Home » Eclipse Projects » Sirius » External Java action when changing context of an element
icon5.gif  External Java action when changing context of an element [message #1711484] Fri, 16 October 2015 07:56 Go to next message
Hi all,
I have a container element and I want to do an external Java action when the context of container is changed, for example: when I add Node in Container or when I change Node's attributes.
Could you please show me how to do it?
Best Regards,
Tuan Hoang
Re: External Java action when changing context of an element [message #1711496 is a reply to message #1711484] Fri, 16 October 2015 08:55 Go to previous messageGo to next message
Le 16/10/2015 13:56, Tuan Hoang Anh a écrit :
> Hi all,
A tool which would listen for the context change does not exist.
But you can execute java code when using a tool either using java
services [1] or with external java action [2].
> Best Regards,
> Tuan Hoang
[1]
http://help.eclipse.org/mars/topic/org.eclipse.sirius.doc/doc/specifier/general/Writing_Queries.html?cp=69_2_7_6#service_methods
[2]
http://help.eclipse.org/mars/index.jsp?topic=%2Forg.eclipse.sirius.doc%2Fdoc%2Fspecifier%2Fgeneral%2FModel_Operations.html&cp=69_2_5&anchor=extensions
Re: External Java action when changing context of an element [message #1711658 is a reply to message #1711496] Mon, 19 October 2015 03:03 Go to previous message
Laurent Fasani wrote on Fri, 16 October 2015 12:55
> Hi all,
> Best Regards,
> Tuan Hoang
[1]
[2]
Hi Laurent,
Thank for your answer.
I know how to use the External Java Action and I want to call it when the context of element changes. But my issue here is that I don't know when the context of element changes, because there are many ways to change the context of container, such as adding/ removing sub-Node, changing name of container, or editing sub-Node ...
Could you please guide me how to implement the listener for these actions?
Best Regards,
Tuan Hoang
Previous Topic:Grouping items in a table
Next Topic:How to change property of object with tool
Current Time: Mon Jul 21 02:50:52 EDT 2025
Powered by FUDForum. Page generated in 0.07253 seconds
