Home » Modeling » Papyrus » How to merge two *.uml models in Papyrus?
How to merge two *.uml models in Papyrus? [message #1713920] Sun, 08 November 2015 07:43 Go to next message
I would like to combine 2 uml files into one; or at least import all Packages from one model into the other. Trying all manners of import the nest I could do was open both models on a single project and drag packages from one model into the other; all classifier names were italicized to show they were not native to the target packages. How can I have a true merge of 2 models into one (without manually drag/drop and all classifiers shown as native)? Thanks for any suggestion!
Re: How to merge two *.uml models in Papyrus? [message #1713931 is a reply to message #1713920] Sun, 08 November 2015 12:34 Go to previous messageGo to next message
If you open one *.uml with the UML Model Editor, you can
either Load Resource for the other *.uml and DND within the one tree
editor,
or open the other *.uml with the UML Model Editor and DND between tree
editors.
Ed Willink
> suggestion!
Re: How to merge two *.uml models in Papyrus? [message #1713970 is a reply to message #1713931] Mon, 09 November 2015 03:48 Go to previous messageGo to next message
If you are using Papyrus, why don't you just import the model bu using
Papyrus menu?
(right-click the root of your model in the Model Explorer, select
Import->Import Package From User Model. Finally select the model you
want to import).
Best,
Víctor
El 08/11/2015 a las 18:34, Ed Willink escribió:
> Hi
> editor,
> editors.
> Regards
> Ed Willink
>> suggestion!
Re: How to merge two *.uml models in Papyrus? [message #1714042 is a reply to message #1713970] Mon, 09 November 2015 09:09 Go to previous messageGo to next message
Thank you very much, Import User package from Root Menu context menu works! But the importer Classifiers are still in italic in Model explorer... does it mean anything? otherwise I'm OK with your suggestion, thansk
Re: How to merge two *.uml models in Papyrus? [message #1714045 is a reply to message #1714042] Mon, 09 November 2015 09:27 Go to previous messageGo to next message
The greyed-out italic labels indicate read-only elements: they are not
editable in this editor without explicit action to make them writable,
to prevent accidental modification of resources referenced by but not
"owned by" the model that the user intends to be editing.
The Import User Package dialog does also have an option to copy the
selected package(s) into the "importing" model, but I have never used
it.
HTH,
Christian
> suggestion, thansk
Re: How to merge two *.uml models in Papyrus? [message #1714116 is a reply to message #1714045] Mon, 09 November 2015 20:24 Go to previous message
THANKS!! Clearer now.
Previous Topic:How to generate source file for PrimitiveTypes in C++?
Next Topic:What is the best strategy to add a Tagged Value for "Definition" to Classifiers?
Current Time: Thu Jul 24 23:35:08 EDT 2025
Powered by FUDForum. Page generated in 1.34568 seconds
