Home » Eclipse Projects » Eclipse Platform » Dependency between java project and plugin project
Dependency between java project and plugin project [message #171268] Tue, 16 December 2003 15:25 Go to next message
I am having some trouble specifying project dependency between a regular
java project and a plugin project. Classes generated in regular java
project are referenced in plugin project. References are compile time.
For example, if there are two projects in workspace, project a and b.
Project a is a “regular” java project. Project b is a plugin project
dependent on project a. Project a contains one class A. Project b is a
simple view plugin created by PDE wizard.
I want to use class A from project a in plugin project b without packaging
class A in a jar and specifying it runtime dependency of plugin b. I have
specified the dependency in project b preferences. Both project a and b
compile correctly after the dependency has been specified. However, when
launching plugin b using runtime workbench, plugin b can not find class A.
How do you run dev/test/debug cycle of plugin b using runtime workbench
while specifying that plugin b is dependent on project a?
Vladimir
Re: Dependency between java project and plugin project [message #171296 is a reply to message #171268] Tue, 16 December 2003 15:42 Go to previous messageGo to next message
Just to add that I am having no trouble specifying dependency between
multiple java projects and launching various runtime configurations. Using
3.0 M5.
Re: Dependency between java project and plugin project [message #171311 is a reply to message #171268] Tue, 16 December 2003 16:17 Go to previous messageGo to next message
There's no harm in converting the regular java project to a plugin; it
will not undo the Java nature of the existing project, and will make it
possible for other plugins to use it without any extra build steps, etc.
Select the project, and go to the menu "File->New->Other...->Plug-in
development->Convert projects to plug-in projects".
We have found that it is good practice to treat all Java projects as
plug-ins, and to exploit the ability of the PDE to automatically
generate classpaths from the plugin.xml file, thereby removing many
version dependencies.
Jonathan Feinberg jdf@us.ibm.com
http://domino.research.ibm.com/cambridge/research.nsf/pages/ cue.html
Re: Dependency between java project and plugin project [message #171654 is a reply to message #171311] Wed, 17 December 2003 10:44 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Beside it must be in plugin. Plugins can't find code that is not in the
same plugin or required plugins. That's the way it works.
See:
http://www.eclipse.org/articles/Article-PDE-does-plugins/PDE -intro.html
and
http://www.eclipse.org/articles/Article-Plug-in-architecture /plugin_architecture.html
Thanks, Rich Kulp
Re: Dependency between java project and plugin project [message #171731 is a reply to message #171654] Wed, 17 December 2003 13:53 Go to previous message
Rich and Jonathan,
Thanks for your responses. I am also discovering the power of project
scoped external tool builders using ant targets thus enabling seamless and
continuous build integration between projects. Ultimately I think that you
are right in your sugestion to use all plugin projects.
Vladimir
Previous Topic:Font Control in Linux
Next Topic:Associating a project with a snapshot view of clearcase
Current Time: Fri Oct 31 07:04:56 EDT 2025
Powered by FUDForum. Page generated in 0.26648 seconds
