| Home » Archived » Eclipse Communications Framework (ECF) » r-OSGI: Upgrading from ECF 3.4 to 3.10/11(Trying to make old code work again)
 Goto Forum:|
| r-OSGI: Upgrading from ECF 3.4 to 3.10/11 [message #1711275] | Wed, 14 October 2015 10:05  |  |
| Eclipse User  |  |  |  |  | Hi,
 I have some really old code that's been running fine for 5 years but now I have to provide some new features. I figured that I would at the same time update external libraries such as the ECF provider library. However, the code breaks and I am not sure how to make something equivalent. The old code that breaks is the following:
 Dictionary<String, Object> props = new Hashtable<String, Object>();
			props.put(Constants.SERVICE_REGISTRATION_TARGETS, _clientContainer
					.getConnectedID());
			props.put(Constants.AUTOREGISTER_REMOTE_PROXY, "true");
			Constants.
			callContainer.registerRemoteService(new String[] { ARTParameterService.class.getName() },
					(Object) _artParameter, props);
			theContext.registerService(ARTParameterService.class.getName(), _artParameter, new Hashtable<String,Object>());
 The observant reader will see that the constant Constants.AUTOREGISTER_REMOTE_PROXY breaks, as it seems to have been removed from the library. I have not been able to figure out why and how to replace it.
 Any hints or tips on how to make the above code run on ECF 3.10/11 are greatly appreciated!
| Re: r-OSGI: Upgrading from ECF 3.4 to 3.10/11 [message #1711294 is a reply to message #1711275] | Wed, 14 October 2015 12:08   |  |
| Eclipse User  |  |  |  |  | On 14.10.2015 17:06, Lars Brenna wrote: > Hi,
 > _clientContainer
 >                     .getConnectedID());
 >             Constants.
 > ARTParameterService.class.getName() },                     (Object)
 > to replace it.
 Hi Lars,
 you will find more context with regards to the changes in the git commit
 [1] that removes the constant (among others) and bug #334448 [2].
 Cheers
 M.
 [1]
 http://git.eclipse.org/c/ecf/org.eclipse.ecf.git/commit/framework/bundles/org.eclipse.ecf.remoteservice/src/org/eclipse/ecf/remoteservice/Constants.java?id=ec9cb7618d514b0a6a4bc0d895ca622cf3305696
 [2] https://bugs.eclipse.org/334448
| Re: r-OSGI: Upgrading from ECF 3.4 to 3.10/11 [message #1711304 is a reply to message #1711275] | Wed, 14 October 2015 14:53   |  |
| Eclipse User  |  |  |  |  | Hi Lars,
 Lars Brenna wrote on Wed, 14 October 2015 10:05
					.getConnectedID());
			Constants.
 Marcus' links are quite correct, but I want to add a little explanation.
 When registerRemoteService was called as above, on the remote client(s) a proxy would be created and registered.  When we initially created this functionality, there was no specification from OSGi about how/when remote service proxies would be registered and so this property allowed ECF's implementation to do it in a non-standard way.
 Now, however, there is the OSGi Remote Service Admin specification (chap 122 in the enterprise spec) that ECF implements.  Part of that spec is a specification of the conditions under which a proxy is created,  i.e. how it's discovered/created/registered locally, etc.   To support the spec properly it was necessary to remove support for this constant.
 I would recommend using the OSGi Remote Services approach...which actually makes it much easier IMHO...and does not require that your code call the ECF remote services API at all.   Everything can/does happen as specfied by the RSA spec, and as implemented by the appropriate distribution provider (e.g. generic, rosgi, jms, etc...see https://wiki.eclipse.org/Distribution_Providers ).   Here's a tutorial showing an example:  https://wiki.eclipse.org/Tutorial:_Building_your_first_OSGi_Remote_Service.
 If you want to stay with the ECF remote services API yourself, and not move to OSGi Remote Services, then it would be possible register an IRemoteServiceListener and handle/respond to IRemoteServiceRegisteredEvents on clients by creating and registering a proxy of your own creation.  This can/ get pretty complicated however (WRT classloading, versioning, etc), and so I recommend that you use RSA.  If you would like more support on this method, however, I can provide it on ecf-dev mailing list:  https://dev.eclipse.org/mailman/listinfo/ecf-dev or via direct communication at slewis at composent.com.
 Scott
 [Updated on: Wed, 14 October 2015 14:54] by Moderator |  |  |  |  |  |  |
| Re: r-OSGI: Upgrading from ECF 3.4 to 3.10/11 [message #1711916 is a reply to message #1711356] | Tue, 20 October 2015 05:56   |  |
| Eclipse User  |  |  |  |  | Hi again,
 I ran into another issue during my work. The ServiceTracker interface has changed quite a bit. In the old code it is used like this:
 Declaration:
	private ServiceTracker _fileIdServiceTracker;
 setContext(BundleContext theContext) :
	_fileIdServiceTracker = new ServiceTracker(_context, FileIdService.class.getName(), null);
       _fileIdServiceTracker.open();
and then:
	public FileIdService getFileIdService() throws BundleException {
		FileIdService service = null;
		try {
			if (_fileIdServiceTracker.getTrackingCount() <= 0) {
				String msg = "Could not find local service " + FileIdService.class.getName();
				_logger.error("getFileIdService() " + msg);
				throw new BundleException(msg);
			service = (FileIdService) _fileIdServiceTracker.getService();
		} catch (NullPointerException e) {
			_logger.error("getFileIdService() NullPointerException: " + e.getMessage());
			throw e;
		return service;
 Reading what I could find on the web (the forum doesn't allow me to post external links...) leaves me thinking that I could get away with simply adding type arguments to ServiceTracker<s, t> where s is the type of object/service being tracked and t the type of object being returned. However, it seems that in my case s and t are the same so I'm adding the same type argument twice, like this:
	private ServiceTracker<FileIdService, FileIdService> _fileIdServiceTracker;
	_fileIdServiceTracker = new ServiceTracker<FileIdService, FileIdService>(_context, FileIdService.class.getName(), null);
 So my question is; does this look correct? It seems a bit funny to add the same type argument twice to ServiceTracker<s,t>...
| Re: r-OSGI: Upgrading from ECF 3.4 to 3.10/11 [message #1712357 is a reply to message #1711916] | Fri, 23 October 2015 05:24   |  |
| Eclipse User  |  |  |  |  | I realize I might be talking to myself here, but giving it another try. So I did what I posted above throughout the 20 plugin bundles I have, and it builds without errors. So far so good. However, I can't start the system (I'm using Eclipse Mars.1 by the way), and Eclipse throws a bunch of exceptions without pointing at my code or any of my settings. Googling these exceptions have not given any answers, the only thing I haven't tried is downgrading Eclipse to Luna. This is the console output:
WARNING: Port 9278 already in use. This instance of R-OSGi is running on port 9279
***WARNING: Display must be created on main thread due to Cocoa restrictions.
!SESSION 2015-10-23 11:14:45.173 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_31
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=nb_NO
Framework arguments:  --os macosx
Command-line arguments:  -dev file:/Users/larsbrenna/Desktop/svn/PARS-Runtime/configuration/dev.properties --os macosx -ws cocoa -arch x86_64 -console -consoleLog
!ENTRY org.eclipse.ui.ide 4 0 2015-10-23 11:14:47.400
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.ui.internal.ide.IDEWorkbenchPlugin.start() of bundle org.eclipse.ui.ide.
	at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:792)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721)
	at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:941)
	at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:318)
	at org.eclipse.osgi.container.Module.doStart(Module.java:571)
	at org.eclipse.osgi.container.Module.start(Module.java:439)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Caused by: org.eclipse.swt.SWTException: Invalid thread access
	at org.eclipse.swt.SWT.error(SWT.java:4491)
	at org.eclipse.swt.SWT.error(SWT.java:4406)
	at org.eclipse.swt.SWT.error(SWT.java:4377)
	at org.eclipse.swt.widgets.Display.error(Display.java:1097)
	at org.eclipse.swt.widgets.Display.createDisplay(Display.java:848)
	at org.eclipse.swt.widgets.Display.create(Display.java:831)
	at org.eclipse.swt.graphics.Device.<init>(Device.java:130)
	at org.eclipse.swt.widgets.Display.<init>(Display.java:721)
	at org.eclipse.swt.widgets.Display.<init>(Display.java:712)
	at org.eclipse.swt.widgets.Display.getDefault(Display.java:1427)
	at org.eclipse.ui.internal.ide.IDEWorkbenchPlugin.createProblemsViews(IDEWorkbenchPlugin.java:388)
	at org.eclipse.ui.internal.ide.IDEWorkbenchPlugin.start(IDEWorkbenchPlugin.java:345)
	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:771)
	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:764)
	... 12 more
Root exception:
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [bundleresource://131.fwk346861221:1/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [bundleresource://131.fwk346861221:2/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See <SLFJ website url omitted> for an explanation.
SLF4J: Actual binding is of type [org.slf4j.impl.Log4jLoggerFactory]
log4j:WARN No appenders could be found for logger (org.eclipse.m2e.core.internal.project.registry.ProjectRegistryRefreshJob).
log4j:WARN Please initialize the log4j system properly.
SLF4J: Found binding in [bundleresource://95.fwk346861221/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [bundleresource://95.fwk346861221:1/org/slf4j/impl/StaticLoggerBinder.class]
2015-10-23 11:14:49,404 [Start Level: Equinox Container: a048a780-6679-0015-10b8-91135119a1dc] DEBUG (ClientActivator.java:28) - ClientActivator() Default locale nb_NO changed to no_NO
2015-10-23 11:14:49,408 [Start Level: Equinox Container: a048a780-6679-0015-10b8-91135119a1dc] DEBUG (ClientActivator.java:35) - start() [PARS-RichClient] Starting
2015-10-23 11:14:50,038 [Start Level: Equinox Container: a048a780-6679-0015-10b8-91135119a1dc] DEBUG (ClientActivator.java:40) - start() [PARS-RichClient] Started successfully
osgi>
| Re: r-OSGI: Upgrading from ECF 3.4 to 3.10/11 [message #1718162 is a reply to message #1712357] | Sun, 20 December 2015 19:03  |  |
| Eclipse User  |  |  |  |  | Lars Brenna wrote on Fri, 23 October 2015 05:24 I realize I might be talking to myself here, but giving it another try.So I did what I posted above throughout the 20 plugin bundles I have, and it builds without errors. So far so good. However, I can't start the system (I'm using Eclipse Mars.1 by the way), and Eclipse throws a bunch of exceptions without pointing at my code or any of my settings. Googling these exceptions have not given any answers, the only thing I haven't tried is downgrading Eclipse to Luna. This is the console output:
!STACK 0
	... 12 more
Root exception:
osgi>
 Hi Lars.  Sorry I never responded to this previously, but your exceptions don't seem related at all to ECF Remote Services.  Rather, these seem to be cause by some non SWT thread calling into SWT code.  It seems to be an event handler thread.
 Current Time: Fri Oct 31 09:43:02 EDT 2025
 Powered by FUDForum . Page generated in 0.33254 seconds |
