Papyrus Oomph setup problems [message #1712134] |
Wed, 21 October 2015 09:13  |
When using the Oomph Installer (1.1. build 1690) to set up the Papyrus (Neon) environment I get some problems.
I'm basing my setup on the Eclipse Comitters product (Neon) and selecting the Papyrus-Main-Infra project, stream Neon/1.2 with target platform Neon.
The product is installed and the git repo is cloned and imported into the ws but there are still several errors, see the attached file. Souldn't that be enught to get the environment up? What am I missing?
Patrik
Re: Papyrus Oomph setup problems [message #1712139 is a reply to message #1712134] |
Wed, 21 October 2015 09:35   |
Hi, Patrik,
Did you import the topmost "Papyrus" project? This one must always be
imported, regardless of which (if any) of its sub-projects you import,
because it defines the basic Papyrus run-time dependencies.
Keep in mind that in the Oomph setup, the project hierarchy provides
organization only. There is no inheritance of stuff in containing
projects by contained projects.
HTH,
Christian
On 2015-10-21 13:13:44 +0000, Patrik Nandorf said:
> platform Neon.
> Regards
> Patrik
> Description Resource Path Location Type
> Bundle 'org.eclipse.gmf.codegen.edit' cannot be resolved MANIFEST.MF
> /org.eclipse.papyrus.tests.framework.edit/META-INF line 9 Plug-in
> Problem
> /org.eclipse.papyrus.tests.framework.editor/META-INF line 10 Plug-in
> Problem
> Bundle 'org.eclipse.gmf.codegen' cannot be resolved MANIFEST.MF
> /org.eclipse.papyrus.tests.framework.edit/META-INF line 8 Plug-in
> Problem
> /org.eclipse.papyrus.tests.framework/META-INF line 24 Plug-in Problem
> Bundle 'org.eclipse.gmf.validate' cannot be resolved MANIFEST.MF
> /org.eclipse.papyrus.tests.framework/META-INF line 42 Plug-in Problem
> Bundle 'org.eclipse.papyrus.gmfgenextension' cannot be resolved
> MANIFEST.MF /org.eclipse.papyrus.tests.framework/META-INF line 37
> Plug-in Problem
> Bundle 'org.eclipse.papyrus.mwe2.utils' cannot be resolved MANIFEST.MF
> /org.eclipse.papyrus.tests.framework/META-INF line 40 Plug-in Problem
> Bundle 'org.eclipse.upr.utp' cannot be resolved MANIFEST.MF
> /org.eclipse.papyrus.tests.framework/META-INF line 44 Plug-in Problem
> CanonicalTests cannot be resolved to a type GMFGen2UTPComponent.java
> /org.eclipse.papyrus.tests.framework/src/org/eclipse/papyrus/tests/framework/gmfgenuml2utp
> line 142 Java Problem
> Class<CSSFormatter> cannot be resolved to a type
> AbstractCSSRuntimeModule.java
> /org.eclipse.papyrus.infra.gmfdiag.css3.xtext/src-gen/org/eclipse/papyrus/infra/gmfdiag/css3
> line 162 Java Problem
> Class<CSSGenerator> cannot be resolved to a type
> line 156 Java Problem
> Class<CSSLabelProvider> cannot be resolved to a type
> AbstractCSSUiModule.java
> /org.eclipse.papyrus.infra.gmfdiag.css3.xtext.ui/src-gen/org/eclipse/papyrus/infra/gmfdiag/css3/ui
> line 85 Java Problem
> Class<CSSOutlineTreeProvider> cannot be resolved to a type
> line 96 Java Problem
> line 101 Java Problem
> Class<CSSProposalProvider> cannot be resolved to a type
> line 112 Java Problem
> Class<CSSQuickfixProvider> cannot be resolved to a type
> line 107 Java Problem
> Class<CSSScopeProvider> cannot be resolved to a type
> line 111 Java Problem
> CodegenContext cannot be resolved to a type CodeGeneratorComponent.java
> /org.eclipse.papyrus.tests.framework/src/org/eclipse/papyrus/tests/framework/m2t/xtend
> line 50 Java Problem
> line 82 Java Problem
> line 83 Java Problem
> EditorPlugin cannot be resolved to a variable
> TestexceptionsEditPlugin.java
> /org.eclipse.papyrus.tests.framework.edit/src-gen/org/eclipse/papyrus/tests/framework/exceptions/provider
> line 55 Java Problem
> TestexceptionsEditorPlugin.java
> /org.eclipse.papyrus.tests.framework.editor/src-gen/org/eclipse/papyrus/tests/framework/exceptions/presentation
> line 57 Java Problem
> GenCommonBase cannot be resolved to a type EditPartRef.java
> /org.eclipse.papyrus.tests.framework/src-gen/org/eclipse/papyrus/tests/framework/exceptions
> line 48 Java Problem
> line 60 Java Problem
> GenCommonBase cannot be resolved to a type EditPartRefImpl.java
> /org.eclipse.papyrus.tests.framework/src-gen/org/eclipse/papyrus/tests/framework/exceptions/impl
> line 80 Java Problem
> line 81 Java Problem
> line 84 Java Problem
> line 86 Java Problem
> line 90 Java Problem
> line 99 Java Problem
> line 100 Java Problem
> line 110 Java Problem
> line 114 Java Problem
> line 157 Java Problem
> line 173 Java Problem
> line 189 Java Problem
> GenEditorGenerator cannot be resolved to a type
> GMFGen2UMLComponent.java
> /org.eclipse.papyrus.tests.framework/src/org/eclipse/papyrus/tests/framework/gmfgen2uml
> line 76 Java Problem
> line 77 Java Problem
> line 78 Java Problem
> GMFGen2UML cannot be resolved to a type GMFGen2UMLComponent.java
> GMFGen2UTPModule cannot be resolved to a type GMFGen2UTPComponent.java
> line 98 Java Problem
> line 102 Java Problem
> line 103 Java Problem
> line 106 Java Problem
> line 109 Java Problem
> line 138 Java Problem
> GMFGenItemProviderAdapterFactory cannot be resolved to a type
> ExceptionsEditor.java
> line 650 Java Problem
> GMFGenPackage cannot be resolved ExceptionsPackageImpl.java
> GMFGenPackage cannot be resolved to a type ExceptionsPackageImpl.java
> line 628 Java Problem
> GMFGenPackage cannot be resolved to a variable
> Metamodels cannot be resolved to a type GMFGen2UMLModule.java
> line 40 Java Problem
> org.eclipse.papyrus.infra.gmfdiag.css3.formatting.CSSFormatter cannot
> be resolved to a type AbstractCSSRuntimeModule.java
> org.eclipse.papyrus.infra.gmfdiag.css3.generator.CSSGenerator cannot be
> org.eclipse.papyrus.infra.gmfdiag.css3.scoping.CSSScopeProvider cannot
> org.eclipse.papyrus.infra.gmfdiag.css3.ui.contentassist.CSSProposalProvider
> cannot be resolved to a type AbstractCSSUiModule.java
> org.eclipse.papyrus.infra.gmfdiag.css3.ui.labeling.CSSDescriptionLabelProvider
> line 91 Java Problem
> org.eclipse.papyrus.infra.gmfdiag.css3.ui.labeling.CSSLabelProvider
> org.eclipse.papyrus.infra.gmfdiag.css3.ui.outline.CSSOutlineTreeProvider
> org.eclipse.papyrus.infra.gmfdiag.css3.ui.quickfix.CSSQuickfixProvider
> org.eclipse.papyrus.infra.gmfdiag.css3.validation.CSSValidator cannot
> line 104 Java Problem
> line 105 Java Problem
> PapyrusDiagramCanonicalTests cannot be resolved to a type
> line 47 Java Problem
> TestExceptionManager cannot be resolved to a type
> The import org.eclipse.gmf cannot be resolved ExceptionsEditor.java
> line 160 Java Problem
> line 22 Java Problem
> line 24 Java Problem
> The import org.eclipse.gmf.codegen cannot be resolved EditPartRef.java
> line 14 Java Problem
> line 21 Java Problem
> line 26 Java Problem
> The import org.eclipse.papyrus.tests.framework.m2m.Metamodels cannot be
> resolved GMFGen2UMLModule.java
> line 16 Java Problem
> The import
> org.eclipse.papyrus.tests.framework.m2t.xtend.templates.CodegenContext
> cannot be resolved CodeGeneratorComponent.java
> line 28 Java Problem
> The import
> org.eclipse.papyrus.tests.framework.m2t.xtend.templates.PapyrusDiagramCanonicalTests
> line 29 Java Problem
> The method basicGetEditPart() from the type EditPartRefImpl refers to
> the missing type GenCommonBase EditPartRefImpl.java
> The method bind(Class<Metamodels>) from the type AbstractModule refers
> to the missing type Metamodels GMFGen2UMLModule.java
> The method createGMFGen2UTPModule(WorkflowContext,
> Collection<TestExceptions>) from the type GMFGen2UTPComponent refers to
> the missing type GMFGen2UTPModule GMFGen2UTPComponent.java
> The method filter(Iterable<?>, Class<GenEditorGenerator>) from the type
> Iterables refers to the missing type GenEditorGenerator
> The method getEditPart() from the type EditPartRef refers to the
> missing type GenCommonBase EditPartRefItemProvider.java
> missing type GenCommonBase EditPartRefOperations.java
> /org.eclipse.papyrus.tests.framework/src-gen/org/eclipse/papyrus/tests/framework/internal/exceptions/operations
> line 56 Java Problem
> The method getEditPart() from the type EditPartRefImpl refers to the
> line 140 Java Problem
> The method getInstance(Class<CanonicalTests>) from the type Injector
> refers to the missing type CanonicalTests GMFGen2UTPComponent.java
> The method getInstance(Class<GMFGen2UML>) from the type Injector refers
> to the missing type GMFGen2UML GMFGen2UMLComponent.java
> The method getUtpModule() from the type GMFGen2UTPComponent refers to
> The method setEditPart(GenCommonBase) from the type EditPartRefImpl
> refers to the missing type GenCommonBase EditPartRefImpl.java
> The method to(Class<? extends ILabelProvider>) in the type
> LinkedBindingBuilder<ILabelProvider> is not applicable for the
> arguments (Class<CSSDescriptionLabelProvider>) AbstractCSSUiModule.java
> The type EditPartRefImpl must implement the inherited abstract method
> EditPartRef.setEditPart(GenCommonBase) EditPartRefImpl.java
> TransformationUtilities cannot be resolved to a type
> line 139 Java Problem
Re: Papyrus Oomph setup problems [message #1718103 is a reply to message #1712617] |
Sat, 19 December 2015 11:59  |
hi
I try to get , to modify the source code of Papyrus plugin and customize it for particular objectifs. but i have a lot of problems:
* how to resolve the error when i try to get the source code with Git Repositories
* how run this source code
* how can i modify this source code
thanks you for your helps
looking forward to hearing from you
kind regards
FUDForum. Page generated in 0.05099 seconds
