[CDO] Client side ID generation [message #1715502] |
Tue, 24 November 2015 02:45  |
I am trying to use CLIENT side ID generation by setting
<property name="idGenerationLocation" value="CLIENT"/> <!-- Possible values: STORE | CLIENT -->
As a result the UUIDHandler is used to create ids for the objects. Now when I try to pre-register packages, ids are generated for the elements of these packages. As a result I get an exception:
java.lang.IllegalStateException: Suffix is too long: _FEhttp://www.eclipse.org/uml2/5.0.0/UML#//ActivityNode/inInterruptibleRegion
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.getName(AbstractMappingStrategy.java:445)
at org.eclipse.emf.cdo.server.internal.db.mapping.AbstractMappingStrategy.getTableName(AbstractMappingStrategy.java:399)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.BranchingListTableMappingWithRanges.initTable(BranchingListTableMappingWithRanges.java:131)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.BranchingListTableMappingWithRanges.<init>(BranchingListTableMappingWithRanges.java:125)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalBranchingMappingStrategyWithRanges.doCreateListMapping(HorizontalBranchingMappingStrategyWithRanges.java:77)
The relevant code
that causes this exception states:
if (name.length() > maxLength || forceNamesWithID)
suffix = NAME_SEPARATOR + suffix.replace('-', 'S');
int length = Math.min(name.length(), maxLength - suffix.length());
if (length < 0)
// Most likely CDOIDs are client side-assigned, i.e., meta IDs are extrefs. See getUniqueID()
throw new IllegalStateException("Suffix is too long: " + suffix);
name = name.substring(0, length) + suffix;
Which is true. But is there a workaround? The getUniquieId() method uses the MetaDataManger which itself uses the ID-Handler. The creation of the ID-Handler is hardcoded into DBStore. So it can not easily be replaced.
Thorsten
[Updated on: Tue, 24 November 2015 03:51] by Moderator
Re: [CDO] Client side ID generation [message #1715524 is a reply to message #1715502] |
Tue, 24 November 2015 04:15   |
Hi Thorsten,
I think the AbstractMappingStrategy.getUniqueID(ENamedElement) method was not written with client side assigned IDs. The
suffix should clearly not become arbitrarily long. Please submit a bugzilla. I have no conrete idea, yet, how to fix
this. I'll need to debug through the complicated naming strategies to fully understand the problem and our options, but
I won't have time this week.
Maybe you can play with the "maxFieldNameLength" property in the cdo-server.xml and see if you can work around the
problem. There are also some other properties that impact the computed table and field names:
http://download.eclipse.org/modeling/emf/cdo/drops/I20151120-0411/help/org.eclipse.emf.cdo.doc/html/operators/Doc01_ConfiguringRepositories.html#Element_mappingStrategy
Cheers
/Eike
http://www.esc-net.de
Am 24.11.2015 um 08:45 schrieb Thorsten Schlathölter:
> at
> at
> at
> at
> The relevant code
> if (length < 0)
> Regards,
> Thorsten
Re: [CDO] Client side ID generation [message #1758308 is a reply to message #1715524] |
Mon, 27 March 2017 10:24  |
Hi Eike,
I have same problem, but I'am using PostgreSQLAdapter which has MaxTableNameLength limitation (63) in CDO.
I have to use CLIENT side id generation, because i would like to use Repository synchronization ( and as i know it is a requirement for this).
Do you know any workaround? Or any bug is submitted about this issue?
Gergo
FUDForum. Page generated in 0.06611 seconds
