Home » Eclipse Projects » Sirius » Access Class which is outside the Model
Access Class which is outside the Model [message #1712439] Sat, 24 October 2015 15:58 Go to next message
Hello everyone,
how can I access a class which is not in the same Model?
Re: Access Class which is outside the Model [message #1712546 is a reply to message #1712439] Mon, 26 October 2015 06:36 Go to previous messageGo to next message
Le 24/10/2015 21:58, Vladimir Ilievski a écrit :
> Hello everyone,
What do you mean by "access a class"?
All semantic models contained in a modeling project can be used in your
representations.
If the semantic model is not in your modeling project, you can add it by
using the contextual menu "Add model" on the "Project Dependencies" item
in the Model Explorer view.
Laurent Redor - Obeo
Re: Access Class which is outside the Model [message #1712602 is a reply to message #1712546] Mon, 26 October 2015 13:24 Go to previous message
I am a begineer using Sirus so I am sorry if I am using wrong expressions. Here is the point. In the atachment bip2.ecore.png there is my .ecore file, and I can't change this file, because it is already standardized. Then when I am creating new modeling project. After creating the project, I am adding new Packaging Model (see attachment selectModel.png) from the Example EMF Model Creation Wizards, and I choose as a Model Object, the class BipPackage (attachment BipPackage.png). This class is in the bip2.ujf.verimag.bip.packaging and it is containing a list of AtomType objects. The class AtomType is in the package bip2.ujf.verimag.bip.types and is not part of this model. Then, when I try to create new instance from AtomType using Node Creation tool and to save it in the list of AtomTypes in the BipPackage class, I am not able to do it. Is there a way to do this?
Previous Topic:Generating the Table Editor code
Next Topic:How to move endpoint of edges when Ends Centering configured as Both
Current Time: Sat Nov 08 18:41:04 EST 2025
Powered by FUDForum. Page generated in 0.03162 seconds
