Home » Eclipse Projects » Sirius » Operation acton: how to get to the semantic element
Operation acton: how to get to the semantic element [message #1713461] Wed, 04 November 2015 04:40 Go to next message
I've created various editors using Sirius by now. However there is something that keeps bogging me.
When you create a OperationAction, a variable ( by default called 'views') is defined that provides the elements on which the OperationAction is to be performed. Actually, the views variable is a set of RepresentationElements (so nodes/edges or anything else on a diagram that has been selected).
Typically, you want the operation to act on the semantic element represented by the RepresentationElements in view. In general, I do this like:
| Container Views Variable 'views'
| begin
|- For tg // views.target
|- - // do something with tg
So I dereference the views variable by the 'target' property. This property is provided as views typically is a set of DSemanticDecorators. However, when I validate the odesign model, a warning is created stating that 'target' is unknown. A better expression would be: views.oclAsType(DSemanticDecorator).target. This however requires me to add a dependency on the Sirius metamodel.
Why isn't an additional variable created that holds the semantic elements on which the operation is to be invoked? If you have a node creation tool for instance, also two variables exist: one representing the container (as semantic element) and one representing the containerView (the graphical element representing the container). A similar approach for the OperationAction sounds reasonable to me.
What do you think?
Greetings,
Wilbert
Re: Operation acton: how to get to the semantic element [message #1713572 is a reply to message #1713461] Thu, 05 November 2015 04:07 Go to previous messageGo to next message
Hi Wilbert,
I understand your remarks, you can raise a bugzilla about either have
Sirius metamodels available natively or have a new variable for this tool.
Best Regards.
Le 04/11/2015 10:40, Wilbert Alberts a écrit :
> like:
> | begin
> What do you think?
> Greetings,
> Wilbert
Esteban Dugueperoux - Obeo
Re: Operation acton: how to get to the semantic element [message #1713574 is a reply to message #1713572] Thu, 05 November 2015 04:22 Go to previous messageGo to next message
Raised bugzilla: https://bugs.eclipse.org/bugs/show_bug.cgi?id=481481
Greetings,
Wilbert.
Re: Operation acton: how to get to the semantic element [message #1716151 is a reply to message #1713574] Tue, 01 December 2015 12:47 Go to previous message
I should really thank you for your post here! I've been struggling with the same problem for days ! your post helped me a lot !
Parsa
Previous Topic:AQL query for the "create view" action
Next Topic:Internal error when trying to open an aird file
Current Time: Sat Jul 26 21:11:50 EDT 2025
Powered by FUDForum. Page generated in 0.03279 seconds
