[Zest] Layout implementations and node overlapping [message #1714742] |
Mon, 16 November 2015 05:50  |
Hey Folks.
My aim is to use several different graph layouts on a planar graph. And maybe you can help me to find a good layout or two. The layouts should satisfy following criteria:
• No node overlapping
• No edge crossing
• Optimal use of the canvas space.
• Minimal space between nodes.
Currently I've investigated these layouts: BoxLayout, GridLayout, TreeLayout, SpringLayout, SugiyamaLayout (Not working at all), RadialLayout, SpaceTreeLayout(also not working)
With following results:
BoxLayout
• Node overlapping
• Edge crossing
• Nodes are drawn over each other in a vertical orientation
GridLayout:
• Node overlapping
• Edge crossing
• Nodes are randomly drawn in a grid based style.
TreeLayout:
• No Node overlapping
• Kind of less Edge crossing
• The nodes are separated into Subtrees which will be orientated vertically on the canvas. Node space is kind of minimal, but since the tree is oriented only vertical the complete space of the canvas is not used properly.
SpringLayout
• Node overlapping
• Edge crossing
• Nodes are randomly drawn on the canvas. And tied together by using a force related layout. The canvas space is used properly but several node overlappings and crossings.
SugiyamaLayout
RadialLayout
• Node overlapping
• less Edge crossing
• Canvas space is used properly
SpaceTreeLayout
I've also tryed Graphvis to layout the graph.
It is doing a nice job, but I don't like the static implementation.
Layout wise I really like the implementation of yWork's yED. But I can not afford a license. If some of you know which implementations they are using, I would appreciate it. They seem well rounded and well organized.
Maybe there is an other layout library out there which you can recommend and which could be used while using zest for representation.
Attachment: box.PNG
(Size: 10.67KB, Downloaded 2182 times)
Attachment: Grid.PNG
(Size: 127.85KB, Downloaded 2364 times)
Attachment: radial.PNG
(Size: 99.94KB, Downloaded 2565 times)
Attachment: spring.PNG
(Size: 104.84KB, Downloaded 2318 times)
Attachment: tree.PNG
(Size: 18.86KB, Downloaded 2065 times)
[Updated on: Mon, 16 November 2015 07:10] by Moderator
FUDForum. Page generated in 0.06141 seconds
