Home » Modeling » Papyrus » Compare/ Merge tool for Papyrus
Compare/ Merge tool for Papyrus [message #1710817] Fri, 09 October 2015 09:57 Go to next message
Is there a Compare/ Diff/ Merge tool for Papyrus?
I have seen https://wiki.eclipse.org/EMF_Compare/CompareUMLPapyrusAPI
but it said that "THIS PAGE IS ARCHIVED. IT IS PROBABLY OUTDATED AND WILL NOT BE UPDATED"
Having such a tool would be really usefull to merge models coming from // developments.
Marc
Re: Compare/ Merge tool for Papyrus [message #1710828 is a reply to message #1710817] Fri, 09 October 2015 10:48 Go to previous messageGo to next message
Hi, Marc,
Select the "Install Papyrus Additional Components" item from the Help
menu. This brings up an installer wizard for the optional components
of Papyrus, one of which (in the "Modeler Extensions" category) is the
"Papyrus Compare (Incubation)" component.
HTH,
Christian
On 2015-10-09 13:57:58 +0000, Marc FLAUW said:
> // developments.
> Best regards,
> Marc
Re: Compare/ Merge tool for Papyrus [message #1710831 is a reply to message #1710828] Fri, 09 October 2015 11:21 Go to previous messageGo to next message
Thanks, I will give a try.
Marc
Re: Compare/ Merge tool for Papyrus [message #1711720 is a reply to message #1710831] Mon, 19 October 2015 08:43 Go to previous message
Hi Marc,
The support is provided by the EMF Compare project, which provides Model and Diagram diff/merge for Papyrus, as well as a good EGit integration. That's your best option (The "Papyrus Compare" entry in the Papyrus Additional Components is a very thin layer on top of EMF Compare, so that's basically the same component Christian mentionned)
However, EMF Compare depends on some API changes/improvements in EGit that may not be available in the latest release version (This is a very active work-in-progress), so it might be worth contacting the EMF Compare project team directly to know how to get the latest stable version.
HTH,
Camille
Previous Topic:Display Stereotypes in Sequence Diagrams
Next Topic:Deployment Diagram: how to connect elements?
Current Time: Sat Jul 26 13:24:27 EDT 2025
Powered by FUDForum. Page generated in 0.04380 seconds
