Home » Eclipse Projects » Sirius » Label Expression :: "Unknown EMF Problem"
Label Expression :: "Unknown EMF Problem" [message #1712258] Thu, 22 October 2015 08:51 Go to next message
I have table with Feature Column that has the following label expression:
aql:if self.oclIsTypeOf(myDsl::SomeType) then self.name endif
I would like to show the name attribute only when the line is of type SomeType.
The above code works well, the table shows what i wanted.
The problem:
when i click the "Validate Model" on the Sirius Specification Editor, I get an Error:
ErrorExpression my.odesign /my.studio/description Unknown EMF Problem
What can cause it? how do I fix it?
Another problem is that if i change the code to be more readable with new lines (\n), then the editor replace everything after the first new line with "...." and the code is gone (I think it's a bug)!
      then self.name
endif
The above code is replaced with the following (bad) code.
aql:if self.oclIsTypeOf(myDsl::SomeType) ...
I'm using the latest 3.1.0
Re: Label Expression :: "Unknown EMF Problem" [message #1712507 is a reply to message #1712258] Mon, 26 October 2015 04:49 Go to previous messageGo to next message
> SomeType. The above code works well, the table shows what i wanted.
> The problem:
> get an Error:
> EMF Problem
Are you sure this problem is caused by the expression "aql:if
self.oclIsTypeOf(myDsl::SomeType) then self.name endif"? If you replace
this expression, by a more simple one, do you have always the validation
problem?
Could you create a bugzilla [1] for the above "..." case?
[1] https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Sirius
Laurent Redor - Obeo
Re: Label Expression :: "Unknown EMF Problem" [message #1712923 is a reply to message #1712507] Thu, 29 October 2015 07:56 Go to previous messageGo to next message
hi,
1. for the label expression, I've replaced:
with:
[if self.oclIsTypeOf(myDsl::SomeType) then self.name else '' endif /]
and the validation pass.
2. I've opened a new bug for the "..."
https://bugs.eclipse.org/bugs/show_bug.cgi?id=480981
Re: Label Expression :: "Unknown EMF Problem" [message #1712939 is a reply to message #1712923] Thu, 29 October 2015 09:15 Go to previous message
Le 29/10/2015 12:56, Yariv Amar a écrit :
> hi,
> with:
I think that the problem is the same as in message #1712830 [1]. You can
add a dependency to your meta-model plugin in your plugin where you
defined the Viewpoint Specification Model and try again.
Thanks.
> Regards,
[1]
https://www.eclipse.org/forums/index.php?t=msg&th=1071547&goto=1712830&#msg_1712830
Previous Topic:Superclass created when creating subclass
Next Topic:Eclipse RCP with Sirius
Current Time: Sun Jul 27 22:29:18 EDT 2025
Powered by FUDForum. Page generated in 0.03940 seconds
