Home » Eclipse Projects » RCP Testing Tool » Runner fails to execute the windows command(Fails to execute command )
icon5.gif  Runner fails to execute the windows command [message #1713287] Tue, 03 November 2015 01:28 Go to next message
Here is a scenario.
In between execution the test has to extract a file via windows command.
This usecase seems to work just fine with the RCPTT IDE.
But this usecase fails when the tests are executed in a runner cause it fails to execute the parallel windows command.
Is there a workaround for this?
Best Regards,
Chetan
Re: Runner fails to execute the windows command [message #1713649 is a reply to message #1713287] Thu, 05 November 2015 12:31 Go to previous message
Hi Chetan,
probably you can use exec-process
Example:
exec-process -command "\"C:\\Prog\\Java\\jdk1.7.0_75\\bin\\java\"" -args "-jar" -args "\"C:\\Users\\angelo.luciani\\workspace\\testhello\\bin\\testhello.jar\""| invoke getStdout | log
You can create a java program and after that you can run the jar using exec-process.
To create the jar I have created a batch file:
https://github.com/angeloluciani/msdos
You can execute the jar using exec-process.
Probably is more robust because with a java program you can also handle threads.
Let us know if it works.
Previous Topic:[SOLVED] How to skip/ignore a rcp tt test case in Jenkins ?
Next Topic:HTML Report blank screenshots on VM
Current Time: Thu Jul 31 00:46:09 EDT 2025
Powered by FUDForum. Page generated in 0.08205 seconds
