Home » Eclipse Projects » GEF » [GEF4] Is it possible to do multiline?
[GEF4] Is it possible to do multiline? [message #1711687] Mon, 19 October 2015 05:46 Go to next message
It is possible to create multi shape with the MultiShape object but I don't find in GEF4 the way to create multi line object. In a shape you have for example three discontinued lines as in the screenshot.
Can it be done natively with GEF4 or do i need to code an object like the multishape object?
Thank you
index.php/fa/23596/0/
Re: [GEF4] Is it possible to do multiline? [message #1711774 is a reply to message #1711687] Mon, 19 October 2015 11:01 Go to previous message
The GEF4 Geometry API does not provide a native shape for multilines (at least not for discontinued ones). You can however use a GEF4 Geometry Path to represent your multi line and can then render this directly by passing it to an FXGeometryNode.
Previous Topic:[GEF4] Curve edges in Zest2
Next Topic:[GEF4] geometry axis
Current Time: Sat Nov 08 11:26:19 EST 2025
Powered by FUDForum. Page generated in 0.04156 seconds
