Re: Compare/ Merge tool for Papyrus [message #1711720 is a reply to message #1710831] |
Mon, 19 October 2015 08:43  |
Hi Marc,
The support is provided by the EMF Compare project, which provides Model and Diagram diff/merge for Papyrus, as well as a good EGit integration. That's your best option (The "Papyrus Compare" entry in the Papyrus Additional Components is a very thin layer on top of EMF Compare, so that's basically the same component Christian mentionned)
However, EMF Compare depends on some API changes/improvements in EGit that may not be available in the latest release version (This is a very active work-in-progress), so it might be worth contacting the EMF Compare project team directly to know how to get the latest stable version.
HTH,
Camille
FUDForum. Page generated in 0.32767 seconds
