Home » Modeling » GMF (Graphical Modeling Framework) » Problem with interpretation of XML representation of diagram layout(how to use the attributes (bendpoints/points, targetAnchor/id, targetAnchor/id) to redraw the connections)
Problem with interpretation of XML representation of diagram layout [message #1714759] Mon, 16 November 2015 07:53 Go to next message
hey everbody,
after i draw a diagram with my own generated GMF-Editor (see Attachement1), i need to redraw it in another GUI. For that i'm using the XML file of the diagram, and i don't know how to use the XML information to redraw a connection in a right way.
Does anyone know how i can use the three values under the nodes "Edges":
1. bendpoints/points
2. sourceAnchor/id
3. targetAnchor/id
to draw a connection (or get the real bendpoints of a connection).
when i only use the attribute bendpoints/points, i get this (see Attatchment2) and as we see, most of the connections are not on the right place.
and i realized that the attributes sourceAnchor/id and targetAnchor/id are missing at some "edges" nodes (see attached XML file).
please, i really need help, any comment could be helpful.
thanks in advance ..
Nana
index.php/fa/23961/0/
index.php/fa/23962/0/
  • Attachment: Attachment1.png
    (Size: 15.31KB, Downloaded 586 times)
  • Attachment: Attachment2.png
    (Size: 16.20KB, Downloaded 591 times)
  • Attachment: XML.xml
    (Size: 13.18KB, Downloaded 241 times)
Re: Problem with interpretation of XML representation of diagram layout [message #1715019 is a reply to message #1714759] Wed, 18 November 2015 09:19 Go to previous messageGo to next message
anyone there who could help please :'(
Re: Problem with interpretation of XML representation of diagram layout [message #1718728 is a reply to message #1715019] Tue, 29 December 2015 08:51 Go to previous messageGo to next message
Hi, did you solve the problem?
I'm in the same situation. I'd like to get coordinates from bendpoints in a (x,y) way. How do you translate from bendpoints to coordinates?
Re: Problem with interpretation of XML representation of diagram layout [message #1719003 is a reply to message #1718728] Mon, 04 January 2016 06:59 Go to previous message
Hey, i did not solve the problem.
this problem is related to GMF, the values in the xml file are not correct.
Wlc
Previous Topic:GMF integrating with MultiPageEditorPart?
Next Topic:Did anyone met crash issue with SVG? How to solve?
Current Time: Sun Jul 20 20:43:18 EDT 2025
Powered by FUDForum. Page generated in 0.03516 seconds
