Home » Modeling » EMF » Disable generation of validation package from Xcore
Disable generation of validation package from Xcore [message #1710999] Mon, 12 October 2015 05:03 Go to next message
I have project with an XCore model for which the code is automatically
generated (e.g., to emf-gen). For some time now, together with the model
classes, a validation package is created (and a description.txt). How
can I disable that?
In the generated classes, the generated JavaDoc states
"This can be disabled with -vmargs
-Dorg.eclipse.emf.examples.generator.validator=false."
So I added "-vmargs
-Dorg.eclipse.emf.examples.generator.validator=false" to the eclipse.ini
file (actually only the -D.. part in the general -vmargs section -- for
everyone who wants to disable this as well). This helped. But I'm
wondering if there is a possibility to avoid generation of the validator
examples without that explicit (and rather hidden) setting.
The weird thing: My colleagues are using the very same setup (and the
code is shared via git), and on their machines no validation package is
generated even without explicitly avoiding it via the eclipse.ini
setting. We are all using Eclipse Mars and XCore SDK 1.3.1.
Actually, this happens only when the generator is triggered
automatically, e.g., when changing the Xcore file. When I generate the
code explicitly via an MWE script (with The weird thing: My colleagues
are using the very same setup (using the
org.eclipse.xtext.generator.GeneratorComponent component), no validation
package is generated.
I haven't found any settings in the Xcore preferences.
Is it possible to disable the generation in the Xcore file explicitly?
E.g. in the @GenModel (although I haven't found any such field in the
properties view).
Jens
Re: Disable generation of validation package from Xcore [message #1711002 is a reply to message #1710999] Mon, 12 October 2015 05:26 Go to previous messageGo to next message
Jens,
EMF has an example for extending the generator. If you deploy this
example, i.e., if it's installed (which isn't intended) or if it's in
your target platform (also not intended), and your launch config
includes it (that could be accidental) it will simply kick in. I've
included this flag because of course in my runtime launches, the
examples are deployed (so I can test them) but usually I don't want to
do that, so I don't want them to kick in, so I include that option in my
launch config to turn if off.
That's all a long winded way of saying that I think you've installed the
example themselves in your IDE and that people who don't have the
problem haven't done that. Also, it's likely not in your target
platform, so when you launch MWE, it's not present and doesn't kick in.
So best you avoid doing that, uninstalling the examples if necessary.
On 12/10/2015 11:03 AM, Jens v.P. wrote:
> model classes, a validation package is created (and a
> description.txt). How can I disable that?
> So I added "-vmargs
> eclipse.ini file (actually only the -D.. part in the general -vmargs
> section -- for everyone who wants to disable this as well). This
> helped. But I'm wondering if there is a possibility to avoid
> generation of the validator examples without that explicit (and rather
> hidden) setting.
> is generated even without explicitly avoiding it via the eclipse.ini
> validation package is generated.
> properties view).
> Cheers,
> Jens
Re: Disable generation of validation package from Xcore [message #1711003 is a reply to message #1711002] Mon, 12 October 2015 05:32 Go to previous messageGo to next message
Thank you very much! That's explains the different behavior. Haven't
thought about uninstalling the examples... thanks!
Jens
Re: Disable generation of validation package from Xcore [message #1711021 is a reply to message #1711003] Mon, 12 October 2015 08:37 Go to previous message
Jens, you got "super-fast" but neglected "and nearly psychic" Smile
Previous Topic:[CDO] Server error with MySQL DBStore
Next Topic:[CDO] query on a view other than latest
Current Time: Mon Jul 21 08:30:43 EDT 2025
Powered by FUDForum. Page generated in 0.33630 seconds
