| Build configuration with Oomph [message #1712626] |
Mon, 26 October 2015 18:18  |
Hi everyone,
Is it possible to create a Build configuration with Setup Project Model? I created a build configuration using "External Tools Configurations" (that uses scons to build a project). Now, I would like to be able to export this configurations in my future Eclipse Installations.
I found "Projects Build" Task in a setup Project Model, but seems like this is something different, or may be I don't know how to use it properly.
Thank you!
| Re: Build configuration with Oomph [message #1713134 is a reply to message #1712960] |
Sun, 01 November 2015 04:09   |
On 29/10/2015 16:04, Artem Gritsenko wrote:
> Ed,
> Thank you for your reply. The blog says that creating a launch task as
> simple as providing a path to .launch file that contains the build/debug
> configuration. I did that by setting up the "Launch Configuration" field
> of a Launch task to an absolute path of a launch file, but I don't see
> any build configurations after the installation. Can you give me a hint
> on what am I doing wrong?
> Artem
The blog actually says
"For the “Launch” task, you need to use the name of the .launch file,
without .launch."
And as Ed said, you first need to ensure the project containing the
..launch is in the workspace... (if I remember correctly, the build task
is not required for the launch configuration to be found: it is required
for the mwe2 launcher class to be found.)
cheers
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
FUDForum. Page generated in 0.07557 seconds
