Error running Tutorial 2 / JavaFX Viewpart [message #1715015] |
Wed, 18 November 2015 08:47  |
I am running the tutorial2 from https://wiki.eclipse.org/Efxclipse/Tutorials/Tutorial2
Using JavaFx 2.0 Tooling (v2.1.0.201508)
with runtime vm arg:
-Xms256m -Xmx2024m -Dosgi.framework.extensions=org.eclipse.fx.osgi
But getting this following error.
!SESSION 2015-11-18 14:27:12.648 -----------------------------------------------
eclipse.buildId=4.5.0.I20150603-2000
java.version=1.8.0_45
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments: -product org.eclipse.sdk.ide
Command-line arguments: -product org.eclipse.sdk.ide -data /home/chakraborty/workspace/eclipsefx/../runtime-EclipseApplication -dev file:/home/chakraborty/workspace/eclipsefx/.metadata/.plugins/org.eclipse.pde.core/Eclipse Application/dev.properties -os linux -ws gtk -arch x86_64 -consoleLog
!ENTRY org.eclipse.equinox.ds 1 0 2015-11-18 14:27:23.318
!MESSAGE Could not bind a reference of component org.eclipse.fx.core.internal.JUtilLoggerFactory. The reference is: Reference[name = registerHandler, interface = java.util.logging.Handler, policy = dynamic, policy-option = greedy, cardinality = 0..n, target = null, bind = registerHandler, unbind = unregisterHandler, updated = null]
WARNING: You are binding against the deprecated org.eclipse.fx.javafx - please remove all javafx imports
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007f5e8f74d2b2, pid=5788, tid=140047738070784
# JRE version: Java(TM) SE Runtime Environment (8.0_45-b14) (build 1.8.0_45-b14)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.45-b02 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C [libgdk-x11-2.0.so.0+0x4e2b2] gdk_display_open+0x52
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /home/chakraborty/work/software/eclipseFX/hs_err_pid5788.log
# If you would like to submit a bug report, please visit:
# http://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Re: Error running Tutorial 2 / JavaFX Viewpart [message #1715023 is a reply to message #1715015] |
Wed, 18 November 2015 09:37   |
If I'd have to guess I think you'll run on GTK3 and because JavaFX is
linked to Gtk2 things crash.
Tom
> java.vendor=Oracle Corporation
> 1.8.0_45-b14)
FUDForum. Page generated in 0.03289 seconds
