Home » Eclipse Projects » Sirius » How to add icons to Table rows
How to add icons to Table rows [message #1712310] Thu, 22 October 2015 16:52 Go to next message
in the basic family example, i notice that when you created a table, there are icons on the rows (of man and women).
could you please explain how to change\add icons to table rows?
index.php/fa/23707/0/
thanks!
[Updated on: Sun, 25 October 2015 05:32] by Moderator
Re: How to add icons to Table rows [message #1712480 is a reply to message #1712310] Sun, 25 October 2015 16:54 Go to previous messageGo to next message
no response yet? Sad Confused
anyone, please?
I'm also using Xtext to build the DSL, in the Xtext outline I see my own custom icons, but they are not "visible" by Sirius.
Re: How to add icons to Table rows [message #1712551 is a reply to message #1712310] Mon, 26 October 2015 06:46 Go to previous messageGo to next message
> thanks!
There is nothing to do to have the icon on lines of table. The joined
screenshot shows an example of a simple table made with EcoreTools [1].
The corresponding table description is here [2].
[1] https://www.eclipse.org/ecoretools/
[2]
http://git.eclipse.org/c/ecoretools/org.eclipse.ecoretools.git/tree/org.eclipse.emf.ecoretools.design/description/ecore.odesign#n1195
Laurent Redor - Obeo
Re: How to add icons to Table rows [message #1712921 is a reply to message #1712551] Thu, 29 October 2015 07:33 Go to previous messageGo to next message
Thank you for the reply.
So I guess that the icons in your example comes from the ecore tools definition, right?https://www.eclipse.org/forums/index.php?t=getfile&id=23731&
But, what if I'm using Xtext integration?
I've created a model with xtext and then I use Sirius tables. When i open the table i get diamond shape icons as in the following screenshot index.php/fa/23779/0/
Do you know how can I change these icons? (somewhere in Xtext, i guess)
Thanks again!
Re: How to add icons to Table rows [message #1712936 is a reply to message #1712921] Thu, 29 October 2015 09:11 Go to previous messageGo to next message
No, they come from the EMF Ecore edit plugin (org.eclipse.emf.ecore.edit).
You need to generate the edit plugin associated to the metamodel. You
can have a look to [1] Integration with EMF, especially "...From the
derived Ecore model and its generator model, we generated the edit
plug-in (needed by GMF) and added some fancier icons..."
> Thanks again!
[1] https://eclipse.org/Xtext/documentation/308_emf_integration.html
Re: How to add icons to Table rows [message #1712962 is a reply to message #1712936] Thu, 29 October 2015 11:18 Go to previous message
thanks, looks like a great starting point !
Previous Topic:Eclipse RCP with Sirius
Next Topic:Installing basicfamily.sample
Current Time: Thu Jul 24 23:46:24 EDT 2025
Powered by FUDForum. Page generated in 0.26062 seconds
