Home » Eclipse Projects » e(fx)clipse » P2 check for updates doesn't work
P2 check for updates doesn't work [message #1711851] Tue, 20 October 2015 03:18 Go to next message
I'm trying to update my application using P2 following this online tutorial.
I have a p2 repository hosted on a local Apache server and my application doesn't seems to detect updates on it. There is also no P2 request logged in the access.log of the Apache server.
So I have two problems :
- When my p2 repo does not exist, update service doesn't throw an error or a warning.
- When my p2 repo is up and contains update, the update service tells me that there is no available update.
Do you have any advice to debug it simply ? or help me with some example code?
Here the code of my update handler :
public class UpdateHandler {
	/** The Logger */
	private static final Logger LOG = Logger.getLogger(UpdateHandler.class);
	/** The Repository URL */
	private static final String REPOSITORY_LOC = "http://localhost/repository";
	@Inject
	UISynchronize sync;
	@Execute
	public void execute(IProvisioningAgent agent, UpdateService updateService, IWorkbench workbench) {
		LOG.debug("execute: " + this.getClass().getName());
		LOG.debug("Adding P2 repository : " + REPOSITORY_LOC);
		P2Util.addRepository(agent, REPOSITORY_LOC);
		final CancelableOperation<Optional<UpdatePlan>> check = updateService.checkUpdate(ProgressReporter.NULLPROGRESS_REPORTER);
		check.onCancel(() -> showInformation("Operation cancelled"));
		check.onException(t -> showError(t.getStatus().getMessage()));
		check.onComplete(updatePlan -> {
			if (!updatePlan.isPresent()) {
				showInformation("Nothing to update");
			else {
				if (showConfirmation("Updates available", "There are updates available. Do you want to install them now?")) {
					final CancelableOperation<UpdateResult> result = updatePlan.get().runUpdate(ProgressReporter.NULLPROGRESS_REPORTER);
					result.onCancel(() -> showInformation("Operation cancelled"));
					result.onException(t -> showError(t.getLocalizedMessage()));
					result.onComplete(r -> {
						if (showConfirmation("Updates installed, restart?", "Updates have been installed successfully, do you want to restart?")) {
							sync.syncExec(() -> workbench.restart());
And my P2Util used to add the repository location :
public class P2Util {
	/** The Logger */
	private static final Logger LOG = Logger.getLogger(P2Util.class);
	public static boolean addRepository(IProvisioningAgent agent, String repo) {
		IMetadataRepositoryManager metadataManager = (IMetadataRepositoryManager) agent.getService(IMetadataRepositoryManager.SERVICE_NAME);
		IArtifactRepositoryManager artifactManager = (IArtifactRepositoryManager) agent.getService(IArtifactRepositoryManager.SERVICE_NAME);
		if (metadataManager == null) {
			LOG.error("metadataManager is null!!!");
			return false;
		if (artifactManager == null) {
			LOG.error("artifactManager is null!!!");
			return false;
		try {
			URI uri = new URI(repo);
			metadataManager.addRepository(uri);
			artifactManager.addRepository(uri);
			return true;
		} catch (Exception e) {
			return false;
Re: P2 check for updates doesn't work [message #1711861 is a reply to message #1711851] Tue, 20 October 2015 03:54 Go to previous messageGo to next message
Are you executing it from the IDE or the exported product? IIRC p2 doesn't work well if the application is started from within the IDE.
If started from the IDE you might want to test if enabling Software Installation Support in the Run Configurations -> Configuration tab has any effect on this. But I never tested that one and verified the p2 updates on exported products.
Re: P2 check for updates doesn't work [message #1711905 is a reply to message #1711861] Tue, 20 October 2015 05:33 Go to previous messageGo to next message
When executing it from the IDE ('Support software installation' is disabled), I got the error 'No provisioning job available', so that's what I expect.
But when executing it from the exported product (or enabling 'Support software installation'), I always got the message 'Nothing to update'. Even if the update repository exists or not, contains available updates or not...
Re: P2 check for updates doesn't work [message #1711920 is a reply to message #1711905] Tue, 20 October 2015 06:01 Go to previous messageGo to next message
Are you sure that your P2Util is working as intended? Have you tried using a p2.inf?
Re: P2 check for updates doesn't work [message #1711923 is a reply to message #1711905] Tue, 20 October 2015 06:03 Go to previous messageGo to next message
I guess you need to connect with a remote debugger to see what is going
wrong.
Tom
> what I expect. But when executing it from the exported product (or
Re: P2 check for updates doesn't work [message #1711973 is a reply to message #1711920] Tue, 20 October 2015 09:31 Go to previous messageGo to next message
On first sight if looks ok - I guess we should ship such API/Helper as
part of e(fx)clipse on day ;-)
Tom
> using a p2.inf?
Re: P2 check for updates doesn't work [message #1711974 is a reply to message #1711973] Tue, 20 October 2015 09:47 Go to previous messageGo to next message
Maybe, but AFAIK p2.inf has more functionality. And I prefer configuration over implementation in that case. If the URL ever changes I don't want to search the whole code for that URL. Also p2 provides the ability to host the metadata repository and the artifact repository at different locations (although I don't know how often that feature is really used).
Did you try to connect to your local update site via the Eclipse Installation Manager? It should be able to connect and to show the IUs in the installation dialog. Just to ensure that everything is ok with your update site.
Re: P2 check for updates doesn't work [message #1711976 is a reply to message #1711905] Tue, 20 October 2015 09:59 Go to previous messageGo to next message
Did you by chance forgot to increment the product-version?
Tom
Re: P2 check for updates doesn't work [message #1711987 is a reply to message #1711974] Tue, 20 October 2015 10:57 Go to previous messageGo to next message
Yes, I've tried Wink But I really need to change P2 repository location at runtime.
Yes, it works perfectly.
I added some code in P2Util to check the repo when adding it to the IProvisioningAgent :
	/** The Logger */
	 * Add a repository to declared updates repositories.
	 * @return
	public static boolean addRepository(IProvisioningAgent agent, URI uri) {
		boolean added = true;
			return false;
			return false;
		try {
			metadataManager.loadRepository(uri, new NullProgressMonitor()); // HERE
			artifactManager.loadRepository(uri, new NullProgressMonitor()); // AND HERE
			LOG.error("An error occurred while adding repository from URI['" + uri + "']. Cause : ", e);
			added = false;
		return added;
Du to this code, the following error is thrown :
!ENTRY org.eclipse.ecf.provider.filetransfer.httpclient4 4 0 2015-10-20 16:46:33.222
!MESSAGE org.eclipse.core.runtime.Status[plugin=org.eclipse.ecf.provider.filetransfer.httpclient4;code=4;message=Warning: Platform proxy API not available;severity2;exception=java.lang.NoClassDefFoundError: org/eclipse/core/net/proxy/IProxyService;children=[]]
!STACK 0
	at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientRetrieveFileTransfer.setupProxies(HttpClientRetrieveFileTransfer.java:316)
	at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:884)
	at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTransfer.java:576)
	at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocolRetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAdapter.java:106)
	at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.sendRetrieveRequest(FileReader.java:426)
	at org.eclipse.equinox.internal.p2.transport.ecf.FileReader.readInto(FileReader.java:358)
	at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.download(RepositoryTransport.java:101)
	at org.eclipse.equinox.internal.p2.transport.ecf.RepositoryTransport.download(RepositoryTransport.java:156)
	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadIndexFile(AbstractRepositoryManager.java:735)
	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:657)
	at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
	at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
	at dp.fast.app.update.util.P2Util.addRepository(P2Util.java:45)
	at dp.fast.app.update.handler.UpdateHandler.execute(UpdateHandler.java:49)
	at java.lang.reflect.Method.invoke(Method.java:497)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:252)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:234)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
	at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:493)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:486)
	at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
	at org.eclipse.fx.ui.workbench.renderers.base.BaseItemRenderer.executeAction(BaseItemRenderer.java:210)
	at org.eclipse.fx.ui.workbench.renderers.base.BaseMenuItemRenderer$1.run(BaseMenuItemRenderer.java:50)
	at org.eclipse.fx.ui.workbench.renderers.fx.DefMenuItemRenderer$MenuItemImpl$2.handle(DefMenuItemRenderer.java:137)
	at org.eclipse.fx.ui.workbench.renderers.fx.DefMenuItemRenderer$MenuItemImpl$2.handle(DefMenuItemRenderer.java:1)
	at com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:86)
	at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:238)
	at com.sun.javafx.event.EventHandlerManager.dispatchBubblingEvent(EventHandlerManager.java:191)
	at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:58)
	at com.sun.javafx.event.EventDispatchChainImpl.dispatchEvent(EventDispatchChainImpl.java:114)
	at com.sun.javafx.event.EventUtil.fireEventImpl(EventUtil.java:74)
	at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:49)
	at javafx.event.Event.fireEvent(Event.java:198)
	at javafx.scene.control.MenuItem.fire(MenuItem.java:462)
	at com.sun.javafx.scene.control.skin.ContextMenuContent$MenuItemContainer.doSelect(ContextMenuContent.java:1405)
	at com.sun.javafx.scene.control.skin.ContextMenuContent$MenuItemContainer.lambda$createChildren$343(ContextMenuContent.java:1358)
	at com.sun.javafx.event.CompositeEventHandler$NormalEventHandlerRecord.handleBubblingEvent(CompositeEventHandler.java:218)
	at com.sun.javafx.event.CompositeEventHandler.dispatchBubblingEvent(CompositeEventHandler.java:80)
	at com.sun.javafx.event.CompositeEventDispatcher.dispatchBubblingEvent(CompositeEventDispatcher.java:59)
	at com.sun.javafx.event.BasicEventDispatcher.dispatchEvent(BasicEventDispatcher.java:56)
	at com.sun.javafx.event.EventUtil.fireEvent(EventUtil.java:54)
	at javafx.scene.Scene$MouseHandler.process(Scene.java:3757)
	at javafx.scene.Scene$MouseHandler.access$1500(Scene.java:3485)
	at javafx.scene.Scene.impl_processMouseEvent(Scene.java:1762)
	at javafx.scene.Scene$ScenePeerListener.mouseEvent(Scene.java:2494)
	at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:352)
	at com.sun.javafx.tk.quantum.GlassViewEventHandler$MouseEventNotification.run(GlassViewEventHandler.java:275)
	at com.sun.javafx.tk.quantum.GlassViewEventHandler.lambda$handleMouseEvent$355(GlassViewEventHandler.java:388)
	at com.sun.javafx.tk.quantum.QuantumToolkit.runWithoutRenderLock(QuantumToolkit.java:389)
	at com.sun.javafx.tk.quantum.GlassViewEventHandler.handleMouseEvent(GlassViewEventHandler.java:387)
	at com.sun.glass.ui.View.handleMouseEvent(View.java:555)
	at com.sun.glass.ui.View.notifyMouse(View.java:937)
	at com.sun.glass.ui.win.WinApplication._runLoop(Native Method)
	at com.sun.glass.ui.win.WinApplication.lambda$null$149(WinApplication.java:191)
	at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.ClassNotFoundException: org.eclipse.core.net.proxy.IProxyService cannot be found by org.eclipse.ecf.provider.filetransfer_3.2.200.v20150810-1719
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:439)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:352)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:344)
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
	... 72 more
Re: P2 check for updates doesn't work [message #1711988 is a reply to message #1711987] Tue, 20 October 2015 11:08 Go to previous messageGo to next message
so there's a missing dependency?
Tom
On 20.10.15 16:57, Thibault Pensec wrote:
> Quote:
>> using a p2.inf?
> Yes, I've tried ;) But I really need to change P2 repository location at
> runtime.
> Quote:
> /** The Logger */
> * @return
> uri) {
> return false;
> return false;
> try {
> added = false;
> return added;
> 16:46:33.222
> !MESSAGE
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> ... 72 more
Re: P2 check for updates doesn't work [message #1711991 is a reply to message #1711988] Tue, 20 October 2015 11:22 Go to previous messageGo to next message
We are simply repackaging the ecf-Feature they provide and it looks like
they don't bring "org.eclipse.core.net" with them.
I've update our target to ship core.net now as well and started a new
build. You should try adding core.net to your feature and check if
things now work with an exception?
Tom
> Tom
>> Quote:
>>> using a p2.inf?
>> runtime.
>> Quote:
>> /** The Logger */
>> * @return
>> uri) {
>> return false;
>> return false;
>> try {
>> added = false;
>> return added;
>> 16:46:33.222
>> !MESSAGE
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 72 more
Re: P2 check for updates doesn't work [message #1711998 is a reply to message #1711991] Tue, 20 October 2015 12:30 Go to previous messageGo to next message
You should try adding core.net to your feature and check if things now work with an exception?
Great ! Things seem to work better, now I can see P2 requests in my Apache server access.log.
But the problem remains the same, no updates are found even if the repository contains available updates Confused
Could you tell me more about Remote RCP debugging ?
Re: P2 check for updates doesn't work [message #1712001 is a reply to message #1711998] Tue, 20 October 2015 12:45 Go to previous messageGo to next message
You've not responded to my initial question have you ugraded the .product version this crucial to make p2 detect updates! The feature version is not enough!
Re: P2 check for updates doesn't work [message #1712002 is a reply to message #1712001] Tue, 20 October 2015 12:52 Go to previous messageGo to next message
Sorry !! In fact it works very well when upgrading the .product version Cool
Thank you very much.
Re: P2 check for updates doesn't work [message #1712003 is a reply to message #1712002] Tue, 20 October 2015 13:05 Go to previous messageGo to next message
I'll Investigate in the next few days what needs to happen to make upgrades possible without that
Re: P2 check for updates doesn't work [message #1712008 is a reply to message #1712002] Tue, 20 October 2015 13:35 Go to previous messageGo to next message
A last thing Smile To make the update visible, I need to manually delete the workspace/ folder at the root of my exported product...
And calling the workbench.restart() method simply close the application but don't restart it.
Do I have to do something else before restarting the application ? Like removing workspace/ folder manually ?
Re: P2 check for updates doesn't work [message #1712014 is a reply to message #1712008] Tue, 20 October 2015 14:01 Go to previous messageGo to next message
It depends what the update does and what you want to happen there's the
RestartService who allows to clear the persisted state on restart.
Tom
On 20.10.15 19:35, Thibault Pensec wrote:
> A last thing :) To make the update visible, I need to manually delete
> the workspace/ folder at the root of my exported product... And calling
> restart it.
Re: P2 check for updates doesn't work [message #1712016 is a reply to message #1712014] Tue, 20 October 2015 14:11 Go to previous messageGo to next message
I've now added the equinox.security and core.net to the p2-feature so if
you update the target you should get core.net deployed.
Tom
> Tom
>> restart it.
Re: P2 check for updates doesn't work [message #1712024 is a reply to message #1712016] Tue, 20 October 2015 15:28 Go to previous message
According to https://wiki.eclipse.org/Tycho/eclipse-repository should do
the trick but when doing the export with PDE inside Eclipse this does
not work, need to test this with a tycho build.
Tom
> Tom
>> Tom
>>> restart it.
Previous Topic:efxclipse AdapterService vs e4 IAdapterManager
Next Topic:Application title bar with extra options
Current Time: Mon Jul 21 03:39:19 EDT 2025
Powered by FUDForum. Page generated in 0.16580 seconds
