Home » Eclipse Projects » Remote Application Platform (RAP) » Redirecting Requests to Root Path Entry Point
Redirecting Requests to Root Path Entry Point [message #1258376] Thu, 27 February 2014 05:13 Go to next message
Hi!
We recently upgraded to Rap 2.3 and are happy to use the root path entry point.
We have only one minor problem with it. When the application is deployed as WAR, it is not possible to access it on a URL without a trailing slash. Instead a white page is shown.
http://localhost:8080/example -> white page
http://localhost:8080/example/ -> our app
When we look at the source code of the white page it turns out to be the regular starting page of RAP, including the JS libs, setting our page title and so on.
We tried redirecting the request in the web.xml by creating a servlet mapping like this, which unfortunately does not help.
	<servlet-mapping>
		<servlet-name>equinoxbridgeservlet</servlet-name>
		<url-pattern></url-pattern>
	</servlet-mapping>
We also tried to configure an empty entry point, which is not allowed.
Is it possible to redirect the request somehow?
Greetings,
Tibu
[Updated on: Thu, 27 February 2014 05:14] by Moderator
Re: Redirecting Requests to Root Path Entry Point [message #1259417 is a reply to message #1258376] Fri, 28 February 2014 05:55 Go to previous messageGo to next message
Hi Tibu,
this redirect is usually done by the servlet container. For example,
when you run an application from the IDE, Jetty redirects /example to
/example/ before the RWTServlet is even called. This doesn't seem to
work in the WAR deployment.
We'll look into this problem. Could you open a bug for it?
Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Re: Redirecting Requests to Root Path Entry Point [message #1262158 is a reply to message #1259417] Mon, 03 March 2014 05:17 Go to previous messageGo to next message
Hi Ralf,
thanks for your feedback on the issue!
The bugreport I created can be found here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=429443
Greetings,
Tibu
Re: Redirecting Requests to Root Path Entry Point [message #1714278 is a reply to message #1262158] Wed, 11 November 2015 04:40 Go to previous message
old problem
Now Could i refuse entry point (empty)?
<servlet-mapping>
<servlet-name>rwtServlet</servlet-name>
<url-pattern>/</url-pattern>
</servlet-mapping>
Dmitry
Previous Topic:RAP in Geronimo/EJB lookups
Next Topic:Uncaught errors WAS8 + Chrome
Current Time: Sun Jul 27 22:29:08 EDT 2025
Powered by FUDForum. Page generated in 0.27185 seconds
