[EMF Forms] validation processing [message #1711572] |
Sat, 17 October 2015 11:03  |
I wonder how it is intended to process invalid forms, i.e. those with failed validation.
As far I can see, EMF Forms only adds highlighting if there are constraint violations (also maybe some other things I am not aware of). But it does not disable any buttons, so it is always possible to create model objects, no matter if they are invalid.
Actually the primary goal of validation is to prevent creating invalid state, so I am sure that I am missing something, but I can't find appropriate documentation relating to this issue.
Re: [EMF Forms] validation processing [message #1711728 is a reply to message #1711572] |
Mon, 19 October 2015 09:00   |
EMF itself does not prevent creating invalid states and so doesn't EMF
Forms, which does not add any additional logic here. Validation is
checking a current model instance against those rules. However, for some
model constraints it would be possible to enforce them beforehand.
I assume you talking about multiplicities? They could actually be
enforced by multi-attribute and multi-references controls, but that
would require some customization.
Best regards
Jonas
Am 17.10.2015 um 17:03 schrieb Klim Tow:
> Hi
> failed validation.
Jonas Helming
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
FUDForum. Page generated in 0.22880 seconds
