Home » Eclipse Projects » Oomph » Executing ResourceCreationTask after workspace switch
Executing ResourceCreationTask after workspace switch [message #1709604] Tue, 29 September 2015 09:41 Go to next message
I have a product setup that specifies a lot of preference tasks.
I also have a project setup that only adds a single resource creation task.
When i provision a workspace with this product/project combination, all preference tasks and the resource creation tasks are executed as expected.
When i then use the product and change the workspace, the preferences are all set in the new workspace. However, the resource creation task is not executed.
I am doing the resource creation task as part of the project setup, since the file needs to be created in the workspace.
I'm sure i am missing something in my setup. Or is this a bug after all?
My resource creation task is specified like this:
<setup:ResourceCreationTask
    xmi:version="2.0"
    xmlns:setup="http://www.eclipse.org/oomph/setup/1.0"
    id="com.codetrails.snipmatch.repositories.config"
    content="&lt;?xml version=&quot;1.0&quot; encoding=&quot;ASCII&quot;?>&#xA;&lt;org.eclipse.recommenders:SnippetRepositoryConfigurations xmi:version=&quot;2.0&quot; xmlns:xmi=&quot;http://www.omg.org/XMI&quot; xmlns:xsi=&quot;http://www.w3.org/2001/XMLSchema-instance&quot; xmlns:com.codetrails=&quot;com.codetrails.connect.snippets.rcp&quot; xmlns:org.eclipse.recommenders=&quot;org.eclipse.recommenders.snipmatch.rcp&quot;>&#xA;  &lt;repos xsi:type=&quot;org.eclipse.recommenders:EclipseGitSnippetRepositoryConfiguration&quot; name=&quot;Code Recommenders Snippet Repository&quot; description=&quot;The Git-based snippet repository provided by the Eclipse Code Recommenders project. It provides sharing capabilities based on Gerrit code review.&quot; id=&quot;org.eclipse.recommenders.snipmatch.repository&quot; defaultConfiguration=&quot;true&quot; url=&quot;http://git.eclipse.org/gitroot/recommenders/org.eclipse.recommenders.snipmatch.snippets.git&quot; pushUrl=&quot;https://git.eclipse.org/r/recommenders/org.eclipse.recommenders.snipmatch.snippets.git&quot; pushBranchPrefix=&quot;refs/for&quot;/>&#xA;  &lt;repos xsi:type=&quot;org.eclipse.recommenders:EclipseGitSnippetRepositoryConfiguration&quot; name=&quot;Custom Snippet Repository&quot; description=&quot;The Git-based snippet repository.&quot; id=&quot;org.example.snipmatch.repository&quot; defaultConfiguration=&quot;true&quot; url=&quot;http://${codetrails.server.hostname}/snipmatch/snippets.git&quot; pushUrl=&quot;https://git.eclipse.org/r/recommenders/org.eclipse.recommenders.snipmatch.snippets.git&quot; pushBranchPrefix=&quot;refs/heads&quot;/>&#xA;&lt;/org.eclipse.recommenders:SnippetRepositoryConfigurations>"
    targetURL="file:${workspace.location}/.recommenders/snipmatch/repositories.config"
    encoding="ASCII"/>
Re: Executing ResourceCreationTask after workspace switch [message #1709947 is a reply to message #1709604] Fri, 02 October 2015 03:49 Go to previous messageGo to next message
Have you verified that the project is actually imported in the second workspace. When you open Navigate->Open Setup, the project setup should be listed.
If not, try importing the project setup: File->Import->Oomph->Projects into Workspace, then you should get the wizard you know from the Oomph installation process.
See https://www.eclipse.org/forums/index.php/t/1070383/
[Updated on: Fri, 02 October 2015 03:54] by Moderator
Re: Executing ResourceCreationTask after workspace switch [message #1710096 is a reply to message #1709604] Sun, 04 October 2015 03:56 Go to previous messageGo to next message
Johannes,
This looks suspicious:
This would not work on Windows. Best to use ${workspace.location|uri)
to product a file: URI for a file system location. I'm not sure that is
the cause of the problem though...
> task.
> expected.
> is not executed.
> xmi:version="2.0"
> xmlns:xmi="http://www.omg.org/XMI"
> content="<?xml version="1.0" encoding="ASCII"?>
> <org.eclipse.recommenders:SnippetRepositoryConfigurations
> xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:com.codetrails="com.codetrails.connect.snippets.rcp"
> xmlns:org.eclipse.recommenders="org.eclipse.recommenders.snipmatch.rcp">
> <repos
> xsi:type="org.eclipse.recommenders:EclipseGitSnippetRepositoryConfiguration"
> name="Code Recommenders Snippet Repository" description="The Git-based
> It provides sharing capabilities based on Gerrit code review."
> id="org.eclipse.recommenders.snipmatch.repository"
> defaultConfiguration="true"
> url="http://git.eclipse.org/gitroot/recommenders/org.eclipse.recommenders.snipmatch.snippets.git"
> pushUrl="https://git.eclipse.org/r/recommenders/org.eclipse.recommenders.snipmatch.snippets.git"
> pushBranchPrefix="refs/for"/>
> <repos
> name="Custom Snippet Repository" description="The Git-based snippet
> repository." id="org.example.snipmatch.repository"
> url="http://${codetrails.server.hostname}/snipmatch/snippets.git"
> pushBranchPrefix="refs/heads"/>
> </org.eclipse.recommenders:SnippetRepositoryConfigurations>"
> encoding="ASCII"/>
Re: Executing ResourceCreationTask after workspace switch [message #1710405 is a reply to message #1710096] Tue, 06 October 2015 09:00 Go to previous messageGo to next message
@Ed: Thanks for the hint about the URL, I have corrected that mistake. You are right though in that this doesn't cause/affect the original problem.
@Alexander: When i go to Navigate > Open Setup, i don't see the project setup listed. The product setup is there, though.
When i then Import the setup as you suggested, i do get the wizard and as part of the resulting task, the resource creation task is correctly executed.
So this already gives me a workaround. Thanks!
Of course, i would like to spare developers the hassle to import the project setup. The resource creation task should thus be executed once for every workspace.
Re: Executing ResourceCreationTask after workspace switch [message #1710478 is a reply to message #1710405] Wed, 07 October 2015 01:39 Go to previous messageGo to next message
Johannes,
If you specify a task in a project setup of course it will only perform
when a stream for that project is referenced by the workspace.setup. If
you switch to a new workspace, that definitely won't be the case; there
will be an empty workspace.setup, and because it references no streams,
there will be no workspace task that resolve the workspace.location
variable. Also, when using the installer to create an installation, if
that project isn't selected, no workspace is created, and the installer
will not know where the workspace.location is in that case either. So
you can't just move the task to your product setup.
However, in a running IDE, ${osgi.instance.area} contains a URI for the
location of the workspace. So perhaps if moved your task to the
product, used ${osgi.instance.area} for the location of the workspace,
and (and this is important!) restricted the task (via the advanced
properties) to perform only on STARTUP and MANUAL, the task will perform
for each workspace opened by that installation. Note that it will
perform only in the running IDE which is the only place where the
workspace location is definitely known; this might be a problem if
something else has read (looked for) this file early during the
launching of the IDE before the task was executed.
> problem.
> project setup listed. The product setup is there, though. When i then
Re: Executing ResourceCreationTask after workspace switch [message #1710826 is a reply to message #1710478] Fri, 09 October 2015 10:31 Go to previous messageGo to next message
Thank you, Ed!
This helps me understand the Oomph process a bit better.
Your suggested solution of moving the task into the product setup using the ${osgi.instance.area} variable kinda works. But i have two issues with it.
Perhaps you can help me once more.
The first problem is that the user is asked for the value of "osgi.instance.area (undeclared)" during the setup.
This field is mandatory; the setup won't continue without an input here.
What the user puts in here is irrelevant. When it comes to evaluating the value in the IDE, the workspace path is resolved, which results in a correct resource creation.
I've tried creating a variable with the name "osgi.instance.area" with a fixed value of "foo", but if i do that, "foo" is the resolved value later on rather than the workspace path.
How can i use the variable without having the user have to input anything here? Preferrably, the user shouldn't be aware of the variable, even when selecting "show all variables."
The second thing is that when i declare the target URL like this: "${osgi.instance.area|uri}.recommenders/snipmatch/repositories.config" it is resolved during setup as "file%3A/Users/johannes/workspace/.recommenders/snipmatch/repositories.config" which is not a file URL and is instead seen as a path relative to the Oomph setup file location. Note, i am testing in Mac OS X.
When i declare the target URL like this: "${osgi.instance.area}.recommenders/snipmatch/repositories.config" it is resolved as "file:/Users/johannes/workspace/.recommenders/snipmatch/repositories.config" and works perfectly. I am surprised though that the "file:" part is prepended and worried that it might not behave correctly on all Operating systems.
Thanks again, i feel i'm almost there.
Re: Executing ResourceCreationTask after workspace switch [message #1710853 is a reply to message #1710826] Fri, 09 October 2015 14:01 Go to previous messageGo to next message
I've looked some more into my second issue with the way ${osgi.instance.area} resolves.
The system property is already a file URL, so using the "|uri" modifier is not necessary and will in fact try to escape the URL.
Thus, for Mac, and probably Linux, ${osgi.instance.area} works as expected.
Unfortunately, it doesn't work in Windows 7.
Here it resolves to "file:/C:/Users/codetrails/workspace/"
The ResourceCreationTask doesn't work with this kind of URL. It should have three slashes after the protocol. [1]
If i manually set the URL to "file:///C:/Users/codetrails/workspace/"... it works as expected.
Is there a way to a) work with this style of URL, to b) convert the URL into something the ResourceCreationTask can work with, or c) is this a bug in the way URLs are treated in Windows?
[1] https://en.wikipedia.org/wiki/File_URI_scheme#Windows_2
Re: Executing ResourceCreationTask after workspace switch [message #1710861 is a reply to message #1710826] Fri, 09 October 2015 16:25 Go to previous messageGo to next message
Johannes,
Comments below.
On 09/10/2015 4:31 PM, Johannes Dorn wrote:
> Thank you, Ed!
> This helps me understand the Oomph process a bit better. Your
> it. Perhaps you can help me once more.
> "osgi.instance.area (undeclared)" during the setup. This field is
Is that during the installer processing? As I said, you must disable it
for bootstrap because in the installer it's the workspace of the
installer, and it doesn't have one...
It should always be defined in the running IDE...
Yes, that's why I said " ${osgi.instance.area} contains a URI"... It's
already a URI...
> is resolved as
> Operating systems.
Re: Executing ResourceCreationTask after workspace switch [message #1710863 is a reply to message #1710853] Fri, 09 October 2015 16:33 Go to previous messageGo to next message
Johannes,
Comments below.
> expected.
That is correct, URI.createFileURI(new File(".'").getAbsolutePath())
will create file:/<drive>:/<path>. So does new
File(".'").getAbsoluteFile().toURI() for that matter.
In my opinion file://C:/... is more correct. It has the drive as the
authority and that prevents ".." from navigate up beyond that point.
But in any case file:///C:/... should work too; this has an empty
authority as opposed to the first form above, which as a null authority.
I'm not sure your basis for the conclusion that file:/C:/... is wrong.
This is commonly used everywhere and should work everywhere...
This information does not reflect what Java itself does on Windows. Try
new File(".'").getAbsoluteFile().toURI() which has nothing to do with EMF...
Re: Executing ResourceCreationTask after workspace switch [message #1710864 is a reply to message #1710861] Fri, 09 October 2015 16:49 Go to previous messageGo to next message
Ed Merks wrote on Fri, 09 October 2015 16:25
I had disabled it for Bootstrap, it is only triggered for Startup and Manual.
Still, the setup asks for a value.
Yes, defining a variable with the same name was just an attempt to get rid of the setup asking for a value.
I am probably wrong about this, yes (I don't have much experience with Windows file systems).
The point is though, that the file:/C:/... URL doesn't work for the ResourceCreationTask while the file:///C:/... URL does work. I haven't tried the file://C:/... URL, but that would be academic anyway, since all i get is the file:/C:/... version.
Re: Executing ResourceCreationTask after workspace switch [message #1710903 is a reply to message #1710864] Sat, 10 October 2015 11:15 Go to previous messageGo to next message
Johannes,
To test this, I tried adding the following task to my workspace.setup of
a debug self-hosted IDE:
xmi:version="2.0"
content="Testing"
targetURL="${osgi.instance.area}sample.text"
encoding="UTF-8"/>
That works and the task produced
"D:\sandbox\oomph-master\ws-IDE\sample.text" on disk as expected.
But I see your point that the installer will prompt for the variant,
because it's not defined in the installer. So I'm looking at how to
specify logic so that an undeclared variant that isn't actually used by
any triggered task is not prompted. Note that the installer generally
prompts for things that won't actually be needed until the IDE performs
the task to avoid a second round of prompting once the installed IDE is
launched; that bites us in this case.
Feel free to pen a bug; I also have it working locally, but it needs
more testing and review...
>> it for bootstrap because in the installer it's the workspace of the
> Manual.
>> wrong. This is commonly used everywhere and should work everywhere...
Re: Executing ResourceCreationTask after workspace switch [message #1710985 is a reply to message #1710903] Mon, 12 October 2015 03:23 Go to previous message
Ed Merks wrote on Sat, 10 October 2015 11:15
xmi:version="2.0"
content="Testing"
encoding="UTF-8"/>
Not sure what i did wrong earlier, or if a newer installer build is responsible, but file creation works as expected for me as well now.
I have created a bug for this: https://bugs.eclipse.org/bugs/show_bug.cgi?id=479535
Ed, i'd be happy to help test related changes.
Previous Topic:ResourceCreation of .options file in Eclipse install Directory
Next Topic:Prompt for record into for every value change
Current Time: Sun Jul 20 21:09:59 EDT 2025
Powered by FUDForum. Page generated in 0.04555 seconds
