Home » Newcomers » Newcomers » Can't add cURL plugin(cURL plugin fails to install)
Can't add cURL plugin [message #1203611] Fri, 22 November 2013 14:05 Go to next message
Good afternoon.
I am trying to install the cURL plugin and it fails on the install.
When I go to the screen to add the plugins and enter the URl: www.curl.com/cde.update-site.win32/ it does produce a number of install 6 options i.e. Curl Development environment (English) however when I select the "Show software only applicable to target environment the Curl Development Enviroment (English) and the other two disappear.
What do I need to do to be able to have cURL plugin installed?
Here is the info on the Eclipse install:
Eclipse Standard/SDK
Version: Kepler Service Release 1
Build id: 20130919-0819
eclipse.buildId=4.3.0.M20130911-1000
Thank you very much for any help/direction to get this resolved. If additional information is needed please let know.
Again, thank you.
Jim
Re: Can't add cURL plugin [message #1205432 is a reply to message #1203611] Sat, 23 November 2013 11:10 Go to previous messageGo to next message
On 11/22/2013 12:05 PM, Jim Gardner wrote:
> Good afternoon.
> Again, thank you.
> Jim
You may discover that you must resort to the third party that wrote this
plug-in, which isn't developed by the Eclipse community. You may not
necessarily get an answer in this forum.
Re: Can't add cURL plugin [message #1714609 is a reply to message #1203611] Fri, 13 November 2015 15:47 Go to previous message
see url curl.com/download/ide/installation.html
for instructions on installing cURL on Eclipse.
Previous Topic:Better timeouts for dependency resolution
Next Topic:Re: Set minimum width of a view
Current Time: Wed Jul 23 13:27:20 EDT 2025
Powered by FUDForum. Page generated in 0.07390 seconds
