Kepler & Mars [message #1713326] |
Tue, 03 November 2015 06:27  |
Hello to everybody,
I have just downloaded Kepler package but because of I have already downloaded Mars package I want to know if there is a possibility do "install" Kepler package inside Mars.
i.e. I would like having only an "eclipse.exe" file and the possibility to choose between Mars or Kepler (or another additional package in case I will download a third one).
Advanced thanks for the reply.
Davide
Re: Kepler & Mars [message #1713506 is a reply to message #1713486] |
Wed, 04 November 2015 11:54   |
Davide Vacca wrote on Wed, 04 November 2015 16:41I have not exacly understood what you've written.... Firefox 41.0.1 is the previous version of Firefox 41.0.2, right ?
That does not apply with Eclipse Kepler and Eclipse Mars, since they are different packages, one for PHP developpers and the other for Java, right ?
I'd like integrating these two different packages.
You're mixing two different things: Kepler (Luna) and Mars are releases of the whole Eclipse system.
Java and PHP are different targets for either system. Pick the newer of your systems, open the Help -> Install new Software dialog, select the base repository (like http://download.eclipse.org/releases/luna, substitute your release to the last path component). Open the filled-up list and pick either Programming Languages -> Java or WEB, XML Java EE and OSGI Enterprise -> PHP, and let Eclipse do the job.
Re: Kepler & Mars [message #1713807 is a reply to message #1713758] |
Fri, 06 November 2015 11:51   |
Each year, Eclipse has a major release of pre-assembled packages. Those releases are given (somewhat arbitrary) names that progress in alphabetical order (a convention established by the Eclipse project management many years ago): ...Helios (2010)...Indigo (2011)...Juno (2012)...Kepler (2013)...Luna (2014)...Mars (2015)...Neon (2016 release)...
For each of those yearly releases, there are different packages; packages are are pre-assembled sets of plug-ins that are tested together. Packages from the same release can be combined together (for example, Install the PHP plug-ins into an installation of Eclipse IDE for Java Developers). However, different releases can not be combined together; that would be like saying I want to combine Windows 7 with Windows 8 - doesn't make sense.
So if you get, for example, Mars release of Eclipse IDE for Java Developers, Mars is the release (aka, "version") and Eclipse IDE for Java Developers is the package. If someone asks, "What version of Eclipse do you have?" it's best to answer with both pieces of information.
FUDForum. Page generated in 0.14920 seconds
