Home » Eclipse Projects » Oomph » how to recover from mistakes?
how to recover from mistakes? [message #1713759] |
Fri, 06 November 2015 08:18  |
As a new Oomph user, I was playing around with creating a new Project Setup, found I might have made a mistake, and wanted to make a fresh start, only to find that Oomph is smart enough to remember each of my mistakes.
Are there any guides where exactly cleanup may be needed for a fresh start on authoring setups?
One thing I found:
- during my first attempt I put a workspace into a wrong location. In that location I had already created a project setup and somehow hooked it up into something.
- after moving that workspace to a different location I got unresolved EProxies from Oomph, and a lot look not right.
- I could see the unresolved proxy in the editors, but I found now way to delete the bogus stuff
- after a lot of poking around I found traces of the broken first attempt in .eclipse/org.eclipse.oomph.setup/setups/org.eclipse.projects.setup
Obviously, beginners make more mistakes than experts. OTOH, beginners have no idea where their experiments left persistent changes.
Aside from guides for cleaning up: would it be possible to create an Oomph-authoring environment in some kind of sandbox that is *not* connected to my local configurations (neither installation nor user ...)? Something that is neither influenced by my private configuration, nor merged into it?
thanks,
Stephan
Re: how to recover from mistakes? [message #1713819 is a reply to message #1713759] |
Fri, 06 November 2015 12:15   |
Stephan,
Comments below.
> mistakes.
It has a mind like a steel trap. :-P
Things like the user extensions of the catalogs can accumulate garbage,
so you can open those from the navigate menu or the toolbar to clean
them up... Otherwise, it's not clear what needs cleaning up to the
extent that it causes problems if you don't.
Note that if you open the overall index and show all resources via the
toolbar button, you can see everything and if there are broken proxies,
they'll be marked with errors. Ideally there are no red markers. Note
that you can only modify the first resource in the resource set, so if
you see another resource with errors, you can open it in its own setup
editor via the context menu on the resource object.
> One thing I found:
I'm not sure what that means. How was it wrong?
It writes out a workspace.setup into the workspace; that would overwrite
an existing on if there was one.
Workspaces and installations are generally not moveable. Best to delete
them and create fresh clean things.
As I mentioned above, only the first resource is editable. So if there
are errors in other resources, open them in their own editor via the
context menu "Open in Setup Editor".
> attempt in
Yes, your user extension of the catalog.
The user catalogs are also editable in the wizards. You can select the
project setups you added and use the red "-" button to delete them.
No, it's all intended to be an integrated whole. It sounds like mostly
you just didn't notice how to delete things you added in the wizard.
> thanks,
> Stephan
Re: how to recover from mistakes? [message #1713842 is a reply to message #1713819] |
Fri, 06 November 2015 17:44   |
Hi Ed,
Ed Merks wrote on Fri, 06 November 2015 18:15
That usually is great, but can at times be a problem ...
The last item was where I failed: I saw the unresolvable thing in various tree editors, but in none of them it could be deleted.
I'm back on track by having learned:
- tree editors like the overall index show a mix of resources and eobjects
- (some) resources have an "Open In Setup Editor" context command
- after travelling to the containing resource its content can be edited.
Wouldn't it be useful if a double click on any object in the tree would navigate to the place where it is declared and editable?
> One thing I found:
Basically this was just an example of: user's make mistakes, or may change their mind or such. Specifically, I specified the parent folder of all my workspaces, hoping that a new workspace would be created inside, but I ended up with nested workspaces which doesn't seem like a good idea
I know to be careful with such moves, but even deleting would have led to the same problem, since the then-deleted thing was still referenced in .eclipse/org.eclipse.oomph.setup/setups/org.eclipse.projects.setup
Well, I'll see how it works out now that I can proceed. I assume some isolation would be achieved when strictly using one workspace only for authoring one particular setup. Is that the recommended approach?
thanks again,
Stephan
Re: how to recover from mistakes? [message #1713846 is a reply to message #1713842] |
Fri, 06 November 2015 22:45   |
Stephan,
The context menu on any object, including any resource, should have
"Open in Setup Editor" in the context menu and should open that object's
resource in a separate editor. If it's a local resource from the file
system or workspace, it should be editable; if that's not the case,
please open a bugzilla with an example. Also note that the hover text
for the error diagnostics should allow you to navigate to the object
with the error (thought there's a bug in EMF
https://bugs.eclipse.org/bugs/show_bug.cgi?id=480064 that hinders this).
In the end, the only resources that have lasting global impact are the
ones in your user.setup and your catalog extensions, i.e., the things in
..eclipse/org.eclipse.oomph.setup/setups/. so I suppose isolation would
be achieved by specifying user.home to be somewhere else. One good
trick is to make that folder be a local git clone and to have that
folder in your workspace as a project; this way you can commit changes
locally and maintain history, and use reset hard to clean up...
On 06/11/2015 11:44 PM, Stephan Herrmann wrote:
> Hi Ed,
>> It has a mind like a steel trap. :p
> Quote:
>> the toolbar button, you can see everything and if there are broken
>> proxies, they'll be marked with errors. Ideally there are no red
>> markers. Note that you can only modify the first resource in the
>> resource set, so if you see another resource with errors, you can
>> open it in its own setup editor via the context menu on the resource
>> object.
> eobjects
> Quote:
>> > One thing I found:
> a good idea :)
> Quote:
>> unresolved > EProxies from Oomph, and a lot look not right.
>> delete them and create fresh clean things.
> Quote:
>> an > Oomph-authoring environment in some kind of sandbox that is
>> *not* > connected to my local configurations (neither installation
>> nor user > ...)? Something that is neither influenced by my private >
>> mostly you just didn't notice how to delete things you added in the
>> wizard.
> thanks again,
> Stephan
Re: how to recover from mistakes? [message #1713861 is a reply to message #1713846] |
Sat, 07 November 2015 05:12  |
Ed Merks wrote on Sat, 07 November 2015 04:45
Cool, if that's where all of Oomph's memory sits, then putting this under git control sounds like a very powerful concept.
thanks,
Stephan
Current Time: Fri Sep 19 06:07:41 EDT 2025
Powered by FUDForum. Page generated in 0.03845 seconds
