Home » Eclipse Projects » e(fx)clipse » Application model variables not declared as modifiable(DeclareModifiable methods are not called in the application context for the application model variables)
Application model variables not declared as modifiable [message #1715248] Fri, 20 November 2015 09:18 Go to next message
Hello guys!
First of all, I'm new to the forum, but using your framework for a long time. Keep up the good work. Smile
Currently I'm using e(fx)clipse 2.0, and I experienced a weird issue. As the title and the description says, it looks like you do not set the variables from the Application Model to the Workbench Context.
For every other level of the context tree, you do this in the PartRenderingEngine's createContext method. When you create the context for the model, you populate the model interfaces into the context, declare the modifiable contextkeys from the model variables, and set the context properties key-value pairs.
Obviously the MApplication is not "rendered" in a common sense, and the context for it is not created by the PartRenderingEngine, so these things are don't happen here for the Application itself. The WorkbenchContext is created by the E4Application(AbstractE4Application)'s createApplicationContext and later the createE4Workbench method loads the Application Model. Here you just
// Set the app's context after adding itself
appContext.set(MApplication.class.getName(), appModel);
instead of populating all the model interfaces into the context, and seems that you completely forget about declaring the variables as modifiable.
You even have a initializeContext method in the E4Workbench, which might do something like this, but it is never called by the framework.
Am I missing something, or is this a real issue here?
It might be related, that it looks like you completely forget about the Context Properties for the Application Model. As an MContext, MApplication also has Properties, but for me it seems, that not only you do not handle it anywhere, it is not even showing in the Editor provided by your tooling.
Again, I'm still using 2.0, so these might have been fixed since, but looking at the your 2.1 fixed issue list, I was not able to find any relevant.
Thank you for your support in advance!
Re: Application model variables not declared as modifiable [message #1715425 is a reply to message #1715248] Mon, 23 November 2015 08:51 Go to previous messageGo to next message
Yes this is a bug and no it has not been fixed, because noone notice
that we are not doing this (i guess the same is true for e4 on SWT).
So please file a bug and we'll fix this for 2.2.0.
Tom
On 23.11.15 14:41, Attila Murvai wrote:
> Hello guys!
> time. Keep up the good work. :)
> just Quote:
> modifiable.
> by your tooling.
> relevant.
Re: Application model variables not declared as modifiable [message #1715526 is a reply to message #1715425] Tue, 24 November 2015 04:23 Go to previous messageGo to next message
thanks for your answer. My guess is also that it's wrong in the original SWT E4, because it does not really relate to the FX rendering (and you process these variables well in your FX rendering engine actually).
Where can I report this issue though? Can you give me a link?
And what about my other question regarding the E4 tooling and Context Properties? If the tooling is not your responsibility, can you direct me to the proper forum?
Thank you again for the support!
Re: Application model variables not declared as modifiable [message #1715530 is a reply to message #1715526] Tue, 24 November 2015 04:39 Go to previous message
For e(fx)clipse you file bugs at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Efxclipse
For the missing context properties in the tooling
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform&component=UI
Tom
On 24.11.15 10:23, Attila Murvai wrote:
Previous Topic:e(fx)clipse runtime works on JRE8 but not JRE7
Next Topic:javax.scene.media.Media does not understand protocol "bundleresource"
Current Time: Sun Jul 27 08:16:22 EDT 2025
Powered by FUDForum. Page generated in 0.05402 seconds
