Home » Newcomers » Newcomers » how to uninstall after using mars installer
how to uninstall after using mars installer [message #1710854] Fri, 09 October 2015 14:07 Go to next message
i installed mars, using the installer to /opt using sudo.
when i try to run, eclipse looks for packages under /root.
i suspect i shouldn't have run the installer as root.
can i simply delete the eclipse directory under /opt, or does the installer have an uninstall option?
thanks,
Dan
Re: how to uninstall after using mars installer [message #1710900 is a reply to message #1710854] Sat, 10 October 2015 10:53 Go to previous messageGo to next message
Dan,
The installer uses a bundle pool by default ((unless you've disabled it
via the menu) . By default that's in ${user.home}/pool, so whatever the
home is for the root, there will be a bundle pool folder there too that
you'll want to delete. Presumably a root user should only create
shared installation because other uses are unlikely to have write access
to the installation; currently an installation created using bundle
pools cannot be shared.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=469837
> thanks,
> Dan
Re: how to uninstall after using mars installer [message #1710919 is a reply to message #1710900] Sun, 11 October 2015 00:45 Go to previous message
Am 10.10.2015 um 16:53 schrieb Ed Merks:
> Dan,
> The installer uses a bundle pool by default ((unless you've disabled it via the menu) . By default that's in
> ${user.home}/pool,
I think it is ${user.home}/.p2/pool
Cheers
/Eike
http://www.esc-net.de
Previous Topic:FrameworkEvent ERROR for Mars
Next Topic:Eclipse crashes after changing -vm paths
Current Time: Mon Jul 21 00:33:42 EDT 2025
Powered by FUDForum. Page generated in 0.10163 seconds
