Home » Eclipse Projects » Eclipse Platform » Error logging in org.eclipse.ui when running .xml file as TestNG(Unable to execute tests through .xml file)
Error logging in org.eclipse.ui when running .xml file as TestNG [message #1710845] Fri, 09 October 2015 12:54 Go to next message
I am certain the .xml file is calling the right classes and packages. I have also tried running tests from different classes and have reinstalled eclipse and TestNG twice and I am still getting the same error. I have also made a completely new workspace to no avail.
This is the error message I am getting when trying to run the testng.xml file. I cannot post the full log yet as I haven't posted more than 5 messages and so I'm unable to reference eclipse.org
STATUS
pluginVersion 3.107.0.v20150507-1945
code 0
severity 4
message Unhandled event loop exception
fingerprint 3ed0857c
Exception:java.lang.NullPointerException: null
at HIDDEN.HIDDEN(HIDDEN:-1)
at org.eclipse.debug.internal.ui.launchConfigurations.LaunchShortcutExtension.launch(LaunchShortcutExtension.java:431)
at org.eclipse.debug.internal.ui.actions.LaunchShortcutAction.run(LaunchShortcutAction.java:74)
at org.eclipse.debug.internal.ui.actions.LaunchShortcutAction.runWithEvent(LaunchShortcutAction.java:123)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:595)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:511)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:420)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4362)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1113)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1137)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1122)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:788)
at org.eclipse.jface.action.ActionContributionItem$9.handleEvent(ActionContributionItem.java:1293)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4180)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3769)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:654)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:598)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at sun.reflect.NativeMethodAccessorImpl.invoke0(null:-2)
at sun.reflect.NativeMethodAccessorImpl.invoke(null:-1)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(null:-1)
at java.lang.reflect.Method.invoke(null:-1)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
REPORT
anonymousId 3741d217-639d-4c96-970a-231ce281c5eb
name
email
comment
eclipseBuildId 4.5.1.M20150904-0015
eclipseProduct org.eclipse.epp.package.jee.product
javaRuntimeVersion 1.8.0_60-b27
osgiWs win32
osgiOs Windows7
osgiOsVersion 6.1.0
osgiArch x86_64
logMessage false
ignoreSimilar false
BUNDLES
Re: Error logging in org.eclipse.ui when running .xml file as TestNG [message #1710874 is a reply to message #1710845] Sat, 10 October 2015 00:04 Go to previous message
Luke,
Given your stack trace:
at
It seems the problems happens in some extension code not provided by
Eclipse. Likely the extension implemented by TestNG to support
launching. No one at Eclipse can help with that because TestNG isn't an
Eclipse Project. Likely it's best you post here
https://groups.google.com/forum/#!forum/testng-users
Given it sounds like bug, reporting it would be good:
http://testng.org/doc/index.html#bug-reports
Previous Topic:Nasty new popups when switching to next perspective or editor
Next Topic:Eclipse Luna problem with Run Configuration
Current Time: Sun Nov 09 14:15:09 EST 2025
Powered by FUDForum. Page generated in 0.03251 seconds
