Home » Newcomers » Newcomers » SQL error #1:Invalid object name 'T_TRIRIGATABLE.(SQL statement does not return a ResultSet object.)
SQL error #1:Invalid object name 'T_TRIRIGATABLE. [message #1715051] Wed, 18 November 2015 14:17 Go to next message
Hi All, We have upgraded from Version 2.6.2 to 4.4.2 on a IBM TRIRIGA Platform. The connection has been successful under Windows>Preference>IBM TRIRIGA BIRT Preferences and also, our data source tests for a successful connection. However, when I try to create a simple report with the query such as Select * from TABLE, and look at the output, I get the below error. PLEASE HELP with any suggestions:
org.eclipse.birt.data.engine.odaconsumer.OdaDataException: Cannot get the result set metadata.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet object.
SQL error #1:Invalid object name 'T_TRICOSTCODEINTERMEDIATE'.
java.sql.SQLException: Invalid object name 'T_TRICOSTCODEINTERMEDIATE'.
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.newException(ExceptionHandler.java:52)
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:108)
at org.eclipse.birt.data.engine.odaconsumer.ExceptionHandler.throwException(ExceptionHandler.java:84)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getRuntimeMetaData(PreparedStatement.java:414)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getProjectedColumns(PreparedStatement.java:377)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.doGetMetaData(PreparedStatement.java:347)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.execute(PreparedStatement.java:563)
at org.eclipse.birt.data.engine.executor.DataSourceQuery.execute(DataSourceQuery.java:970)
at org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQueryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:503)
at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(QueryExecutor.java:1222)
at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.executeQuery(ServiceForQueryResults.java:233)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultIterator(QueryResults.java:178)
at org.eclipse.birt.data.engine.impl.QueryResults.getResultMetaData(QueryResults.java:132)
at org.eclipse.birt.report.data.adapter.impl.DataSetMetaDataHelper.getRuntimeMetaData(DataSetMetaDataHelper.java:194)
at org.eclipse.birt.report.data.adapter.impl.DataSetMetaDataHelper.getRealMetaData(DataSetMetaDataHelper.java:153)
at org.eclipse.birt.report.data.adapter.impl.DataSetMetaDataHelper.getDataSetMetaData(DataSetMetaDataHelper.java:115)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.getDataSetMetaData(DataRequestSessionImpl.java:240)
at org.eclipse.birt.report.designer.data.ui.util.DataSetProvider.populateAllOutputColumns(DataSetProvider.java:221)
at org.eclipse.birt.report.designer.data.ui.dataset.OutputColumnsPage.populateOutputColums(OutputColumnsPage.java:417)
at org.eclipse.birt.report.designer.data.ui.dataset.OutputColumnsPage.updateOutputColumns(OutputColumnsPage.java:361)
at org.eclipse.birt.report.designer.data.ui.dataset.OutputColumnsPage.pageActivated(OutputColumnsPage.java:245)
at org.eclipse.birt.report.designer.data.ui.property.AbstractPropertyDialog.showPage(AbstractPropertyDialog.java:588)
at org.eclipse.birt.report.designer.data.ui.property.AbstractPropertyDialog.showSelectionPage(AbstractPropertyDialog.java:482)
at org.eclipse.birt.report.designer.data.ui.dataset.DataSetEditor.showSelectionPage(DataSetEditor.java:913)
at org.eclipse.birt.report.designer.data.ui.property.AbstractPropertyDialog$2$1.run(AbstractPropertyDialog.java:438)
at org.eclipse.birt.report.designer.data.ui.property.AbstractPropertyDialog$2.selectionChanged(AbstractPropertyDialog.java:433)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:163)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:50)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:178)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer.java:160)
at org.eclipse.jface.viewers.StructuredViewer.updateSelection(StructuredViewer.java:2171)
at org.eclipse.jface.viewers.StructuredViewer.handleSelect(StructuredViewer.java:1202)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected(StructuredViewer.java:1231)
at org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenStrategy.java:242)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.java:236)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:408)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4353)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1061)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4172)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:832)
at org.eclipse.jface.window.Window.open(Window.java:808)
at org.eclipse.birt.report.designer.ui.dialogs.BaseDialog.open(BaseDialog.java:111)
at org.eclipse.birt.report.designer.data.ui.providers.EditableDataSetNodeProvider.performEdit(EditableDataSetNodeProvider.java:102)
at org.eclipse.birt.report.designer.internal.ui.views.DefaultNodeProvider.performRequest(DefaultNodeProvider.java:472)
at org.eclipse.birt.report.designer.internal.ui.views.actions.EditAction.doAction(EditAction.java:85)
at org.eclipse.birt.report.designer.internal.ui.views.actions.AbstractElementAction.run(AbstractElementAction.java:70)
at org.eclipse.birt.report.designer.internal.ui.views.RenameListener.doubleClick(RenameListener.java:214)
at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:831)
at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:828)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSelect(AbstractTreeViewer.java:1472)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1237)
at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:252)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:249)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:311)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Caused by: org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet object.
at org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery(Statement.java:481)
at org.eclipse.birt.report.data.oda.jdbc.Statement.getMetaUsingDefaultPolicy(Statement.java:388)
at org.eclipse.birt.report.data.oda.jdbc.Statement.getMetaData(Statement.java:330)
at org.eclipse.birt.report.data.oda.jdbc.bidi.BidiStatement.getMetaData(BidiStatement.java:56)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.doGetMetaData(OdaQuery.java:423)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaQuery.getMetaData(OdaQuery.java:390)
at org.eclipse.birt.data.engine.odaconsumer.PreparedStatement.getRuntimeMetaData(PreparedStatement.java:407)
... 84 more
Caused by: java.sql.SQLException: Invalid object name 'T_TRICOSTCODEINTERMEDIATE'.
at net.sourceforge.jtds.jdbc.SQLDiagnostic.addDiagnostic(SQLDiagnostic.java:372)
at net.sourceforge.jtds.jdbc.TdsCore.tdsErrorToken(TdsCore.java:2894)
at net.sourceforge.jtds.jdbc.TdsCore.nextToken(TdsCore.java:2334)
at net.sourceforge.jtds.jdbc.TdsCore.getMoreResults(TdsCore.java:643)
at net.sourceforge.jtds.jdbc.JtdsStatement.executeSQLQuery(JtdsStatement.java:506)
at net.sourceforge.jtds.jdbc.JtdsPreparedStatement.executeQuery(JtdsPreparedStatement.java:979)
at org.eclipse.birt.report.data.oda.jdbc.Statement.executeQuery(Statement.java:477)
... 90 more
Re: SQL error #1:Invalid object name 'T_TRIRIGATABLE. [message #1715057 is a reply to message #1715051] Wed, 18 November 2015 16:38 Go to previous messageGo to next message
(There's a separate Eclipse BIRT forum.)
Re: SQL error #1:Invalid object name 'T_TRIRIGATABLE. [message #1715058 is a reply to message #1715057] Wed, 18 November 2015 16:52 Go to previous messageGo to next message
I apologize, which forum should I post this in?
Again, my apologies.
Re: SQL error #1:Invalid object name 'T_TRIRIGATABLE. [message #1715061 is a reply to message #1715058] Wed, 18 November 2015 17:33 Go to previous message
Sorry, yes, in the Eclipse BIRT forum. It's under Eclipse Projects at
eclipse.org.
Previous Topic:Error code 143
Next Topic:Eclipse Sandboxed // Green border?
Current Time: Thu May 08 04:49:34 EDT 2025
Powered by FUDForum. Page generated in 0.11273 seconds
