Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EMF Forms] 1.7.1: where is org.eclipse.emfforms.spi.common?
Re: [EMF Forms] 1.7.1: where is org.eclipse.emfforms.spi.common? [message #1711604 is a reply to message #1711587] |
Sun, 18 October 2015 04:36   |
I also get "No view service of type 'org.eclipse.emf.ecp.edit.spi.DeleteService' found"
I suppose it is because of the same issue - missing some bundles?
'org.eclipse.emf.ecp.edit' is in my dependencies, the classes are there but not the service definition - it seems to be in some of the missing bundles.
Below are listed the bundles I defined as dependency to get EMF Forms working in RCP application:
org.eclipse.emf.common,
org.eclipse.emf.common.ui,
org.eclipse.emf.ecore,
org.eclipse.emf.ecp.application.e3,
org.eclipse.emf.ecp.application.e4,
org.eclipse.emf.ecp.common.ui,
org.eclipse.emf.ecp.core,
org.eclipse.emf.ecp.edit,
org.eclipse.emf.ecp.edit.swt,
org.eclipse.emf.ecp.ui,
org.eclipse.emf.ecp.ui.e4,
org.eclipse.emf.ecp.ui.rcp,
org.eclipse.emf.ecp.ui.view,
org.eclipse.emf.ecp.ui.view.editor.controls,
org.eclipse.emf.ecp.ui.view.swt,
org.eclipse.emf.ecp.validation,
org.eclipse.emf.ecp.view.context.locale,
org.eclipse.emf.ecp.view.control.multireference,
org.eclipse.emf.ecp.view.custom.ui.swt,
org.eclipse.emf.ecp.view.group.model.edit,
org.eclipse.emf.ecp.view.group.swt.embedded,
org.eclipse.emf.ecp.view.group.ui.swt,
org.eclipse.emf.ecp.view.horizontal.model,
org.eclipse.emf.ecp.view.horizontal.model.edit,
org.eclipse.emf.ecp.view.horizontal.ui.swt,
org.eclipse.emf.ecp.view.label.model,
org.eclipse.emf.ecp.view.label.model.edit,
org.eclipse.emf.ecp.view.label.ui.swt,
org.eclipse.emf.ecp.view.migrator,
org.eclipse.emf.ecp.view.model.provider.generator,
org.eclipse.emf.ecp.view.model.provider.xmi,
org.eclipse.emf.ecp.view.rule,
org.eclipse.emf.ecp.view.rule.model,
org.eclipse.emf.ecp.view.rule.model.edit,
org.eclipse.emf.ecp.view.swt.layout,
org.eclipse.emf.ecp.view.table.columnservice,
org.eclipse.emf.ecp.view.table.model,
org.eclipse.emf.ecp.view.table.model.edit,
org.eclipse.emf.ecp.view.table.ui.swt,
org.eclipse.emf.ecp.view.template.service,
org.eclipse.emf.ecp.view.unset,
org.eclipse.emf.ecp.view.util.swt,
org.eclipse.emf.ecp.view.validation,
org.eclipse.emf.ecp.view.vertical.model,
org.eclipse.emf.ecp.view.vertical.model.edit,
org.eclipse.emf.ecp.view.vertical.ui.swt,
org.eclipse.emf.ecp.workspace.core,
org.eclipse.emf.ecp.workspace.ui,
org.eclipse.emf.edit,
org.eclipse.emfforms.common,
org.eclipse.emfforms.core.services,
org.eclipse.emfforms.core.services.databinding.featurepath,
org.eclipse.emfforms.core.services.editsupport,
org.eclipse.emfforms.core.services.emf,
org.eclipse.emfforms.core.services.emfspecificservice,
org.eclipse.emfforms.core.services.locale.default,
org.eclipse.emfforms.localization,
org.eclipse.emfforms.swt.core.di,
org.eclipse.emfforms.swt.core.di.extension,
org.eclipse.emfforms.swt.core.plugin,
org.eclipse.emfforms.swt.treemasterdetail,
org.eclipse.emfforms.view.model.localization
[Updated on: Sun, 18 October 2015 04:47] by Moderator
Re: [EMF Forms] 1.7.1: where is org.eclipse.emfforms.spi.common? [message #1711995 is a reply to message #1711891] |
Tue, 20 October 2015 12:13   |
the bundle org.eclipse.emfforms.spi.common has never exist, I was wrong
as far I can see, I have all the bundles are needed to run:
and I think those services are essential, so I cannot use EMF Forms
it seems I misunderstood the goal of EMF Forms - I thought it is qualified to build RCP applications that are not generated ECP Editors or whatever the goal is, but not the plain e4 RCP application, because it does not wire its services together in that environment... my fault
[Updated on: Tue, 20 October 2015 12:14] by Moderator
Re: [EMF Forms] 1.7.1: where is org.eclipse.emfforms.spi.common? [message #1712224 is a reply to message #1712136] |
Thu, 22 October 2015 04:49   |
Hi Klim,
just to solve some misunderstanding:
"it seems I misunderstood the goal of EMF Forms - I thought it is qualified to build RCP applications that are not generated ECP Editors or whatever the goal is, but not the plain e4 RCP application, because it does not wire its services together in that environment"
you understood the goal of EMFForms correctly, we allow you to easily provide forms for your emf data.
Now for the Services:
!MESSAGE Could not bind a reference of component EMFFormsViewService. The reference is: Reference[name = Provider, interface = org.eclipse.emf.ecp.view.spi.provider.IViewProvider, policy = dynamic, cardinality = 0..n, target = null, bind = addProvider, unbind = removeProvider]
There is a bug report for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=402750
This is just a log message of DS, so as long as all your view models are used you can ignore this.
The DeleteService is a bit trickier:
It is used in order to correctly delete emf objects eg from a tree or a table.
In order to get rid of the log message, you must provide an instance of this service when instantiating the viewmodelcontext. BUT even if the log occurs we have a fallback in place so the elements still will get deleted.
We are currently working on a redesign of the service hierarchies so that we can omit such confusing situations. We plan to finish it for 1.8 .
And to answer you question:
org.eclipse.emfforms.spi.common.report - This is a bundle in org.eclipse.emfforms.common
See eclipse package name conventions:
https://wiki.eclipse.org/Naming_Conventions#Java_Packages
And you can find how to setup a feature based config in this tutorial:
http://eclipsesource.com/blogs/tutorials/getting-started-with-EMF-Forms/
Under "Try the layout in the demo application"
I hope this helps.
Eugen
Current Time: Thu Jul 24 23:04:34 EDT 2025
Powered by FUDForum. Page generated in 0.08592 seconds
