halstrick wrote on Fri, 20 November 2015 03:00
What should I do? Unfortunately, I never contribute to OSS, maybe now it is a good opportunity to start. Smile
Re: How to do "git log --oneline --decorate" in JGit [message #1715595 is a reply to message #1715577] Tue, 24 November 2015 09:54 Go to previous messageGo to next message
The first contribution is the hardest. You should follow our https://wiki.eclipse.org/EGit/Contributor_Guide. You should have at least a green (no errors) jgit project in your workspace. Your work would probably mostly in LogCommand.java and in the addition of the new class MergesFilter as a sibling of NoMergesFilter.
Re: How to do "git log --oneline --decorate" in JGit [message #1729017 is a reply to message #1715595] Sat, 09 April 2016 10:45 Go to previous messageGo to next message
I finally took a time to implement the additions. I tried to follow the guide but Gerrit ended up by refusing my push.
After adding my ssh pub key to my account in Gerrit and commit my changes to my local 'origin/master' i tried to push with
git push ssh://username@git.eclipse.org:29418/jgit/jgit.git HEAD:origin/master
After added the server to my known hosts, I've got the following error message:
Counting objects: 12, done.
Delta compression using up to 4 threads.
Compressing objects: 100% (9/9), done.
Writing objects: 100% (12/12), 1.35 KiB | 0 bytes/s, done.
Total 12 (delta 8 ), reused 0 (delta 0)
remote: Resolving deltas: 100% (8/8)
remote: Processing changes: refs: 1, done
To ssh://username@git.eclipse.org:29418/jgit/jgit.git
! [remote rejected] HEAD -> origin/master (prohibited by Gerrit)
error: failed to push some refs to 'ssh://username@git.eclipse.org:29418/jgit/jgit.git'
What am I missing?
Re: How to do "git log --oneline --decorate" in JGit [message #1729094 is a reply to message #1729017] Mon, 11 April 2016 03:32 Go to previous messageGo to next message
See http://wiki.eclipse.org/EGit/Contributor_Guide#Using_Gerrit_with_git_command_line:
You have to use "git push ... HEAD:refs/for/master"
Re: How to do "git log --oneline --decorate" in JGit [message #1729276 is a reply to message #1729094] Tue, 12 April 2016 10:00 Go to previous messageGo to next message
What exactly "refs/for/master" means? I managed to found the find command and then I ran the following:
$ find .git/refs
and given the following answer:
.git/refs
.git/refs/heads
.git/refs/heads/master
.git/refs/remotes
.git/refs/remotes/origin
.git/refs/remotes/origin/HEAD
.git/refs/tags
i used the bold path and tried these 2 different pushes, as follows (one at a time)
$ git push ssh://username@git.eclipse.org:29418/jgit/jgit.git HEAD:refs/heads/master
$ git push ssh://username@git.eclipse.org:29418/jgit/jgit.git HEAD:heads/master
but the answer was the same:
remote: Branch refs/heads/master:
remote: You are not allowed to perform this operation.
remote: To push into this reference you need 'Push' rights.
remote: User: username
remote: Please read the documentation and contact an administrator
remote: if you feel the configuration is incorrect
! [remote rejected] HEAD -> master (prohibited by Gerrit)
Is not the public ssh key enough for authentication?
Re: How to do "git log --oneline --decorate" in JGit [message #1729279 is a reply to message #1729276] Tue, 12 April 2016 10:16 Go to previous messageGo to next message
have you tried "refs/for/master"? If you push to a gerrit server and you want that your push goes into the review queue for branch x , then you have to push to "refs/for/x". That's how gerrit detects that you want to push for review.
It doesn't help if you search with the find command for refs you have locally. When you push to a git server then what you specify to the right of the colon is a ref which is interpreted only by the server. So the server has to know the ref. And our git server knows how to handle refs/for/x.
Re: How to do "git log --oneline --decorate" in JGit [message #1729306 is a reply to message #1729279] Tue, 12 April 2016 14:19 Go to previous message
It worked for "refs/for/master". \o/
I was the whole time thinking that it was a "generic" reference to the mast Ref. It took also a bit longer because I had committed without the Change-Id than I got some errors, but i managed to solve than. Many thanks for the help.
Previous Topic:Lock Fail
Next Topic:Eclipse upgrade to 4.5.2
Current Time: Sat Sep 13 17:02:14 EDT 2025
Powered by FUDForum. Page generated in 0.05339 seconds
