Home » Eclipse Projects » Kura » Change log level at runtime
Change log level at runtime [message #1691445] Tue, 07 April 2015 06:19 Go to next message
Is there any way to change a logger's level at runtime?
I would like to change between INFO and DEBUG on some features I'm working on without restarting Kura.
Re: Change log level at runtime [message #1691890 is a reply to message #1691445] Fri, 10 April 2015 06:19 Go to previous messageGo to next message
My apologies for the late response. This feature has been removed in the OSGI console due to dependencies problem with another stack.
You can add a flag in the log4j config file (/opt/eclipse/kura/kura/log4j.properties), but you have to restart Kura to active it.
--Pierre
Re: Change log level at runtime [message #1692077 is a reply to message #1691890] Mon, 13 April 2015 05:28 Go to previous messageGo to next message
Ok, thank you.
Re: Change log level at runtime [message #1703133 is a reply to message #1692077] Tue, 28 July 2015 14:54 Go to previous messageGo to next message
I know this feature has been added again, but its accessible only through OSGi console. I developed a simple web interface to change log levels at runtime.
I uploaded the project on my github page. It compiles with Maven 3.0.5 as deployment package, you can install it on any running kura instance.
I find it very useful when developing/debugging, hope it may help someone else.
Re: Change log level at runtime [message #1712459 is a reply to message #1703133] Sun, 25 October 2015 06:47 Go to previous messageGo to next message
Alessandro you mention this can be done via osgi console? what is the command?
Your plugin looks interesting, I might build and install on my testing device.
thanks, p.
Re: Change log level at runtime [message #1712505 is a reply to message #1712459] Mon, 26 October 2015 04:42 Go to previous messageGo to next message
Yes, kura already supports it from OSGi console. Connect to the console with telnet <host> 5002, commands are
getkuraloglevel
setkuraloglevel <loggername> <level>
where level is one of TRACE, DEBUG, INFO, WARN, CRITICAL, ERROR.
Those commands are defined in kura/org.eclipse.kura.core.log/src/main/java/org/eclipse/kura/core/log/LoggerCommandProvider.java
Please ask if you have any further question Smile
Re: Change log level at runtime [message #1719601 is a reply to message #1712505] Sat, 09 January 2016 11:47 Go to previous messageGo to next message
Just letting you know that I update my bundle https://github.com/darugnaa/kura-web-log
Now you can view the log directly in the browser.
Web interface is rather simple, any help is welcome =)
Re: Change log level at runtime [message #1840943 is a reply to message #1712505] Thu, 29 April 2021 06:38 Go to previous message
From version 4 of Kura the "setkuraloglevel" command is removed.
How do you get to change the log level at runtime now?
Previous Topic:Kura and Java 11
Next Topic:Data export from STEP 7 (TIA V16)
Current Time: Sun Jul 20 21:54:18 EDT 2025
Powered by FUDForum. Page generated in 0.04455 seconds
