Home » Eclipse Projects » Remote Application Platform (RAP) » [Table] Individual colors for each cell possible?
[Table] Individual colors for each cell possible? [message #1714022] Mon, 09 November 2015 07:52 Go to next message
I am currently trying to convert a Swing application to RAP which contains a quite customized JTable component.
One of the areas where I haven't found a solution is coloring of individual cells, used to illustrate the result of input validation.
What is the way to go when each cell requires custom background/forground - the background should fill the cell and not only the text. I saw OwnerDrawLabelProvider/StyledCellLabelProvider as well as the low-level Erease-Event/Paint-Event is not supported by RAP. Is there any way to assign background/forground for each table cell manually?
Thank you in advance, Clemens
Re: [Table] Individual colors for each cell possible? [message #1714033 is a reply to message #1714022] Mon, 09 November 2015 08:45 Go to previous messageGo to next message
TableItem.setBackground(int, Color) and TableItem.setForeground(int,
Color) is what you are looking for.
HTH,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: [Table] Individual colors for each cell possible? [message #1714047 is a reply to message #1714033] Mon, 09 November 2015 09:33 Go to previous message
Hi Ivan,
At first I was a bit confused, because I am using a virtual table and therefore the TableItems are created by the Table itself on demand.
Using a SWT.SetData listener did the trick even for the virtual table.
Thanks a lot for the pointer Smile
Best regards, Clemens
Previous Topic:Different deploy approach then war product
Next Topic:badge on the right in treeviewer
Current Time: Mon Jul 21 00:42:39 EDT 2025
Powered by FUDForum. Page generated in 0.03459 seconds
