Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EMFForms] Dependency Injection fails on render of view
[EMFForms] Dependency Injection fails on render of view [message #1711400] |
Thu, 15 October 2015 11:21  |
Hi there,
since eclipse mars.1 emfforms tooling does not allow to edit 1.5.1 view models anymore and migrated view models don't work with 1.5.1, i though it's a good idea finally update to 1.7.1.
Now i'm facing an injectionException
org.eclipse.e4.core.di.InjectionException: Could not find satisfiable constructor in org.eclipse.emf.ecp.view.internal.core.swt.renderer.ViewSWTRenderer
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:354)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:264)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.emfforms.spi.swt.core.di.EMFFormsDIRendererFactory.getRendererInstance(EMFFormsDIRendererFactory.java:156)
at org.eclipse.emfforms.internal.swt.core.EMFFormsRendererFactoryImpl.getRendererInstance(EMFFormsRendererFactoryImpl.java:102)
at org.eclipse.emf.ecp.view.internal.swt.ECPSWTViewRendererImpl.render(ECPSWTViewRendererImpl.java:91)
Any ideas on how to proceed?
Thanks in advance
Philippe
Re: [EMFForms] Dependency Injection fails on render of view [message #1711412 is a reply to message #1711400] |
Thu, 15 October 2015 13:31   |
As a side note, I haven't been using di before. Is EMFForms 1.7.1 suppose to work with Rap?
These di related mesages are also showing up:
!ENTRY org.eclipse.equinox.ds 1 0 2015-10-15 19:25:27.014
!MESSAGE Could not bind a reference of component EMFFormsViewService. The reference is: Reference[name = Provider, interface = org.eclipse.emf.ecp.view.spi.provider.IViewProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addProvider, unbind = removeProvider]
!ENTRY org.eclipse.equinox.ds 1 0 2015-10-15 19:25:27.127
!MESSAGE Could not bind a reference of component org.eclipse.emfforms.swt.core.rendererfactory. The reference is: Reference[name = EMFFormsAdditionalRendererService, interface = org.eclipse.emfforms.spi.swt.core.EMFFormsAdditionalRendererService, policy = dynamic, cardinality = 0..n, target = null, bind = addEMFFormsAdditionalRendererService, unbind = removeEMFFormsAdditionalRendererService]
Re: [EMFForms] Dependency Injection fails on render of view [message #1711446 is a reply to message #1711412] |
Fri, 16 October 2015 04:04   |
we use DI internally to instanciate the renderers. Reason is that
renderers, espcially custom ones have a very divers set of parameters
they require, that is why we switched to DI here to simplify things.
Please see here for more details:
http://eclipsesource.com/blogs/tutorials/how-to-customize-emf-forms/#customizecontrols
In your case, it seems a required service is missing. Do you maintain a
feature based run config? Otherwise I think you are missing new bundles,
org.eclipse.emfforms.swt.core seems one of them.
We strongly recommend to use feature-based product and run configs, we
update our features if there are new bundles...
Best regards
Jonas
Am 15.10.2015 um 19:31 schrieb Phil Wim:
> removeProvider]
Jonas Helming
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: [EMFForms] Dependency Injection fails on render of view [message #1714407 is a reply to message #1711566] |
Thu, 12 November 2015 07:57   |
I'm new to EMF Forms and I'm trying to integrate it into an existing RCP Application. I'm facing the same errors as decribed above:
!ENTRY org.eclipse.equinox.ds 4 0 2015-11-12 13:38:17.129
ERROR 165 Could not bind a reference of component EMFFormsViewService. The reference is: Reference[name = Provider, interface = org.eclipse.emf.ecp.view.spi.provider.IViewProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addProvider, unbind = removeProvider]
!ENTRY org.eclipse.equinox.ds 4 0 2015-11-12 13:38:17.130
!ENTRY org.eclipse.emf.ecp.view.model 4 0 2015-11-12 13:38:21.966
!MESSAGE
!STACK 0
at org.eclipse.emf.ecp.view.internal.swt.ECPSWTViewRendererImpl.render(ECPSWTViewRendererImpl.java:78)
at org.eclipse.emf.ecp.view.internal.swt.ECPSWTViewRendererImpl.render(ECPSWTViewRendererImpl.java:65)
Since I'm integrating in an existing RCP I can't switch my launch configuration to "feature based". Below I have listed the bundles that i added for EMF Forms:
workspace {
"org.eclipse.emf.ecp.makeithappen.model.edit"
"org.eclipse.emf.ecp.makeithappen.model"
target {
"org.eclipse.emfforms.common"
"org.eclipse.emfforms.core.services"
"org.eclipse.emfforms.core.services.editsupport"
"org.eclipse.emfforms.core.services.emfspecificservice"
"org.eclipse.emfforms.localization"
"org.eclipse.emf.ecp.ui.view.swt"
"org.eclipse.emf.ecp.ui.view.swt.di"
"org.eclipse.emfforms.swt.core"
"org.eclipse.emfforms.swt.core.di"
"org.eclipse.e4.core.contexts"
"org.eclipse.e4.core.di"
"org.eclipse.e4.core.di.annotations"
"org.eclipse.emf.ecp.core"
"org.eclipse.emf.ecp.ui"
"org.eclipse.emf.ecp.ui.view"
"org.eclipse.emf.ecp.view"
"org.eclipse.emf.ecp.view.validation"
"org.eclipse.emf.ecp.view.util.swt"
"org.eclipse.emfforms.swt.core.plugin"
"org.eclipse.emf.ecp.view.model"
"org.eclipse.emf.ecp.view.model.common"
"org.eclipse.emf.ecp.view.context"
"org.eclipse.emf.ecp.view.core.swt"
"org.eclipse.emf.ecp.view.template.model"
"org.eclipse.emf.ecp.view.migrator"
"org.eclipse.emf.ecp.view.model.provider.xmi"
"org.eclipse.emf.ecp.view.model.provider.generator"
"org.eclipse.emf.ecp.view.custom.model"
"org.eclipse.emf.ecp.view.label.model"
"org.eclipse.emf.ecp.view.rule.model"
"org.eclipse.emf.ecp.view.stack.model"
"org.eclipse.emf.ecp.view.table.model"
"org.eclipse.emf.ecp.view.treemasterdetail.model"
"org.eclipse.emf.ecp.view.treemasterdetail.ui.swt"
"org.eclipse.emf.ecp.workspace.core"
"org.eclipse.emfforms.core.services.emf"
"org.eclipse.emf.ecp.ide.view.service"
"org.eclipse.core.resources"
"org.eclipse.emf.ecp.ui.view.editor.controls"
"org.eclipse.emfforms.core.services.locale.default"
"org.eclipse.emf.ecp.ide.util"
"org.eclipse.emf.ecore.edit"
"org.eclipse.net4j.util"
"org.eclipse.emf.ecp.view.template.service"
"org.eclipse.emf.ecp.common"
"org.eclipse.emf.ecp.common.ui"
"org.eclipse.emf.ecp.edit"
"org.eclipse.emf.ecp.edit.swt"
"org.eclipse.emf.edit"
"org.eclipse.emf.edit.ui"
"org.eclipse.emf.common"
"org.eclipse.emf.common.ui"
"org.eclipse.emf.ecore"
"org.eclipse.emf.ecore.xmi"
"org.eclipse.emf.databinding"
"org.eclipse.emf.databinding.edit"
"org.eclipse.ui.views"
Besides that the RCP is based on Eclipse Juno (3.8.2). I needed to add some bundles from Mars to satisfy some dependencies (namely: org.eclipse.net4j.sdk.feature.group, org.eclipse.e4.core.contexts, org.eclipse.e4.core.di, org.eclipse.e4.core.di.annotations, org.eclipse.core.databinding.property).
I would appreciate any help on getting this run on Eclipse 3.
Thanks!
Greets, Peter
Re: [EMFForms] Dependency Injection fails on render of view [message #1714561 is a reply to message #1714526] |
Fri, 13 November 2015 10:03   |
Hi Eugen,
both of these Objects are not Null. See Screenshot below
childContext.localValues has the following content:
{org.eclipse.emf.ecp.view.spi.model.VElement=org.eclipse.emf.ecp.view.spi.model.impl.VViewImpl@b4ca64 (name: null, label: , visible: true, enabled: true, readonly: false) (ecorePath: null), org.eclipse.emf.ecp.view.spi.context.ViewModelContext=org.eclipse.emf.ecp.view.internal.context.ViewModelContextImpl@ae9d8d, org.eclipse.emf.ecp.view.spi.model.VView=org.eclipse.emf.ecp.view.spi.model.impl.VViewImpl@b4ca64 (name: null, label: , visible: true, enabled: true, readonly: false) (ecorePath: null), parentContext=OSGi context for bundle: org.eclipse.emfforms.swt.core.di}
Thanks for helping out!
Greets, Peter
Re: [EMFForms] Dependency Injection fails on render of view [message #1714709 is a reply to message #1714585] |
Mon, 16 November 2015 02:36   |
Thanks for your answer.
But it seems like all services are registered:
osgi> services (objectclass=org.eclipse.emfforms.spi.common.report.ReportService)
{org.eclipse.emfforms.spi.common.report.ReportService}={component.name=org.eclipse.emfforms.internal.common.report.ReportServiceImpl, component.id=44, service.id=80}
"Registered by bundle:" org.eclipse.emfforms.common_1.7.1.20150923-2258 [150]
"No bundles using service."
osgi> services (objectclass=org.eclipse.emfforms.spi.swt.core.EMFFormsRendererFactory)
{org.eclipse.emfforms.spi.swt.core.EMFFormsRendererFactory}={component.name=org.eclipse.emfforms.swt.core.rendererfactory, component.id=53, service.id=96}
"Registered by bundle:" org.eclipse.emfforms.swt.core_1.7.1.20150923-2258 [158]
osgi> services (objectclass=org.eclipse.emfforms.spi.core.services.databinding.EMFFormsDatabinding)
{org.eclipse.emfforms.spi.core.services.databinding.EMFFormsDatabinding, org.eclipse.emfforms.spi.core.services.databinding.emf.EMFFormsDatabindingEMF}={component.name=EMFFormsDatabinding, component.id=49, service.id=83}
"Registered by bundle:" org.eclipse.emfforms.core.services.emf_1.7.1.20150923-2258 [154]
osgi> services (objectclass=org.eclipse.emfforms.spi.common.locale.EMFFormsLocaleProvider)
{org.eclipse.emfforms.spi.common.locale.EMFFormsLocaleProvider}={component.name=org.eclipse.emfforms.localization.default, component.id=51, service.id=93}
"Registered by bundle:" org.eclipse.emfforms.core.services.locale.default_1.7.1.20150923-2258 [156]
From the debug output of my previous code, I think that not all services are in the provided context. And the services are not being bound: "No bundles using service"
Maybe a problem caused by not running on Eclipse 4? (but on the other hand "some" Objects are in the context ....)
Any Hint on where to go on?
Thank you very much for your help!
Greets, Peter
additional debug output:
osgi> ss
"Framework is launched."
id State Bundle
0 ACTIVE org.eclipse.osgi_3.8.2.v20130124-134944
Fragments=213
1 ACTIVE org.eclipse.equinox.simpleconfigurator_1.0.301.v20120914-163612
Fragments=203
2 STARTING ag.ion.bion.workbench.office.editor.core_2.0.14
3 ACTIVE ag.ion.noa_3.1.2.qualifier
Fragments=4
4 RESOLVED ag.ion.noa.patch_4.2.1549.qualifier
Master=3
5 STARTING ag.ion.noa4e.ui_2.0.14
Fragments=6
6 RESOLVED ag.ion.noa4e.ui.nl1_2.0.14
Master=5
7 RESOLVED ch.qos.logback.classic_1.0.11
Fragments=30, 31
8 RESOLVED ch.qos.logback.core_1.0.11
9 RESOLVED com.eclipsesource.jaxrs.jersey-all_2.10.1.SR1
<SNIP Application bundles/>
48 RESOLVED com.google.gson_2.2.4
49 STARTING com.ibm.icu_4.4.2.v20110823
50 RESOLVED javax.mail_1.4.5
51 RESOLVED jcl.over.slf4j_1.7.5
52 RESOLVED jul.to.slf4j_1.7.5
53 RESOLVED org.apache.commons.codec_1.6.0.v201305230611
54 RESOLVED org.apache.commons.codec_1.3.0.v201101211617
55 RESOLVED org.apache.commons.email_1.2.0
56 RESOLVED org.apache.commons.httpclient_3.1.0.v201012070820
57 RESOLVED org.apache.commons.io_2.0.1.v201105210651
58 RESOLVED org.apache.commons.lang_2.4.0.v201005080502
59 RESOLVED org.apache.commons.lang3_3.1.0
60 ACTIVE org.apache.felix.gogo.command_0.8.0.v201108120515
61 ACTIVE org.apache.felix.gogo.runtime_0.8.0.v201108120515
62 ACTIVE org.apache.felix.gogo.shell_0.8.0.v201110170705
63 RESOLVED org.eclipse.core.commands_3.6.1.v20120912-135020
Fragments=64
64 RESOLVED org.eclipse.core.commands.nl_de_3.7.0.v20130724081219
Master=63
65 ACTIVE org.eclipse.core.contenttype_3.4.200.v20120523-2004
Fragments=66
66 RESOLVED org.eclipse.core.contenttype.nl_de_3.7.0.v20130724081219
Master=65
67 STARTING org.eclipse.core.databinding_1.4.1.v20120912-135020
Fragments=68
68 RESOLVED org.eclipse.core.databinding.nl_de_3.7.0.v20130724081219
Master=67
69 ACTIVE org.eclipse.core.databinding.observable_1.4.1.v20120521-2332
Fragments=70
70 RESOLVED org.eclipse.core.databinding.observable.nl_de_3.7.0.v20130724081219
Master=69
71 STARTING org.eclipse.core.databinding.property_1.5.0.v20150422-0725
Fragments=72
72 RESOLVED org.eclipse.core.databinding.property.nl_de_3.7.0.v20130724081219
Master=71
73 ACTIVE org.eclipse.core.expressions_3.4.400.v20120523-2004
Fragments=74
74 RESOLVED org.eclipse.core.expressions.nl_de_3.7.0.v20130724081219
Master=73
75 STARTING org.eclipse.core.filesystem_1.3.200.v20130115-145044
Fragments=76
76 RESOLVED org.eclipse.core.filesystem.nl_de_3.7.0.v20130724081219
Master=75
77 ACTIVE org.eclipse.core.jobs_3.5.200.v20120521-2346
Fragments=78
78 RESOLVED org.eclipse.core.jobs.nl_de_3.7.0.v20130724081219
Master=77
79 STARTING org.eclipse.core.net_1.2.200.v20120914-093638
Fragments=80
80 RESOLVED org.eclipse.core.net.nl_de_3.7.0.v20130724081219
Master=79
81 STARTING org.eclipse.core.resources_3.8.1.v20121114-124432
82 ACTIVE org.eclipse.core.runtime_3.8.0.v20120521-2346
Fragments=86
83 STARTING org.eclipse.core.runtime.compatibility.auth_3.2.300.v20120523-2004
Fragments=84
84 RESOLVED org.eclipse.core.runtime.compatibility.auth.nl_de_3.7.0.v20130724081219
Master=83
85 RESOLVED org.eclipse.core.runtime.compatibility.registry_3.5.100.v20120521-2346
Master=199
86 RESOLVED org.eclipse.core.runtime.nl_de_3.7.0.v20130724081219
Master=82
87 STARTING org.eclipse.e4.core.contexts_1.4.0.v20150828-0818
88 STARTING org.eclipse.e4.core.di_1.5.0.v20150421-2214
89 RESOLVED org.eclipse.e4.core.di.annotations_1.4.0.v20150528-1451
90 ACTIVE org.eclipse.ecf_3.4.0.v20150306-2024
Fragments=97
91 STARTING org.eclipse.ecf.console_1.0.0.v20150306-2024
92 ACTIVE org.eclipse.ecf.discovery_5.0.0.v20150306-2024
93 ACTIVE org.eclipse.ecf.filetransfer_5.0.0.v20150306-2024
Fragments=94
94 RESOLVED org.eclipse.ecf.filetransfer.nl_de_3.7.0.v20130724081219
Master=93
95 ACTIVE org.eclipse.ecf.identity_3.4.0.v20150306-2024
Fragments=96
96 RESOLVED org.eclipse.ecf.identity.nl_de_3.7.0.v20130724081219
Master=95
97 RESOLVED org.eclipse.ecf.nl_de_3.7.0.v20130724081219
Master=90
98 ACTIVE org.eclipse.ecf.osgi.services.distribution_2.1.0.v20150306-2024
99 ACTIVE org.eclipse.ecf.osgi.services.remoteserviceadmin_4.2.0.v20150306-2024
100 ACTIVE org.eclipse.ecf.osgi.services.remoteserviceadmin.proxy_1.0.0.v20150306-2024
101 ACTIVE org.eclipse.ecf.provider_4.5.0.v20150306-2024
102 ACTIVE org.eclipse.ecf.provider.filetransfer_3.2.200.v20150306-2024
Fragments=104
103 ACTIVE org.eclipse.ecf.provider.filetransfer.httpclient_4.0.200.v20120610-1946
104 RESOLVED org.eclipse.ecf.provider.filetransfer.nl_de_3.7.0.v20130724081219
Master=102
105 ACTIVE org.eclipse.ecf.provider.remoteservice_4.1.0.v20150306-2024
106 ACTIVE org.eclipse.ecf.remoteservice_8.5.0.v20150306-2024
107 ACTIVE org.eclipse.ecf.remoteservice.asyncproxy_1.0.0.v20140410-1838
108 ACTIVE org.eclipse.ecf.sharedobject_2.5.0.v20150306-2024
109 STARTING org.eclipse.emf.common_2.11.0.v20150512-0501
110 STARTING org.eclipse.emf.common.ui_2.10.0.v20150601-0402
111 STARTING org.eclipse.emf.databinding_1.3.0.v20150601-0402
112 STARTING org.eclipse.emf.databinding.edit_1.3.0.v20150601-0402
113 STARTING org.eclipse.emf.ecore_2.11.0.v20150512-0501
114 STARTING org.eclipse.emf.ecore.edit_2.9.0.v20150601-0402
115 STARTING org.eclipse.emf.ecore.xmi_2.11.0.v20150512-0501
116 STARTING org.eclipse.emf.ecp.common_1.7.1.20150923-2258
117 STARTING org.eclipse.emf.ecp.common.ui_1.7.1.20150923-2258
118 STARTING org.eclipse.emf.ecp.core_1.7.1.20150923-2258
119 STARTING org.eclipse.emf.ecp.edit_1.7.1.20150923-2258
120 STARTING org.eclipse.emf.ecp.edit.swt_1.7.1.20150923-2258
121 STARTING org.eclipse.emf.ecp.ide.util_1.7.1.20150923-2258
122 STARTING org.eclipse.emf.ecp.ide.view.service_1.7.1.20150923-2258
123 STARTING org.eclipse.emf.ecp.makeithappen.model_1.6.1.qualifier
124 STARTING org.eclipse.emf.ecp.makeithappen.model.edit_1.6.1.qualifier
125 STARTING org.eclipse.emf.ecp.ui_1.7.1.20150923-2258
126 STARTING org.eclipse.emf.ecp.ui.view_1.7.1.20150923-2258
127 STARTING org.eclipse.emf.ecp.ui.view.editor.controls_1.7.1.20150923-2258
128 STARTING org.eclipse.emf.ecp.ui.view.swt_1.7.1.20150923-2258
129 STARTING org.eclipse.emf.ecp.view.context_1.7.1.20150923-2258
130 STARTING org.eclipse.emf.ecp.view.core.swt_1.7.1.20150923-2258
131 STARTING org.eclipse.emf.ecp.view.custom.model_1.7.1.20150923-2258
132 STARTING org.eclipse.emf.ecp.view.label.model_1.7.1.20150923-2258
133 RESOLVED org.eclipse.emf.ecp.view.migrator_1.7.1.20150923-2258
134 STARTING org.eclipse.emf.ecp.view.model_1.7.1.20150923-2258
135 STARTING org.eclipse.emf.ecp.view.model.common_1.7.1.20150923-2258
136 STARTING org.eclipse.emf.ecp.view.model.provider.generator_1.7.1.20150923-2258
137 STARTING org.eclipse.emf.ecp.view.model.provider.xmi_1.7.1.20150923-2258
138 STARTING org.eclipse.emf.ecp.view.rule.model_1.7.1.20150923-2258
139 STARTING org.eclipse.emf.ecp.view.stack.model_1.7.1.20150923-2258
140 STARTING org.eclipse.emf.ecp.view.table.model_1.7.1.20150923-2258
141 STARTING org.eclipse.emf.ecp.view.template.model_1.7.1.20150923-2258
142 STARTING org.eclipse.emf.ecp.view.template.service_1.7.1.20150923-2258
143 STARTING org.eclipse.emf.ecp.view.treemasterdetail.model_1.7.1.20150923-2258
144 STARTING org.eclipse.emf.ecp.view.treemasterdetail.ui.swt_1.7.1.20150923-2258
145 STARTING org.eclipse.emf.ecp.view.util.swt_1.7.1.20150923-2258
146 STARTING org.eclipse.emf.ecp.view.validation_1.7.1.20150923-2258
147 STARTING org.eclipse.emf.ecp.workspace.core_1.7.1.20150923-2258
148 STARTING org.eclipse.emf.edit_2.11.0.v20150601-0402
149 STARTING org.eclipse.emf.edit.ui_2.11.0.v20150601-0402
150 STARTING org.eclipse.emfforms.common_1.7.1.20150923-2258
151 STARTING org.eclipse.emfforms.core.services_1.7.1.20150923-2258
152 STARTING org.eclipse.emfforms.core.services.databinding.featurepath_1.7.1.20150923-2258
153 STARTING org.eclipse.emfforms.core.services.editsupport_1.7.1.20150923-2258
154 STARTING org.eclipse.emfforms.core.services.emf_1.7.1.20150923-2258
155 STARTING org.eclipse.emfforms.core.services.emfspecificservice_1.7.1.20150923-2258
156 STARTING org.eclipse.emfforms.core.services.locale.default_1.7.1.20150923-2258
157 STARTING org.eclipse.emfforms.localization_1.7.1.20150923-2258
158 STARTING org.eclipse.emfforms.swt.core_1.7.1.20150923-2258
159 STARTING org.eclipse.emfforms.swt.core.di_1.7.1.20150923-2258
160 STARTING org.eclipse.emfforms.swt.core.plugin_1.7.1.20150923-2258
161 STARTING org.eclipse.emfforms.view.model.localization_1.7.1.20150923-2258
162 ACTIVE org.eclipse.equinox.app_1.3.100.v20120522-1841
Fragments=163
163 RESOLVED org.eclipse.equinox.app.nl_de_3.7.0.v20130724081219
Master=162
164 ACTIVE org.eclipse.equinox.common_3.6.100.v20120522-1841
Fragments=165
165 RESOLVED org.eclipse.equinox.common.nl_de_3.7.0.v20130724081219
Master=164
166 ACTIVE org.eclipse.equinox.concurrent_1.0.300.v20120912-130548
167 ACTIVE org.eclipse.equinox.console_1.0.0.v20120522-1841
168 ACTIVE org.eclipse.equinox.ds_1.4.1.v20120926-201320
Fragments=169
169 RESOLVED org.eclipse.equinox.ds.nl_de_3.7.0.v20130724081219
Master=168
170 ACTIVE org.eclipse.equinox.event_1.2.200.v20120522-2049
171 RESOLVED org.eclipse.equinox.launcher_1.3.0.v20120522-1813
Fragments=172
172 RESOLVED org.eclipse.equinox.launcher.nl_de_3.7.0.v20130724081219
Master=171
173 STARTING org.eclipse.equinox.p2.artifact.repository_1.1.200.v20120430-1959
Fragments=174
174 RESOLVED org.eclipse.equinox.p2.artifact.repository.nl_de_3.7.0.v20130724081219
Master=173
175 STARTING org.eclipse.equinox.p2.console_1.0.300.v20120429-0125
Fragments=176
176 RESOLVED org.eclipse.equinox.p2.console.nl_de_3.7.0.v20130724081219
Master=175
177 STARTING org.eclipse.equinox.p2.core_2.2.0.v20120430-0525
Fragments=178
178 RESOLVED org.eclipse.equinox.p2.core.nl_de_3.7.0.v20130724081219
Master=177
179 STARTING org.eclipse.equinox.p2.director_2.2.0.v20120524-0542
Fragments=180
180 RESOLVED org.eclipse.equinox.p2.director.nl_de_3.7.0.v20130724081219
Master=179
181 STARTING org.eclipse.equinox.p2.engine_2.2.0.v20130121-021919
Fragments=182
182 RESOLVED org.eclipse.equinox.p2.engine.nl_de_3.7.0.v20130724081219
Master=181
183 STARTING org.eclipse.equinox.p2.garbagecollector_1.0.200.v20110808-1657
Fragments=184
184 RESOLVED org.eclipse.equinox.p2.garbagecollector.nl_de_3.7.0.v20130724081219
Master=183
185 RESOLVED org.eclipse.equinox.p2.jarprocessor_1.0.200.v20110808-1657
Fragments=186
186 RESOLVED org.eclipse.equinox.p2.jarprocessor.nl_de_3.7.0.v20130724081219
Master=185
187 STARTING org.eclipse.equinox.p2.metadata_2.1.0.v20120430-2001
Fragments=188
188 RESOLVED org.eclipse.equinox.p2.metadata.nl_de_3.7.0.v20130724081219
Master=187
189 STARTING org.eclipse.equinox.p2.metadata.repository_1.2.100.v20120524-1717
Fragments=190
190 RESOLVED org.eclipse.equinox.p2.metadata.repository.nl_de_3.7.0.v20130724081219
Master=189
191 STARTING org.eclipse.equinox.p2.operations_2.2.0.v20130119-010614
Fragments=192
192 RESOLVED org.eclipse.equinox.p2.operations.nl_de_3.7.0.v20130724081219
Master=191
193 STARTING org.eclipse.equinox.p2.repository_2.2.0.v20120524-1945
Fragments=194
194 RESOLVED org.eclipse.equinox.p2.repository.nl_de_3.7.0.v20130724081219
Master=193
195 STARTING org.eclipse.equinox.p2.transport.ecf_1.0.100.v20120913-155635
Fragments=196
196 RESOLVED org.eclipse.equinox.p2.transport.ecf.nl_de_3.7.0.v20130724081219
Master=195
197 ACTIVE org.eclipse.equinox.preferences_3.5.1.v20121031-182809
Fragments=198
198 RESOLVED org.eclipse.equinox.preferences.nl_de_3.7.0.v20130724081219
Master=197
199 ACTIVE org.eclipse.equinox.registry_3.5.200.v20120522-1841
Fragments=85, 200
200 RESOLVED org.eclipse.equinox.registry.nl_de_3.7.0.v20130724081219
Master=199
201 STARTING org.eclipse.equinox.security_1.1.100.v20120522-1841
Fragments=202
202 RESOLVED org.eclipse.equinox.security.nl_de_3.7.0.v20130724081219
Master=201
203 RESOLVED org.eclipse.equinox.simpleconfigurator.nl_de_3.7.0.v20130724081219
Master=1
204 ACTIVE org.eclipse.equinox.util_1.0.400.v20120917-192807
Fragments=205
205 RESOLVED org.eclipse.equinox.util.nl_de_3.7.0.v20130724081219
Master=204
206 STARTING org.eclipse.help_3.6.0.v20120912-134126
Fragments=207
207 RESOLVED org.eclipse.help.nl_de_3.7.0.v20130724081219
Master=206
208 ACTIVE org.eclipse.jface_3.8.0.v20120912-135020
Fragments=211
209 RESOLVED org.eclipse.jface.databinding_1.6.0.v20120912-135020
Fragments=210
210 RESOLVED org.eclipse.jface.databinding.nl_de_3.7.0.v20130724081219
Master=209
211 RESOLVED org.eclipse.jface.nl_de_3.7.0.v20130724081219
Master=208
212 STARTING org.eclipse.net4j.util_3.5.1.v20150820-0533
213 RESOLVED org.eclipse.osgi.nl_de_3.7.0.v20130724081219
Master=0
214 RESOLVED org.eclipse.osgi.services_3.3.100.v20120522-1822
Fragments=215
215 RESOLVED org.eclipse.osgi.services.nl_de_3.7.0.v20130724081219
Master=214
216 ACTIVE org.eclipse.osgi.services.remoteserviceadmin_1.6.0.v20150306-2024
217 RESOLVED org.eclipse.osgi.util_3.2.300.v20120913-144807
Fragments=218
218 RESOLVED org.eclipse.osgi.util.nl_de_3.7.0.v20130724081219
Master=217
219 RESOLVED org.eclipse.swt_3.8.1.v3836b
Fragments=220, 221
220 RESOLVED org.eclipse.swt.gtk.linux.x86_3.8.1.v3836b
Master=219
221 RESOLVED org.eclipse.swt.nl_de_3.7.0.v20130724081219
Master=219
222 ACTIVE org.eclipse.ui_3.8.2.v20121018-234953
Fragments=229
223 STARTING org.eclipse.ui.browser_3.4.1.v20120912-135036
Fragments=224
224 RESOLVED org.eclipse.ui.browser.nl_de_3.7.0.v20130724081219
Master=223
225 STARTING org.eclipse.ui.forms_3.5.200.v20120521-2332
Fragments=226
226 RESOLVED org.eclipse.ui.forms.nl_de_3.7.0.v20130724081219
Master=225
227 ACTIVE org.eclipse.ui.navigator_3.5.200.v20120523-1956
Fragments=228
228 RESOLVED org.eclipse.ui.navigator.nl_de_3.7.0.v20130724081219
Master=227
229 RESOLVED org.eclipse.ui.nl_de_3.7.0.v20130724081219
Master=222
230 STARTING org.eclipse.ui.views_3.6.100.v20120521-2332
231 ACTIVE org.eclipse.ui.workbench_3.8.2.v20121128-133708
Fragments=232
232 RESOLVED org.eclipse.ui.workbench.nl_de_3.7.0.v20130724081219
Master=231
233 ACTIVE org.eclipse.update.configurator_3.3.200.v20120912-142556
Fragments=234
234 RESOLVED org.eclipse.update.configurator.nl_de_3.7.0.v20130724081219
Master=233
235 STARTING org.eclipse.update.core_3.2.600.v20130104-035835
Fragments=236
236 RESOLVED org.eclipse.update.core.nl_de_3.7.0.v20130724081219
Master=235
237 STARTING org.eclipse.update.ui_3.3.0.v20120912-142556
Fragments=238
238 RESOLVED org.eclipse.update.ui.nl_de_3.7.0.v20130724081219
Master=237
239 RESOLVED org.sat4j.core_2.3.0.v20110329
240 RESOLVED org.sat4j.pb_2.3.0.v20110329
241 ACTIVE org.slf4j.osgi-over-slf4j_1.7.5
242 RESOLVED org.swtchart_0.7.0.v201201201914
243 RESOLVED slf4j.api_1.7.5
Re: [EMFForms] Dependency Injection fails on render of view [message #1714895 is a reply to message #1714880] |
Tue, 17 November 2015 09:17  |
Great, it works!
At first I had a new error:
java.lang.IllegalStateException: There must be exactly one LayoutProvider!
Found 0 providers.
at org.eclipse.emf.ecp.view.spi.swt.layout.LayoutProviderHelper.checkProviderLength(LayoutProviderHelper.java:168)
after browsing the code i found that i was missing the org.eclipse.emf.ecp.view.swt.layout bundle.
Thank you very much again for your help!
Greets, Peter
Current Time: Sun Jul 20 23:58:46 EDT 2025
Powered by FUDForum. Page generated in 0.05681 seconds
