Home » Modeling » Papyrus » How to extend OCL standard library in Papyrus
How to extend OCL standard library in Papyrus [message #1714685] |
Sun, 15 November 2015 15:07  |
Hello.
I want to add some functions (just prototype) in oclAny such that Papyrus OCL editor should not give any syntax error while typing that customized functions. I have nothing to do with OCL validation. My only concern is syntax support in Papyrus editor for few new operations with header definition in standard OCL library (oclAny). My question is two fold: 1) What is the simplest way to achieve this ? 2) I know it is possible to customize standard OCL library through Xtext editor (CompleteOCL) but how to use such OCL std. lib extension to support the syntax of new functions in papyrus OCL editor ?
I have good Java programming background but new to OCL and Papyrus. Therefore, i need the valuable suggestions of domain experts to select the right path.
Re: How to extend OCL standard library in Papyrus [message #1714946 is a reply to message #1714853] |
Tue, 17 November 2015 15:08   |
Dear Ed Willink
Thanks for your early response. I think it is necessary to first describe my requirements. First of all, i am working to develop a complete MDA platform for embedded systems that includes: 1) Modeling tool 2) Transformation Engine and 3) Simulation. In my modeling approach, i have proposed few new functions in OCL standard library (OCLAny) so that end-user should be able to write constraints in UML / SYSML models through my proposed OCL extension. For OCL extension, i have used Xtext editor to customize standard OCL library. Now come to the first step i.e. Modeling tool. I have to include modeling tool in my framework so that end-user should be able to model requirements. I have selected Papyrus because it is open source and can be customized as per requirements. I cannot select other modeling tools like magic draw, RSA etc. due to their proprietary licenses. Furthermore, I cannot use GMT to develop my own modeling tool because it is very time-consuming. Consequently, i have selected Papyrus as a best choice and customize it for my framework. At the moment, papyrus is working fine in my framework to provide modeling facilities in UML and SYSML profiles. However, when it comes to write constraints through my proposed OCL extension, Papyrus OCL editor give syntax error because it cannot recognize my extended OCL functions. I just want to resolve syntax error issue for my new OCL functions because i do not need any OCL validation features. At this stage, I already done a lot of work on papyrus. I just want to know how to load complete OCL document in Papyrus such that my customized OCL functions should be recognize by Papyrus OCL editor (just syntax). As my only concern is syntax support, Is there any other way (may be without loading completeOCL) in papyrus to achieve that ? I don't want to ask end-users to write OCL constraints in separate file because it will increase complexity. I hope now you can understand the exact situation that why i am stick with papyrus and why i am only interested in syntax support for my customized OCL functions.
looking for your reply
regards
Re: How to extend OCL standard library in Papyrus [message #1714999 is a reply to message #1714946] |
Wed, 18 November 2015 06:46   |
<html>
<head>
<meta content="text/html; charset=utf-8" http-equiv="Content-Type">
</head>
<div class="moz-cite-prefix">Hi<br>
<br>
Since you are leveraging Ecipse to provide your modeling tool, you
should offset the many savings that you get from re-use from some
costs through contributing back enhancements. You cannot expect to
get everything included added functionality for free.<br>
<br>
I provided you with three solutions that I might work on one day.
If you want solutions sooner, you need to contribute. All the
underlying functionality is there, it's just the inadequate
'import' that is a blocker.<br>
<br>
With regards to not imposing an extra file on your users, that is
misguided. If the users want 10 lines of OCL, fine embed it in the
UML. If the users want 1000 lines of OCL then an extra file is a
much much better solution. Both approaches should work.<br>
<br>
Regards<br>
<br>
Ed Willink<br>
<br>
<br>
On 17/11/2015 20:08, waseem anwar wrote:<br>
</div>
<blockquote cite="mid:n2g1gj$ju6$1@xxxxxxxxe.org" type="cite">Dear
Ed Willink
<br>
<br>
looking for your reply <br>
regards </blockquote>
<br>
</body>
</html>
Re: How to extend OCL standard library in Papyrus [message #1715279 is a reply to message #1714999] |
Fri, 20 November 2015 15:48  |
Dear Letavernier and Willink
I am thankful to both of you for your valuable comments. First of all, I am agree with Camille Letavernier that this is one possible solution but it is lengthy solution as i just need few customized functions in OCL. However, this solution is in my mind if I will not find any other simple solution.
For Ed Willink Comments, I just want to clear one thing that is I am not developing anything commercial by using all open source software's. In fact, our framework will also be open source and freely available for relevant students, researchers and practitioners. Currently, we are in scientific publications phase and we will provide the link of our framework soon.
So far, I have removed some additional features of papyrus to meet the particular requirement of my framework. Whenever, i add any new feature in papyrus or any other corresponding eclipse plugin, i will definitely share the details with you. In addition, I never expect all things for free without contributing. For example, I have developed my own transformation engine with a lot of efforts though i have used all open source M2M and M2T tools. Further, my frame work will also be freely available (open source).
Finally, I want to say that I have post my query here just to get the simplest and quick solution of my issue to save my time because all senior members of this forum are experts of the domain and very helpful. In fact, the provided comments are very valuable for me to find the solution of my problem.
regards
Current Time: Thu Jul 24 23:44:46 EDT 2025
Powered by FUDForum. Page generated in 0.07628 seconds
