Draw location for new nodes [message #1711172] |
Tue, 13 October 2015 13:38  |
I have a border node that when double-clicked creates a new node in the model and on the diagram. I would like that new node to be drawn right next to the doubled clicked border node but not attached to it. Currently it draws the new node in the upper left corner of the diagram.
Am I able to control where the new node gets drawn? If so, how would I go about doing that?
Thank you,
Bailey
[Updated on: Tue, 13 October 2015 13:39] by Moderator
Re: Draw location for new nodes [message #1711791 is a reply to message #1711770] |
Mon, 19 October 2015 13:03  |
In fact when I was saying after the node creation, I was thinking into
the same tool/service that creates the node, not a different action. You
should give it a try, because I am not entirely sure that this is not
too soon for the Sirius refresh.
For the node creation listener, you can add a ModelChangeTrigger that
would react on node creation.
Another way, but a little bit overkill, would be to implement a specific
layout using this tutorial:
https://www.eclipse.org/sirius/doc/developer/extensions-provide_custom-arrange-all.html
Steve
Le 19/10/2015 16:41, Bailey Trenton a écrit :
> Hello Steve,
> So there is no way to set the location before it is drawn on the
> Sirius Diagram? I can only move it after it is drawn?
> Also where would I do the updating? Are there a node creation listener
> in Sirius?
> Bailey
Steve Monnier - Obeo
Need professional services for Sirius?
FUDForum. Page generated in 0.06522 seconds
